Offline marklin913
#1 Posted : 31 July 2010 02:33:13(UTC)
marklin913
Confused my central station 1 is not working well everything works but the touch screen are there any fixes i can do . it's long since been out of warraty .
#2 Posted : 31 July 2010 03:46:09(UTC)
One possibility is that the touch surface is already registering contact.
This may be a dirty surface but I would suggest checking the plastic surround for either deformed plastic pressing down or maybe dust/crumbs caught in the gap.
I have a related issue at the bottom centre of the screen where I used to roll my finger over the edge of the plastic to press the button to change to "Accessories" mode. I would subsequently have unresponsive buttons or the mode would randomly change back to the loco screen as if the button was pressed again - because the plastic was bent onto the screen.
Regardless this does not render the CS1 useless - connecting to a PC can allow continued access to almost all the functions
like registering new locos, signals and routes manually (and , with the right program, can make the process smoother and more fun)
Offline marklin913
#3 Posted : 31 July 2010 04:22:17(UTC)
marklin913
ThumpUp THAT FIXED IT i have been trying to fix it for 6 months i called marklin in the usa and germany and also esu (i think they designed it) but none of them had an answer. THANKS Chris !!!!!!!!!!!!ThumpUp
#4 Posted : 31 July 2010 05:39:54(UTC)
Chris?? Clapcott's name has been Peter for as long as I've known him!
Good that your problem has been fixed though!
Offline GSRR
#5 Posted : 31 July 2010 08:02:11(UTC)
GSRR
Marklin 913, or is it Chris?
Welcome to the forum. Peter is one of the most knowledgeable and helpful members concerning digital.
(Peter, bit of a dry spell, glad to see you back)
Thomas
#6 Posted : 31 July 2010 10:48:42(UTC)
He's been busy writing some software. And attending exhibitions! Cool Wink
#7 Posted : 31 July 2010 11:49:22(UTC)
Hi and welcome to the forum.Smile
Online David Dewar
#8 Posted : 31 July 2010 13:54:05(UTC)
Once again Peter solves a problem with a single post. I will print this off in case I have the same problem in the future.
dave
Lost cables for Central Station 1 (Digital)
by johnhendry 06/11/2024 22:18:14(UTC)
by dave55uk 21/09/2023 22:23:59(UTC)
Central Station 1 (60212) with bad screen (Digital)
by cwp_marklin 31/01/2015 20:24:22(UTC)
Central Station 1 (60212) (Digital)
by Rocca 27/04/2013 08:58:04(UTC)
Using two Central Station 1 in tandem? (Digital)
by magload 10/03/2013 19:49:57(UTC)
Central Station 1 #60212 parts needed (Digital)
by Dave Banks 19/03/2011 03:13:43(UTC)
Which booster is compatible with 60212 Central Station 1 (Digital)
by biswasg 21/08/2010 10:17:56(UTC)
Central Station 1 and 2 (Digital)
by James 21/01/2010 05:39:24(UTC)
Central Station 1 controls (General MRR)
by Drongo 13/06/2009 14:21:46(UTC)
Central Station 1 and 2 connections (Digital)
by James 11/02/2009 10:30:10(UTC)
This page was generated in 0.446 seconds.
