Offline I_love_Marklin_37538
#1 Posted : 05 March 2010 22:22:40(UTC)
Ok
I have a module in the making and I am considering using Marklin signals but can anyone offer me any advice on Viessmann signals and the realism and quality of it and the difference between Marklin Signals
Offline rschaffr
#2 Posted : 05 March 2010 22:46:43(UTC)
rschaffr
I use all Viessmann signals. I have never tried the Marklin ones, though. I like the construction and the reliability of the Viessmann ones so i have not looked elsewhere. Actually, I stared with Viessmann because I got one for free at a train show in Munich when I bought a catalog, so I just stayed with them.
-Ron
Offline petestra
#3 Posted : 05 March 2010 22:59:07(UTC)
I started to build my new layout last Sept. and I wanted to replace most of my
72** series signals that were about 40 years old with the new 76*** ones. Most of the
expense for the new layout was for 18 of these new signal. The layout is now wired
except for buildings and I must say I'm very happy with these signals. They are pricey
but they are worth it. They work beautifully!Good luck! Cheers, Peter
Offline Breitenfurt
#4 Posted : 06 March 2010 00:14:46(UTC)
Breitenfurt
Obviously not the same but I am (or, rather, will be) using just Viessmann signals. Actually the modern Marklin Z scale signals are made by Viessmann anyway. I don't know where you live but there is a hobby shop in the UK that is selling off all its Z stock at really good prices (like my signals were about 40% off. Address can be supplied is any interest.
To answer you query, I find them very realistic and fragile. They have a much larger range than Marklin (in semaphore anyway).
Best wishes,
Chris.
#5 Posted : 06 March 2010 00:27:47(UTC)
Alex lives in New Zealand, and both Viessmann and Marklin signals can be obtained from Dion at Toottoot.
Offline pab
#6 Posted : 06 March 2010 12:53:49(UTC)
pab
I use Viessmaan signals (semaphore) for a long time now. They are reliable.
The Viessmann semaphore signals are much better looking. The M signals are not as detailed and the Viessmann signals move slowly and have no visible power unit. You only need a 12 mm hole in your table.
For the semaphore signals you need about 10 cm free space under your table.
#7 Posted : 06 March 2010 14:49:13(UTC)
I am changing from the old Marklin colour light signals to the Viessmann semaphores. I chose them because they look more realistic than the Marklin semaphores which were introduced in the '50s.
THe new Marklin colour light signals are very nice, and I think they are made by Viessmann as well, but I'm not sure about that.
Offline cyberbeast41
#8 Posted : 06 March 2010 19:27:09(UTC)
cyberbeast41
Most Marklin and Viessmann signals are just the same. They are both made by Viessmann, with only small changes.
Whatever you choose, it doens't matter that much.
Offline pab
#9 Posted : 07 March 2010 16:06:39(UTC)
pab
Talking about semaphore signals, you're wrong.
I don't know about other signals
Offline Breitenfurt
#10 Posted : 07 March 2010 20:47:41(UTC)
Breitenfurt
Hi Piet.
Well, certainly the Z scale signals are identical to the Viessmann ones except that they were green instead of Viessmann's black. I am surprised that they didn't do the same with HO. Whatever, they are certainly a lot more realistic than the older versions.
Best wishes,
Chris.
Offline Macfire
#11 Posted : 08 March 2010 02:06:55(UTC)
Macfire
I agree.
Viessmann for me and cost was also a factor - M being dearer.
Lord Macca
Offline James
#12 Posted : 11 March 2010 21:40:13(UTC)
James
Hello All:
Just my 2 cents worth.
I'm sure that Viessmann is constructing some items for Marklin, but I'm not sure about the light signals. As of yet, I haven't seen Marklin's newer light signals being offered under the Viessmann label.
Part 1: Semaphore Signals
When it comes to the semaphore line of signals, for me, it has to be Viessmann all the way. The detail and the slow motor mechanism is the greatest. To be fair to Marklin, though, they really haven't tried to upgrade their semaphore signals, concentrating on their light signal product line. Viessmann offers a larger variety of semaphores as well.
Part 2: Light Signals
When it comes to the light signals without a doubt it has to be the newer line of Marklin signals. The thing about them, for me, is the slow (prototypical)transition color changing that is most appealing, plus the fact that the wires are hidden within the mast. Viessmann's light signals have the wires visibly running through the mast assembly.
My layout reflects the era III / IV time period in Germany and so my signals a transitional. For the mains, I primarily use light signals while on the branch lines, Semaphore's can still be found.
____________________________________________________________________________________________________________________________________________
James Bannerman
Give me steam, and how you feel can make it real, real as anything you've seen. (Peter Gabriel)
Offline Tex
#13 Posted : 12 March 2010 01:53:38(UTC)
Tex
James wrote:
Hello All:
it comes to the light signals without a doubt it has to be the newer line of Marklin signals. The thing about them, for me, is the slow (prototypical)tranPart 2: Light Signals
When sition color changing that is most appealing, plus the fact that the wires are hidden within the mast. Viessmann's light signals have the wires visibly running through the mast assembly.
Offline Tex
#14 Posted : 12 March 2010 01:59:54(UTC)
Tex
Tex wrote:
James wrote:
Hello All:
I agree with the Marklin new light signals being the most reliable and atractive choice. Also modeling the era III/ IV transition period in Germany and am replacing marklin / Viessmann semophores as fast as I can afford to.
Tex
viessmann signals multiplexer (Digital)
by Alfred Bugeja 20/08/2023 09:22:45(UTC)
Viessmann signals with ESU SignalPilot and CS3 (Digital)
by swisslocofan 26/05/2021 23:56:39(UTC)
Azatrax Signal Controllers used with Viessmann Signals (General MRR)
by andrews 25/07/2018 03:14:19(UTC)
Viessmann Signals (H0-scale)
by alistairiancampbell 01/05/2018 04:32:38(UTC)
operating Viessmann Signals (Digital)
by pradeep 26/02/2014 19:26:01(UTC)
Can the ESU SwitchPilot 51800 be used for Viessmann signals (Digital)
Belarus Semaphore 07/01/2013 17:36:23(UTC)
Viessmann signals & how to connect using CS1 (Digital)
by Dave Banks 16/03/2010 23:42:32(UTC)
Viessmann signals with marklin (Digital)
by pyxa69 05/05/2007 04:22:40(UTC)
Viessmann signals and brake module (Digital)
by Nuno 26/10/2005 20:59:40(UTC)
Question on Viessmann signals (H0-scale)
by efel 27/07/2005 20:31:09(UTC)
This page was generated in 1.127 seconds.
