Offline Drongo
#1 Posted : 23 September 2014 11:40:50(UTC)
Drongo
I have this particular turnout that is giving me some grief. Cursing Cursing
The components are - C track 24672; decoder 74460 and motor 74491.
Here's the problem. If I connect the turnout to the programming track it works - no problem. When I connect it to the layout it only works very occasionally. I've checked the voltage for both programming track and layout with both showing about 14v. I've tested the turnouts located nearby, and some are actually connected to this one, and they all work.
Does someone have any ideas or suggestions?
Greg
Offline Drongo
#2 Posted : 23 September 2014 12:35:37(UTC)
Drongo
I've done some more investigating and found that the turnout has an insulating tab on the longer arm of the turnout. This tab is for TrainContoller and isolated the s88 in the block. I connected the turnout to the programming track on the arm and the motor didn't work. I then connected the turnout on the common arm and it worked. I removed the tab and connected to the longer arm and it worked. Therefore, the red tab is causing the problem. However, the red tab is required for the s88 contact.
How do I overcome this situation?
Greg
Drongo attached the following image(s):
Offline Drongo
#3 Posted : 23 September 2014 12:56:31(UTC)
Drongo
The obvious thing to do, is to remove the red tab and move it to the next piece of track. I did this and the turnout now works. The only thing I have to do is to adjust the braking length in the block.
I know no-one assisted me, but just being able to mention this on the forum enabled me to think about the problem. Thanks Juhan for the forum. Love Love Love
Greg
#4 Posted : 23 September 2014 13:00:20(UTC)
Hi Greg,
You seem to be isolating yourself out of a good ground contact for the turnout motor. Try connecting the motor to a nearby track instead of this one. You might need to extend the cable.
Offline Drongo
#5 Posted : 23 September 2014 14:52:25(UTC)
Drongo
Hi Greg,
Thanks Ray. I didn't think of this - I'll give it ago tomorrow.
Greg
Offline blid
#6 Posted : 23 September 2014 16:46:54(UTC)
blid
Place the turnout as is where you want it. Then try a ground cable to one of the rails of the turnout. If that helps, give the turnout a permanent ground cable.
Bjorn
Use of M-turnout motors in C-turnouts (General MRR)
by gimo49 20/01/2024 12:27:07(UTC)
Marklin turnout motors (H0-scale)
by David Dewar 03/01/2023 13:31:11(UTC)
Turnout motors (Digital)
by David Dewar 24/04/2020 21:15:42(UTC)
is 12V DC good enough to switch K-track turnout motors? (Model railroad wiring)
by DaleSchultz 30/12/2019 04:13:21(UTC)
Screw for turnout motors (General MRR)
by Hics 22/11/2019 14:01:26(UTC)
Turnout motor 74491 operation (Digital)
by michelvr 05/06/2019 18:17:04(UTC)
Marklin C-Track Turnout motor 74491 (Model railroad wiring)
by michelvr 06/06/2017 16:50:09(UTC)
Turnout motors - anyone familiar with mtb MT1 (Digital)
by Minok 30/11/2016 01:01:28(UTC)
Turnout Motor Wires redux (H0-scale)
by Jabez 15/11/2016 22:58:21(UTC)
Viessmann Turnout motors and decoders (Digital)
by nitramretep 25/10/2015 23:18:17(UTC)
C Track Turnout motor with relay control (Digital)
by Profpetrof 15/04/2015 13:14:20(UTC)
New generation turnout motors from Marklin! (Digital)
by Joseph Meiring 07/04/2015 15:48:53(UTC)
Your experience of K track turnout motors for digital operation (H0-scale)
by PeFu 01/04/2015 08:33:36(UTC)
switching a turnout motor (Small scale)
by Rocca 15/12/2014 20:23:03(UTC)
Viessmann turnout motor + Märklin K83 (Digital)
by flashwebb 29/08/2014 19:37:34(UTC)
Help - Need C-Track Turnout motor wires (Model railroad wiring)
by mkbkiwi 11/06/2014 09:34:32(UTC)
CS2 and Viessmann turnout motor feedback (Digital)
by blid 29/10/2013 14:51:40(UTC)
Problems with Märklin 74490 turnout motors (Digital)
by Janne75 17/06/2013 23:50:16(UTC)
Repairing Turnout Motors 74990 (Digital)
by Drongo 15/06/2013 09:27:48(UTC)
Viessmann 4554 Turnout Motor (General MRR)
by poppa-7 05/02/2013 04:16:20(UTC)
Tam Valley Depot-turnout motor control (Digital)
by Lollo 18/04/2012 10:24:10(UTC)
Viessmann 4554 Turnout Motor & Decoder (General MRR)
by poppa-7 08/04/2012 07:50:01(UTC)
K turnout motors - motor mounting options? (General MRR)
by BrandonVA 20/02/2012 16:03:56(UTC)
Turnout motor on a manual turn out for K track. (General MRR)
by Kodiak 21/01/2011 03:14:05(UTC)
Stuck turnout motor switch (General MRR)
by dntower85 30/11/2010 17:32:10(UTC)
Viessmann 4554 Digital Turnout Motor Review (Digital components and Software reviews)
by plavnostruev 10/02/2010 19:50:52(UTC)
74490 turnout motor problem (H0-scale)
by efel 08/11/2009 12:10:04(UTC)
Alternative turnout motors and decoders (Digital)
by DamonKelly 21/07/2009 17:19:46(UTC)
74490 Turnout Motor Reliability (H0-scale)
by Roger E 31/08/2008 15:33:43(UTC)
Viessmann Integrated Turnout Motor/Decoder (Digital)
by mascagni 05/03/2008 21:43:43(UTC)
Viessmann turnout motor 4554 (Digital)
Belarus Armando 14/02/2008 20:47:57(UTC)
C-Track Turnout Motors Buzzing (74490) (H0-scale)
by Caplin 17/12/2007 22:51:01(UTC)
74490 Turnout motor dead (H0-scale)
by efel 29/03/2007 13:39:50(UTC)
C-track turnout motor installation problem (H0-scale)
by perz 22/03/2007 22:48:02(UTC)
Veissman 4554 Turnout Motor / Decoder (Digital)
by Frostie 13/07/2006 05:37:40(UTC)
"Slow acting" turnout motors (H0-scale)
by rschaffr 15/12/2003 20:55:52(UTC)
Re: Turnout motors in C Track (H0-scale)
by Tahoetom 18/04/2002 02:18:18(UTC)
This page was generated in 0.536 seconds.
