#1 Posted : 21 June 2008 09:03:04(UTC)
What are the features of this decoder and is it the early Delta Decoder with 4 Mouse Piano Keys?
nev
#2 Posted : 21 June 2008 11:11:07(UTC)
Nev, the 6080 is the original digital decoder. Big and chunky, with no load regulation. It is designed to be used with the AC motor.
The 6080 comes with 8 switches (mouse piano - I hate that term!), so that you can access all 80 addresses. It will automatically detect analogue operation.
Only F0 is supported by this decoder - normally used for the lights.
The Delta decoder in its original form was much more limited. You could select 16 addresses by soldering pads, and the lights were on when the engine was moving only. In its later incarnations it became more and more similar to a 6080.
#3 Posted : 21 June 2008 11:55:38(UTC)
THanks RAy,
Nev
#4 Posted : 21 June 2008 16:14:48(UTC)
I found this photo of the 6080 decoder:
http://www.pallund.dk/marklin/pictures/6080_scan.jpg
Offline mmervine
#5 Posted : 21 June 2008 16:33:25(UTC)
mmervine
A decoder made in Germany...those were the good old days!
thanks 1 user liked this useful post by mmervine
#6 Posted : 21 June 2008 22:39:12(UTC)
Lets have a look some different of 6080.
Date 1985 type (3653 Class 120).
Date 1991 (3660 Class 111).
Date 1992 (3682 Class V221).
Date 1993 (3658 Class 103).
#7 Posted : 22 June 2008 02:59:25(UTC)
THankyou Stephen. Getting a HAG from 1998 fitted with a 6080 decoder by the dealer when originally purchased.
NEV
Offline Lars Westerlind
#8 Posted : 22 June 2008 09:57:16(UTC)
Lars Westerlind
It's the 1985 which counts; still the Motorola standard chip on board :-)
A, those were the days. And the decoders were clumsy and bad performers.
/Lars
Offline Maxi
#9 Posted : 22 June 2008 16:43:11(UTC)
Maxi
But progress had to start from something.wink
Offline WelshMatt
#10 Posted : 23 June 2008 16:49:24(UTC)
WelshMatt
I think it very much depends on the motor they were paired with and indeed the loco. I have a couple of DHG 700s with this decoder which have very poor control, to the extent that they're not all that useful as shunters and will probably get 60760s if Marklin still make that kit. However, I also have a 3774 (transparent Br. 216) which is a fine performer with the same decoder but a different motor.
Matt from Wales.
Offline mmervine
#11 Posted : 23 June 2008 17:13:56(UTC)
mmervine
Matt:
The 60760 kits will be available again later this summer.
r/mark
#12 Posted : 23 June 2008 18:07:54(UTC)
This is the first generation 6080, as seen in Steventrains photo.
A 3772 from 1985
#13 Posted : 23 June 2008 21:02:39(UTC)
First generation - With Zymos controller chip - the "original"...
Then the LME03 - Lenz-Märklin-Elektronik - only understands the "old" protocol, also used in 3611/3613/3614 Württemberg C:s ...
Those relics are a long way from the first "high efficiency" drive which was made possible by the 701.13 chip (in original 6090 decoders)... But they do work ok still...
#14 Posted : 24 June 2008 08:58:18(UTC)
Offline tekin65
#15 Posted : 24 June 2008 12:41:36(UTC)
tekin65
Turkey
<br />THankyou Stephen. Getting a HAG from 1998 fitted with a 6080 decoder by the dealer when originally purchased.
NEV
Nev hi,
I just converted my Hag Re 6/6 to digital with 6080; works like a dream. Congratulations!
Cem.
Now all eras but no ICE
#16 Posted : 24 June 2008 13:15:54(UTC)
Good one Cem. I hope to get my Hag 250.1 next week. Instead of one trailer/Cab Car it has 2 so is a 3 car consist.
Nev
Offline tekin65
#17 Posted : 24 June 2008 13:20:44(UTC)
tekin65
Turkey
Hey Nev,
Check "How many locomotives ..." thread! biggrin
Cem.
#18 Posted : 24 June 2008 14:29:04(UTC)
<br />Hey Nev,
Cem.
Good Buying. biggrinbiggrin
N
#19 Posted : 04 July 2008 03:23:00(UTC)
Got the HAG 25o, runs nicely.
Question: What Voltage does the decoder supply to the interior Lights??
Headlights are Ok but the interior light is almost brown. Going to open up this morning . Looks like the original bulb was not changed for a lower voltage one.
nev
6080 decoder (H0-scale)
by cintrans 12/07/2025 18:03:29(UTC)
6080 decoders (Digital)
by cintrans 25/01/2024 17:26:11(UTC)
digital loco with 6080 decoder in analog mode (H0-scale)
by 3104V200 25/08/2023 08:04:09(UTC)
peculiar behavior from an old 6080 decoder (Digital)
by DaleSchultz 20/05/2020 20:50:29(UTC)
6080 decoder not responding? (H0-scale)
by Sir Timbo 05/03/2019 06:43:07(UTC)
Marklin 6080 decoder and Ecos controller (Digital)
by johnmarklin 21/06/2018 21:13:28(UTC)
CS2 - 6080 Decoder - 3670 Litt D 109 (Digital)
by gdk2003 04/01/2017 19:32:30(UTC)
Is there any benefits using 5-pole armature instead of 3-pole with Delta or 6080 decoders? (Digital)
by Janne75 01/05/2013 16:19:15(UTC)
I converted an 3106 BR 78 355 steam tank loco to digital with 6080 decoder today (Digital)
by Janne75 08/02/2013 01:24:29(UTC)
Testing Marklin 6080 Decoder (Digital)
by Arbeithuber 20/12/2010 01:33:19(UTC)
This page was generated in 0.892 seconds.
