Offline Frostie
#1 Posted : 05 February 2005 17:26:37(UTC)
Frostie
I accidently received a shipment of a model 70000 caternary starter set from a dealer. I was not unhappy and decided to keep it and try it out.
It really adds to the layout, and I like it.
It is mounted on C track and using the height guage it measures a 4 on the little guage which indicates Fleischman Profi.
It appears to run ok, but the indicator for marklin C Class is number 7 on the guage.
Is it ok to be mounted on C track, but giving the measurement of Fleischman Profi ? Will I run into any problems ?
CS/MS Digital Era 1/2
Offline Alberto Pedrini
#2 Posted : 05 February 2005 22:18:13(UTC)
Alberto Pedrini
Look at my page http://www.gfobergamo.it/catenaria.htm, perhaps you will find the answer, so it runs ok. wink UserPostedImage
Alberto
Marklinfan Club Italia
www.marklinfan.net
Offline tnx jake
#3 Posted : 05 February 2005 23:17:00(UTC)
tnx jake
Frostie,
I am surprised it measures a four. I have it mounted on the layout next to C just as it comes as shown in the instructions and it measures a 7. It works fine.
Jack
Offline Frostie
#4 Posted : 06 February 2005 15:15:28(UTC)
Frostie
Everything seems to run OK. I am attaching the masts to the track using the little clips, so that might be the measurement issue.
However, I will just have to see how ut works with time.
Offline tnx jake
#5 Posted : 06 February 2005 18:00:00(UTC)
tnx jake
Frostie,
If you are using the metal clips to the C track you should be fine.
Jack
Offline tnx jake
#6 Posted : 06 February 2005 20:44:18(UTC)
tnx jake
Frostie,
I have measured the distance between the top of a rail on C track and the bottom arm of the catenary mast and it is aprox. 2 5/8 inches. If you are anywhere close you will be within a good tolerance. However, the side to side adjustment is critical particulaly on the narrow Swiss pantos.
Hope this helps.
Jack
Offline Tony
#7 Posted : 06 February 2005 21:44:39(UTC)
Tony
Hey Alberto - thats a great picture - really clear, in focus and defined.
Regards Tony
Offline applor
#8 Posted : 07 February 2005 06:16:27(UTC)
applor
yeah what camera do you own?
Paint Colour required for Marklin Catenary (H0-scale)
by marklin61 04/12/2023 20:45:38(UTC)
by Ausipeet 18/08/2021 05:13:57(UTC)
by Kyrannosaurus 08/08/2018 11:01:16(UTC)
Old-Style Marklin Catenary- Wire Material and Conductive Weathering Treatments? (Painting & Weathering)
by 5HorizonsRR 09/05/2016 22:43:46(UTC)
working with Marklin catenary (H0-scale)
by quarkhirad 06/05/2015 14:33:59(UTC)
Marklin Catenary? (H0-scale)
by biedmatt 06/05/2014 13:23:17(UTC)
Pantographs with new marklin catenary (H0-scale)
by marklin61 16/02/2014 10:42:11(UTC)
Marklin Catenary Question- "Blacken It" Product (H0-scale)
by 5HorizonsRR 28/02/2006 23:16:32(UTC)
Diameter of NEW Marklin catenary wire segments? (H0-scale)
by David Barnblatt 20/07/2005 20:42:55(UTC)
This page was generated in 0.389 seconds.
