Offline applor
#1 Posted : 13 February 2005 12:17:56(UTC)
applor
hello all,
just wondering about these. I have recently purchased some nice coach sets and I want to light them.
My setup is digital so I'd be putting a decoder in one coach and using these in between them.
Anyone used them before? I remember reading somewhere that they weren't the best and that Roco ones or something are much better.
Offline Tamrac
#2 Posted : 13 February 2005 16:04:37(UTC)
Tamrac
I have not tried any yet, but I think this subject was brought up in the forum before and Marklin's version of the CC's was not a favorite. I have been looking at the ones offered by Viessmann, the seem to be a very good design.
Offline rschaffr
#3 Posted : 13 February 2005 16:05:34(UTC)
rschaffr
Applor:
I use the Viessmann 5048 two circuit couplers. They look good (small knuckle) and have two sets of contacts (one on top and one on bottom). They couple and uncouple normally, and work well. I tried the Roco 4-conductor ones. they a re large, blocky things that have to be coupled and uncoupled manually.
-Ron
#4 Posted : 13 February 2005 17:32:49(UTC)
I agree with Ron. Have just used the Viesmann couplers which are Fleischman close couplers modified and so far have worked very well. They are two pole where Roco are four pole but Roco do not couple and uncouple without a struggle. I believe all coaches should be lit. Well done.
David
Offline Lars Westerlind
#5 Posted : 13 February 2005 18:49:07(UTC)
Lars Westerlind
I prefer Roco as they are four pole; I get one slider and a rather fixed set of cars, but i can control some lamps individually in this way. Rocos couplers are far easier to handle than Märklins, one pole; but not ideal of course.
/Lars
Offline rschaffr
#6 Posted : 13 February 2005 19:03:28(UTC)
rschaffr
Four poles was tempting, but I liked the functionality of the Viessmann better. As I said I tried both. In actuality, I don't know what I would do with four poles, anyway. I have set mine up with the upper pole switched, the lower always powered, and each coach indivdually grounded with the grounding leaf springs. I am converting my loks to have a 24v relay in them to turn the lights in the cars on and off with a lok funciton. that way I have only the lok slider on my steam and diesel, and no sliders on my e-loks (I use the catenary).
-Ron
Offline Sander van Wijk
#7 Posted : 13 February 2005 20:58:23(UTC)
Sander van Wijk
I've tested the Viessmanns as well and I'm very pleased with the result. The only small problem is that after many times coupling and uncoupling the conductors bend a little and sometimes don't work anymore. Very easy to solve by bending it back. I don't consider it to be a problem since I won't change the train composition often. I only use these couplers to make it possible to store the cars in their original boxes easier.
By the way, I agree with Ron, I don't see the use of a 4 pole coupler too. Lars, what do you use the 3th and 4th pole for?
Sander
#8 Posted : 13 February 2005 21:23:59(UTC)
I dont see any use for four poles as any number of leads can be taken from two. Also being unable to uncouple is poor. I take my power from the loco and therefore no need for other pick ups on the coaches etc.
I have yet to hear from anybody who uses the M version with success.
David
Offline rschaffr
#9 Posted : 13 February 2005 21:34:45(UTC)
rschaffr
I've not tried the Marklin ones. I have gotten some with some light kits and just discarded them. They look similar to the special couplers that our 3770 ICE-1 has. Those hold together ok, but it takes a bit of effort to couple them and uncouple them. In that case, however, I keep the ICE together so it doesn't matter.
-Ron
Offline applor
#10 Posted : 21 February 2005 05:10:27(UTC)
applor
another thing I'm curious about, is can you get CC close couplers?
I noticed one of my new sets, a aqua IC express (4327) are close couplers and would be good if I could keep them that way.
Offline rschaffr
#11 Posted : 21 February 2005 05:38:35(UTC)
rschaffr
The Viessmann couplers directly replace the NEM pocket Marklin close couplers and work exactly the same with repect to coach spacing. I have had no problem with them.
-Ron
#12 Posted : 21 February 2005 09:06:34(UTC)
Lars Westerlind
Roco 4 pole couple close also.
/lars
#13 Posted : 21 February 2005 13:09:33(UTC)
Sorry Lars but Roco (which I did like in the past) are not as close as the Viessmann couplers....and of course Viessmann do actually couople and un couple on the track.
David
#14 Posted : 21 February 2005 13:39:41(UTC)
Lars Westerlind
<br />Sorry Lars but Roco (which I did like in the past) are not as close as the Viessmann couplers....and of course Viessmann do actually couople and un couple on the track.
David
You are probably correct. Let me correct my statement:
Roco 4 pole couple close enough for me.
/lars
Offline nico van zon
#15 Posted : 21 February 2005 15:31:26(UTC)
nico van zon
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />...Roco 4 pole couple close enough for me.
The Roco couples exactly the distance as stated in NEM 362, so nothing wrong with this one.
#16 Posted : 21 February 2005 18:59:51(UTC)
AS far as I know the Veissmann couplers are in fact Fleischmann close couplers and will work with uncoupling tracks etc. So far I have found them really good. I have dozens of the Roco 4 pole couplers and will probably continue to use them for coaches that do not require to be uncoupled from the loco as I take the power from the loco.
David
Offline rschaffr
#17 Posted : 21 February 2005 20:04:07(UTC)
rschaffr
David: Yes, they are supposed to be identical with the Fleischmann 6515 profi couplers with the circuit contacts and wires added. I haven't tried it yet, but after I get a significant number of loks converted to the Viessmann couplers, I plan to buy some of the fleischmann ones for cargo cars taht don't need the power.
-Ron
Offline tnx jake
#18 Posted : 22 February 2005 17:40:53(UTC)
tnx jake
Well, one thing we can all agree on is that the Marklin close couplers are not acceptable. I have used the Roco four conductor cc couplers for years and find them excellent. I have converted all of my passenger cars to them. I am sure that others are as satisfactory or better.
Jack
Offline rschaffr
#19 Posted : 22 February 2005 18:32:50(UTC)
rschaffr
Jack: The Roco couplers are well made and link and operate very well. My only problem was that they have to be manually coupled and uncouped, as do the Marklin ones. That is the main reason I went with the Viessmann ones.
-Ron
Offline Chrome
#20 Posted : 22 February 2005 19:22:58(UTC)
Chrome
Has anybody tried the RTS current conducting couplers?
They look nice - a lot like the normal M* closecouplers.
See fx. http://cgi.ebay.de/ws/eB...item=7302069687&rd=1
Offline McLae
#21 Posted : 23 February 2005 02:29:30(UTC)
McLae
[size=1" face="Verdana" id="quote]quote:Lars, what do you use the 3th and 4th pole for?
I can answer that. I am setting up to have power and lighting control from the Lok. Bottom connections (1-2) are read/brown for most lights. Directly from frame and decoder red feed (might be catenary). Connections 3-4 are for cab unit control (steurwagon[however it is spelled]). This way, no sliders on the cars to complicate block control.Cool The cars in the middle just pass 3-4 on to the end car.
Now if Marklin would just make an OBB City Shuttle.....
The McLae
Offline Mikael
#22 Posted : 23 February 2005 09:50:06(UTC)
Mikael
[size=1" face="Verdana" id="quote]quote:Originally posted by Chrome
<br />Has anybody tried the RTS current conducting couplers?
I'm not sure, but they look like some that I use. I don't know the name/make of my couplers. I just got them at my local shop.
If they are the same (and I think so), then they work relatively well. They are just a bit hard to couple/uncouple, usually needing manual intervention by a helping hand. They are supposed to get better once they have been used for a while. Time will tell.
Offline tnx jake
#23 Posted : 23 February 2005 17:16:23(UTC)
tnx jake
Ron,
Yes that is the drawback. However I use them in sets of cars that I never really uncouple from each other in running. The first and last car has a regular coupler. I also have used the four conductors to a decoder and can turn lights on and off in four individual cars. That really impresses visitors. In any event, I think we can all agree that the Marklin CC couplers are just too difficult to work with. I used to have to put a whole train together upside down and then get it on the track. What a pain.
Jack
ESU LED Lighting - Current Conducting Couplers (H0-scale)
by Eddie7979 28/03/2023 12:08:28(UTC)
Interior Lighting & Current Conducting Couplers (H0-scale)
by Eddie7979 18/10/2022 11:58:28(UTC)
72021 current conducting couplers (H0-scale)
by marklinist5999 15/05/2021 21:02:42(UTC)
current conducting couplers fro 4132 style coaches???????? (H0-scale)
by dominator 24/10/2020 09:50:02(UTC)
Lokpilot, coach lighting & current conducting couplers (Model railroad wiring)
by morsing 29/10/2018 20:33:02(UTC)
Current conducting couplers (General MRR)
by morsing 18/10/2018 21:44:59(UTC)
Voltage in Current Conducting Couplers? (H0-scale)
by waltklatt 10/05/2018 16:19:47(UTC)
New Märklin current conducting couplers (H0-scale)
by Minok 04/10/2017 23:43:34(UTC)
Current Conducting Couplers -- Installation Help (General MRR)
by AJH4 03/03/2017 01:06:30(UTC)
Marklin Locos with Current Conducting Couplers (H0-scale)
by xxup 13/04/2016 07:42:43(UTC)
Coach not prepared for current conducting couplers? No problem. (H0-scale)
by biedmatt 30/05/2015 23:30:51(UTC)
HO current conducting couplers (H0-scale)
by rhfil 23/09/2014 17:20:40(UTC)
RTS Current Conducting Couplers (News from Märklin and others)
by Armando 14/03/2014 23:28:43(UTC)
Current Conducting Couplers 43873 (H0-scale)
Belarus Harvey 29/12/2013 19:38:53(UTC)
Installing 72021 current conducting couplers (Collector's Corner general)
by Bob 01/05/2011 15:11:44(UTC)
2 Pole Current Conducting Couplers (AGAIN) (H0-scale)
by nevw 08/03/2010 06:09:34(UTC)
Can I use current conducting couplers on a loco? (Digital)
by sebastian 31/05/2007 22:06:58(UTC)
Viessmann vs RTS current conducting couplers (H0-scale)
by efel 10/03/2007 19:44:10(UTC)
Roco Current Conducting Couplers (H0-scale)
by tnx jake 09/02/2003 17:25:36(UTC)
Current conducting couplers from RTK-Elektronik? (H0-scale)
by Hans_Dietrich 10/01/2003 18:25:41(UTC)
This page was generated in 1.319 seconds.
