Offline gauravk
#1 Posted : 15 October 2011 10:32:15(UTC)
gauravk
Hi i am new to Railroading and have recently developed a layout on winrail. I have a question, i want a city line on my layout but i want the track to look like a tram line which is covered with concrete. I am thinking of using marklin k track and covering it up with plaster while leaving the rails and center studs exposed. Can i do this? Will the k track still work? Are there any kits or special tracks i can order?
Offline kbvrod
#2 Posted : 15 October 2011 22:15:28(UTC)
kbvrod
Gaurav,welcome to the forum!Cool
Just to get this right,you want track to run in the streets of a city but not a tram per say?
You could use plaster for the outside of the rails but in between it would kind of hard to smooth out.
What you could do is use card stock or styrene for that.
Dr D
thanks 1 user liked this useful post by kbvrod
#3 Posted : 16 October 2011 10:14:06(UTC)
I know the effect you are trying to achieve and done correctly it looks pretty awesome, but it can be quite fiddly.
First thing is that K-track is not particularly forgiving of wet plaster - while the track is stainless steel, the center rail is not and rust may (probably will ) develop.
I wonder if you can use some form of gap filler instead to make the concrete appearance, ie 'no more gaps' (Selley's) or similar? - it's still a slightly moist product but not as harsh as plaster and you have the advantage of being able to shape/sculpture it while it's drying.
Getting is reasonably smooth will be fiddly, especially around the studs. I'd be interested to hear what others suggest as it's something I may ultimately want to do myself. Someone here is bound to have done it or seen it done.
Steve
Melbounre
#4 Posted : 16 October 2011 10:20:53(UTC)
Hi Gauravk,
Welcome to the forum.
#5 Posted : 16 October 2011 10:23:17(UTC)
Not sure if there is something to watch at youtube...
Offline pab
#6 Posted : 16 October 2011 12:38:18(UTC)
pab
Hi Gauravk,
I wanted to make a concrete floor in my loco shed.
I used plastic a imitation concrete pieces (just bought in my local shop) and placed it between the tracks. Easy to cut with a hobby knive.
Since the rails are higher than the pukos you have to make a new feeder for you trains. I used a T shaped piece between two parts of plastic. Make sure the wheels have enough space to move on the tracks.
You can also use an imitation coble stone, asphalt or other pavement layer between you're tracks. You can also think of making your own pukos (like copper nails soldered to a strip)
See the work in progress of the interior of my shed
I have picture of the end result inside. I do have one of the completed shed from outside by night
thanks 1 user liked this useful post by pab
Offline Renato
#7 Posted : 16 October 2011 16:35:54(UTC)
Renato
Hi Gaurav,
A warm welcome to the forum.
Renato
thanks 1 user liked this useful post by Renato
Offline Western Pacific
#8 Posted : 16 October 2011 17:26:50(UTC)
Western Pacific
Welcome,
Just for information 3-rail systems exist in the real 1:1 world:
Light rail line outside Grand Théâtre in Bordeaux (France).
Another picture with a light rail train.
More information about the APS (alimentation par le sol) can be found here:
In French.
In English.
Offline kbvrod
#9 Posted : 16 October 2011 17:34:51(UTC)
kbvrod
WP,can't see the photosConfused I don't think he is talking about light rail,as K-track certainly isn't.
Pab,you need inspection pits in your lokschuppen.Smile
Dr D
Offline gauravk
#10 Posted : 16 October 2011 18:38:27(UTC)
gauravk
Dr D
Yeah i want it to look like tram tracks but i will run a marklin railcar on it. Ok yeah it would probably be a bad idea to use plaster in between rails. Anyways thanks for your help ill keep u guys posted on my progress and put up pics asap.
Offline gauravk
#11 Posted : 16 October 2011 18:40:39(UTC)
gauravk
Steve
Melbounre
Thanks for the tip about the rust. Ill do some research on kinds of materials i can use. I was also thinking plastic wood. I guess ill haveto try out a few before i finally decide on a materiaL.
Offline gauravk
#12 Posted : 16 October 2011 18:42:36(UTC)
gauravk
Hi Gauravk,
Thanks. Its great to be here. I never realised there was a another world out there full of marklin'ists'. Lol
Offline gauravk
#13 Posted : 16 October 2011 18:46:28(UTC)
gauravk
Originally Posted by: pab Go to Quoted Post
Hi Gauravk,
Thanks for the advice, ill probably try something like that as well. The pics really help. Nice loco sheds.... did u build it from scratch or buy a kit?
Offline gauravk
#14 Posted : 16 October 2011 18:50:13(UTC)
gauravk
Yeah iv been looking on youtube and have also done a search on google. Didnt come up with anything.
#15 Posted : 16 October 2011 20:06:40(UTC)
Western Pacific
Running a railcar sound like a nice idea.
You could even have heavier trains, provided that you look at for instance Jack London Square in Oakland, California:
Jack London Square, Oakland, CA
Photo shot on January 2nd 2008 at 19h46 (or 7h46 pm) using a mobile phone, showing an Amtrak California train leaving Oakland. I believe it was going to Sacramento.
Offline pab
#16 Posted : 16 October 2011 21:29:06(UTC)
pab
Hi Gauravk,
You're welcome
It's a (Faller) kit with some enhancements (e.g. lights, stone innerwall)
#17 Posted : 17 October 2011 13:41:26(UTC)
cookee_nz probably understates the risk for rust. It will rust heavily!!!
Using cardboard is a good idea.
But I think the best solution is:
Place a strip of conducting sheet-metal along the centerline where you want the track to go.
Use some (cheap) generic 2-rail track.
Fill the space between the tracks with what-ever materiel.
Hammer in nails (with a small rounded head) along the centerline of the track.
Connect the sheet-metal from under the track to a trafo, and the nail-heads will do the puko-job...
The old Märklin-master (Profi-Tips, etc) did it this way.
#18 Posted : 17 October 2011 14:35:06(UTC)
Didn't Peco make a track with removable center studs? This might be an easier way to get the center concrete look..
Offline Nielsenr
#19 Posted : 17 October 2011 18:22:37(UTC)
Nielsenr
To expand upon Piet's and Henrik's posts, as can be seen from Piet's photos, you might consider trying to use standard two rail track connecting the rails together electrically. For the center rail you could use an N scale rail secured to the sleepers. Someone here on the forum did that for a hidden station since it was less expensive to buy lengths of two rail flex track and N scale rails than it was to buy standard Marklin track. The end result would have it looking like the real life photos posted.
Robert
Offline kbvrod
#20 Posted : 17 October 2011 23:00:14(UTC)
kbvrod
Hi all,Adrian,
They did but I think it was discontinued.Erbert still makes their pukos.
Dr D
Offline gauravk
#21 Posted : 19 October 2011 08:48:48(UTC)
gauravk
Well since im a first time railroader this seems a little complex...but i will give it a go.
Thanks.
#22 Posted : 19 November 2011 22:36:17(UTC)
You have been a member since:: 10/02/2006(UTC)
here is how I did it (also K-Track)
http://layout.mixmox.com/1/concrete-rails
Offline gauravk
#23 Posted : 29 November 2011 14:49:40(UTC)
gauravk
Wow the end result is good. thats what im looking for. which brand of modelling clay did u use?
#24 Posted : 08 December 2011 03:47:16(UTC)
I used some clay called DAS
#25 Posted : 08 December 2011 06:07:06(UTC)
Which is readily available here in NZ, so folks in larger countries should have no trouble finding it.
Guest (9)
Marklin K Track Points (H0-scale)
by Trevor G 27/01/2025 04:48:18(UTC)
Marklin K track (General MRR)
Belarus Marklin30 01/11/2023 04:47:51(UTC)
ACME coaches on Marklin K track, (H0-scale)
by danmarklinman 13/03/2021 19:15:44(UTC)
Lsmodels on Marklin k track !!! (H0-scale)
by danmarklinman 15/01/2021 11:03:49(UTC)
AC and DC with Marklin K track ? (Model railroad wiring)
by Mattawa 26/02/2017 12:41:36(UTC)
Marklin K track equivalent (General MRR)
by Hackcell 13/04/2016 21:26:19(UTC)
Marklin K track 2292 feeder track help. (Digital)
by danmarklinman 28/05/2015 10:53:42(UTC)
Piko AC diesels do they run well on Marklin K TRACK PLease (H0-scale)
by dan67millie 07/03/2012 17:38:04(UTC)
Roco on Marklin K track (H0-scale)
by dan67millie 23/12/2010 20:33:06(UTC)
DC on Marklin K track? (H0-scale)
by 5HorizonsRR 20/04/2009 08:54:27(UTC)
This page was generated in 0.942 seconds.
