Offline Rolando
#1 Posted : 24 August 2022 22:48:55(UTC)
Rolando
Is it possible to adjust the CV5 (max speed) on a MM2 dekoder with a Märklin CS2 ??
If yes , how do you do it ? Because now the value is grey in the configuration of the train and not possible to adjust. I can not see , how I can reach the CV's .
#2 Posted : 25 August 2022 00:52:17(UTC)
See my answer in your other thread.
[edit]
But in addition to what I wrote over there, I think you can only do what you want on the programming track, not on the main line.
[/edit]
Offline Rolando
#3 Posted : 25 August 2022 07:19:59(UTC)
Rolando
Hi again,
Actually, we are working with it on a programming track. But since the figures of min and max speed have a grey colour character, we can not edit them. The thing is to find a way to do it......
Do you have a CS2 by yourself.?
Regards. Roland
#4 Posted : 25 August 2022 14:12:58(UTC)
Hi Roland
The CS2 and CS3 have a presentation screen to adjust parameters on locos.
Depending on the decoder type, some parameters a greyed to indicate the specific adjutment is not possible / not available.
So the workaround is to change the decoders. I know you probably don't like it (we don't either) but there has been so many changes since the first decoders in 1985 with discreete components soldered vertically and the latest decoders with sound, 8 outputs, 2 inputs, that on some locos I changed the decoder 2 times already.
Here is the kind of slow speed you could get already in 2012: MFX, normal DC Märklin motor "Coffee grinder")
#5 Posted : 25 August 2022 20:13:34(UTC)
If yes , how do you do it?
It can be done for some decoders, but not for others.
And you must choose the correct decoder type in the CS2 loco settings.
Offline mvd71
#6 Posted : 25 August 2022 22:17:59(UTC)
What decoder do you have? If it is the mm2 decoder 60902 or equivalent the max speed and the acceleration/deceleration is set via potentiometers on the decoder itself, not via the controller.
#7 Posted : 26 August 2022 01:00:47(UTC)
As I mentioned in the post i linked to in post 2 in this thread, this is the same also for any of the 6090x decoders, i.e. also 6090 and 60901 (I can't remember if there is a 60903).
Rolando, post a photo of the decoder you are trying to adjust - i.e. take the body off the loco and inspect just what model of decoder it is. Until you do that we are all fishing in the dark. The decoder could have been changed from what was originally fitted, so having the catalogue number of the loco may not be of help.
Offline Rolando
#8 Posted : 26 August 2022 06:55:36(UTC)
Rolando
Thank you for your friendly reply.
I Will do so today in the afternoon.
MY friend will bring it to me.
Regards Roland
Offline Rolando
#9 Posted : 26 August 2022 12:06:01(UTC)
Rolando
Hi , again
My friend did not show up , so I can not send any picture today.
I will send it later
Roland
Offline Rolando
#10 Posted : 26 August 2022 13:43:44(UTC)
Rolando
My friend did nor show up today so I will send a photo later
regards Roland
#11 Posted : 27 August 2022 13:35:27(UTC)
Most people write "6090" for the 6090 decoder (no fx) and "6090x" for the newer fx decoders with DIP switches.
60901, 60902, 60903, and 60904 all used the same decoder, but came with different motor parts or none at all. The 60905 was a different decoder for coreless motos.
Programmable MM decoders include ESU OEM decoders and the 60760 family of decoders.
#12 Posted : 27 August 2022 17:18:54(UTC)
Rolando sent me this photo of the decoder, which definitely has two potentiometers on it.
I'm not familiar enough with these, can anyone tell which pot is the speed, and which the momentum?
#13 Posted : 27 August 2022 17:51:46(UTC)
There is a simple method to know which is which
- turn the first one them fully counterclockwise
- turn the second one them fully clockwise
If the loco goes slowly then the first one is the speed and the second one the inertia
Online bph
#14 Posted : 27 August 2022 18:06:56(UTC)
#15 Posted : 28 August 2022 00:52:08(UTC)
Good spot. And as an added bonus it has shunting mode on f4.
Looking for MM, MM2 Mfx packets format (Digital)
by Papymouzot 15/10/2022 10:17:01(UTC)
Engine not responding to MM/MM2 packets (Digital)
by mgbeck 12/10/2020 01:34:50(UTC)
SBB 6/6 with MM2 not working on MS2 (Digital)
by berlinbagdad1907 17/05/2020 08:58:33(UTC)
What address do I send a faulty MM2 to? (Digital)
by danmarklinman 12/10/2018 11:17:18(UTC)
Can I not register loco 36082 with MM2 or DCC protocol??? (General MRR)
by vnangli 23/06/2016 04:35:15(UTC)
Mfx, DCC, MM2 protocol setting in MS2. (Digital)
by vnangli 17/05/2016 22:26:57(UTC)
MM2 with DCC and N gauge (Digital)
by danmarklinman 12/03/2016 15:20:46(UTC)
Developing MM2 (with DCC) Shield for Arduino (Digital)
by Yaasan 04/03/2014 11:38:12(UTC)
MM2 and MFX signals on track (Digital)
by walter__ 30/12/2013 17:25:46(UTC)
MM2 and mfx speed steps (Model railroad software)
by TouchCab 27/07/2013 14:27:46(UTC)
This page was generated in 0.526 seconds.
