Offline saetta
#1 Posted : 19 March 2015 02:21:31(UTC)
saetta
I am sure this topic has been discussed somewhere else at length...BUT I keep having to replace my switch motors evry 2 hours of use. Have warrantied 3 of them already. MARKLIN GET IT TOGETHER !!! FOR HEAVEN SAKE !!! Anyone having same issues ?!
#2 Posted : 19 March 2015 08:08:42(UTC)
Rumours say there will be revised revised turnout motors available in April.
There are many threads about failing Märklin turnout motors and how they can be bridged for digital operation.
Online RayF
#3 Posted : 19 March 2015 09:48:59(UTC)
You haven't said what type of track you are using, but I am assuming it is C track as this seems to have the worst of the problems with turnout motors.
Seems to be a bit of a hit and miss affair with individual motors. I have some which work strongly in both directions and have never failed to operate in over ten years of use. Some others always work well in one direction and don't work so well in the other. None of my motors have ever failed completely. If it stops working I spray it with WD40 and leave it overnight to soak into the contact switches, then it works fine again for a few weeks.
There is a modification that can be made to bridge the connection for the micro switches so that the motors don't cut off at the end of travel. This solves the problem, but one must be careful not to leave the motor activated continuously as it will overheat and burn out the coil.
When you say "I keep having to replace my switch motors evry 2 hours of use" do you mean that every motor on your layout fails after using the layout for two hours? This is unlikely, but if true would indicate a problem unrelated to the motors themselves.
If you mean that individual motors fail after a cumulative operation time of two hours then that is a lot of operation for a turnout motor, assuming that a motor activates for about 1 second per operation it means the motor has been energised 7200 times.
Perhaps if you phrase your problem more precisely we can give better advice?
Offline siroljuk
#4 Posted : 19 March 2015 10:13:28(UTC)
siroljuk
I have had also issues like this in my layout. The older one 74490 and new one 74491 have the same problem. The only working way is to solder microswitch contacts to gether and hereby bypass the possibility to avoid burning the motor. If you do soldering you have to be sure that for example you don´t give too much time for turnout in your keyboard- and memory settings.
I have managed to burn my three-way turnout decoder with soldering contacts and giving too log time for turning. Threeway turnout mechanism might be sticky when it gets older.
By the way, have anyone any idea how to clean and make mechanism easy to swicth in three-way turnout. Putting oil into it is not a good idea.
Has anyone tried to use Viessmann Article number 4558 Point motor for Märklin (Turnout Mechanism). I´m just thinking to oder one and try it.
See you
Jukka
Offline saetta
#5 Posted : 19 March 2015 14:40:10(UTC)
saetta
Hi Gentlemen,
Sorry for being so vague...it was frustration ! Yes I am using C track, and by 2 hours, I really meant , I usually play at least an hour a day and some switches have NEVER failed( abt 14) the other 20% tend to fail after a couple of months of play...Maybe 50 to a hundred commands. I don't think there is anything wrong with the set up, since some of them have worked flawlessly for 2 years.
I have been a Marklin addict ( with my 20 year sabbatical) since I was 9 years old (1959) and have always admired their quality durability and CHARM. I have never wandered to competing brands. It seems that this switch problem is endemic ..it was worse in prev model motors. All I have now is 91 and they seem to be marginally better ..but that's not good enough as far as I am concerned. This is supposed to be the Mercedes of German HO and I (think) should not have to rig this items to make them work. I am also mechanically inept...that why I buy premium and these switches are hardly that. I have had 2 in the last week that are going one way only and one failed completely, the other 14 have been working fine for a long time. I am really hoping that the rumor for a revised turn out motor is true.
It was great to get such a rapid response from fellow "marklinists"
thanks 2 users liked this useful post by saetta
Offline waorb
#6 Posted : 19 March 2015 14:55:42(UTC)
waorb
Brazil
Hello Mike.
Did you try to soldering one motor as described previously? For 'out-of-warranty' items it's a good solution to spare time&money.
Today, a new revised motor it's just a rumor...
Walter
Online RayF
#7 Posted : 19 March 2015 16:32:45(UTC)
Hi Gentlemen,
As I mentioned before, for the ones that only work one way you can try a squirt of WD40 or similar. It seems to get them to work again, at least for a while.
Hopefully Marklin will come up with a more bulletproof motor soon.
Offline Joseph Meiring
#8 Posted : 19 March 2015 18:56:08(UTC)
Joseph Meiring
'Has anyone read Tom's "signature"? .... a quote from the Marklin New Items brochure... :
"In all of the gauges, we particularly emphasize a high level of quality, the best possible fidelity to the prototype, and absolute precision. You will see that in all of our products." (from Märklin New Items Brochure 2015, page 1) ROFLBTCUTS!
Well I for one, and many, many others on this forum, do NOT see the quality and precision in this product, 74490/1!!
It is simply disgusting that a modern Marklin product can be SO appallingly unreliable in this day and age.
And M knows this only too well - witness the fact that they replace my faulty switches without even wanting the faulty ones in return!
And once, when I complained of one faulty switch, they sent me two in return.....
Tom, I pray the rumour is more than just a rumour......
From a thoroughly disillusioned and saddened Marklin fan of 55years.....
Joe
Offline saetta
#9 Posted : 19 March 2015 20:25:39(UTC)
saetta
My sentiments exactly !!
thanks 1 user liked this useful post by saetta
m84 and switches (Digital)
by TashTrain 30/01/2024 10:51:17(UTC)
New 38440 GE ES44AC stops on metal M double slip switches 5207, 5128 (H0-scale)
by Bill L 10/01/2024 21:19:20(UTC)
K track, ski pick up shoe shorts out system over switches? (Model railroad wiring)
by mattj70 18/08/2023 03:55:24(UTC)
Track And Switches In Particular (Small scale)
by Artologic 03/07/2023 14:52:40(UTC)
Rocrail Connection - M83 and Switches (H0-scale)
by Eddie7979 30/04/2023 09:11:08(UTC)
magnetic micro switches (General MRR)
by marklinist5999 24/05/2022 00:14:37(UTC)
Centre Rail Slider (and Switches/Crossings) (H0-scale)
by mike c 04/04/2022 19:06:21(UTC)
C=track electric double sleek switches (H0-scale)
by river6109 31/03/2022 20:32:02(UTC)
Ballasting and colorizing model tracks and switches (Model railroad photography)
by CVI 08/03/2022 11:57:14(UTC)
k83 (6083) decoder for K track switches tutorial (Digital)
by Fireguy911 02/02/2022 00:17:19(UTC)
Extra power for switches while using ESU Ecos? (Digital)
by IBtrain 09/10/2021 08:39:04(UTC)
K track switches and crossovers (General MRR)
by eurotrain 10/09/2021 16:29:31(UTC)
Connecting slip switches (H0-scale)
by Mr. Ron 11/08/2021 00:05:12(UTC)
640 keyboard used for analog switches??? (Digital)
by Keyser 25/06/2021 04:20:35(UTC)
3060 lights and switches (H0-scale)
by BenP 06/04/2021 02:44:35(UTC)
Marklin Switches/turnouts/points - contact cleaning (Small scale)
by Poor Skeleton 17/10/2020 20:42:30(UTC)
switches with digitals decoder (Digital)
by Garoux 16/08/2020 12:08:06(UTC)
cables networksimplified for switches (General MRR)
by Garoux 29/07/2020 09:58:54(UTC)
Day to Day Track Maintenance: Part 2: Switches and Crossings (1952) (Training and Instructional)
by ShannonN 26/06/2020 20:59:18(UTC)
Switches & Solenoids Question (H0-scale)
by Roland 19/05/2020 23:10:29(UTC)
Using a Transformer and 7210 Switches rather than Decoders on each turnouts. (H0-scale)
by Richard Joint 07/01/2020 03:33:52(UTC)
Startup gymnastics for switches with CS3? (Digital)
by jonas_sthlm 28/12/2019 12:04:50(UTC)
Marklin 74491 and limit switches (General MRR)
by Thewolf 13/11/2019 18:08:01(UTC)
Wiring a 3900 / 3800 M track w/ switches & semaphore lights (Model railroad wiring)
by edmund36 24/10/2019 23:00:15(UTC)
Usingswitches digitally (Digital)
by ocram63_uk 21/07/2019 23:16:57(UTC)
K-track switches (points) - changes over time (H0-scale)
by Spokanesteve 20/06/2019 03:24:03(UTC)
Motors for switches and switch decoders (General MRR)
by ocram63_uk 25/11/2018 10:18:25(UTC)
Finding new wheels for old E10 that short-circuits in hi-speed switches (H0-scale)
by johnpatrickwack 31/10/2018 12:45:34(UTC)
pickup shoe slider with hole short circuit on slender K switches (H0-scale)
by applor 23/10/2018 00:12:41(UTC)
Older Marklin track & switches (H0-scale)
by rhschulz2000 25/06/2018 04:10:41(UTC)
M Track Switches (H0-scale)
by sjbartels 23/02/2018 21:47:46(UTC)
Max Number Of Switches/Lights On One 32a Transformer ? (Model railroad wiring)
by Trigster 29/12/2017 01:25:27(UTC)
turnout mechanism in K track switches (H0-scale)
by applor 14/08/2017 00:48:11(UTC)
Bumpy Reed Switches? (H0-scale)
by Jabez 27/03/2017 23:50:24(UTC)
M-track switches and curved track question (H0-scale)
by AtlanticMan 19/03/2017 01:26:46(UTC)
Railbus 3016 shorting out on K track switches (H0-scale)
by louisbuddy 24/02/2017 00:00:47(UTC)
MS2 function buttons switches position (Digital)
by MaerklinLife 28/11/2016 06:28:34(UTC)
How many reed switches for train position feed back (Digital)
by Gregzim 09/03/2016 13:00:45(UTC)
TC (Gold) and turnout position control using end switches (Digital)
by blid 19/02/2016 11:22:30(UTC)
control unit 6021 DIP switches (Digital)
by freire 18/09/2015 16:02:27(UTC)
Digital switches (Digital)
by Cargodog 21/03/2015 22:35:29(UTC)
Life cycle length of M-rail switches? (H0-scale)
by Martin T 01/03/2015 16:18:08(UTC)
7045 vs. 7245 universal remote switches (H0-scale)
by yorckmf 03/02/2015 08:10:37(UTC)
Marklin 8816/8112 struggles to get through switches (Small scale)
by Artologic 05/11/2014 23:24:06(UTC)
Problem with Marklin M track switches (H0-scale)
by jimwallace1652 22/09/2014 00:11:24(UTC)
Connecting switches to normal track (Small scale)
by Carim 16/09/2014 09:33:44(UTC)
K Track points/switches. (H0-scale)
by Tom Jessop 14/08/2014 11:54:55(UTC)
Howdo I modify Marklin K-Track Switches for two-rail use? (Model railroad wiring)
by BruceS 27/07/2014 03:27:39(UTC)
Help with Reed Switches (General MRR)
by aos 31/12/2013 17:43:58(UTC)
CS2 - Feeding switches from progamming output (Digital)
by Martin T 06/11/2013 21:56:34(UTC)
This page was generated in 0.525 seconds.
