Offline Zurky
#1 Posted : 03 December 2025 06:51:58(UTC)
Zurky
Hello everybody,
I have been running my T18 1 gauge loco for a couple of years with no problem, but now, a couple of the function do not work, and the rear light stay on all the time. Changing direction only make it flick, but stays on.
I am driving a Mylocosound card through relays, to get the sound, and I can now only activate 2 relays with the function keys (F3 and F4)
My question is, has anyone found a proper manual for that old 6905 decoder, especially, how to reset it to manufacturer set up? I can go into the cv, but they are all at the same value and cannot be changed separately!!!
So, I will appreciate very much if somebody can tell me how to reset that decoder and see if it fixes the problem.
Thanks a lot
Best Regards
Zurky
Oh yes, and I am using the Marklin Mobile station MS2
Offline applor
#2 Posted : 11 December 2025 10:57:06(UTC)
applor
I can't answer that question but sounds like the decoder is cactus. I have changed some 1 gauge over to a Loksound XL and can recommend.
Offline Zurky
#3 Posted : 17 December 2025 14:30:39(UTC)
Zurky
Thanks, I think you are right, but it does not look like a major problem, and I would have like to fix it.
I will have a look at the Loksound XL. I was also looking at the Massoth eMotion LS decoder.
#4 Posted : 17 December 2025 18:47:52(UTC)
You may find the current capabilities of the Loksound L are sufficient without going to the more expensive XL.
Vintage Marklin Decoder with dip switches (Digital)
by roundsaturn31 05/07/2024 01:52:35(UTC)
Marklin decoder replacement (H0-scale)
by StanN 11/11/2023 18:01:22(UTC)
Marklin Decoder mSD3 Sound Fade (Digital)
by Kiko 11/10/2023 02:12:38(UTC)
Marklin Decoders and JMRI (Model railroad software)
by Santa Fe Rly 05/09/2023 06:07:33(UTC)
Marklin decoder 60760 (Digital)
by ocram63_uk 28/01/2023 19:05:40(UTC)
programming Marklin decoder with Loksound programmer (Digital)
by kirkcampbell33 18/12/2022 17:14:02(UTC)
Marklin Decoder Manufacturer? (Digital)
by Rob11966 22/07/2022 13:52:43(UTC)
Issue with Marklin decoder and 8-pin connector (Digital)
by JDennis 05/02/2022 17:06:04(UTC)
Help in Setting CV values for Marklin decoder 60972 to handle Marklin braking module 72441/72442 (Digital)
by Bill L 08/12/2021 22:27:35(UTC)
Marklin decoder 6080 settings 8 dip switch decoder (General MRR)
by Christo Swanepoel 19/07/2021 12:12:02(UTC)
Power pack on marklin decoder (Digital)
by geir 10/05/2020 13:07:18(UTC)
Which Marklin decoder should I buy? (Digital)
by LongHairedDavid 21/01/2020 12:54:09(UTC)
Marklin Decoder m83, 60832, and external power supply (Digital)
by ocram63_uk 28/10/2019 09:15:30(UTC)
Questions about Marklin Decoders (Digital)
by anthpao 03/04/2019 12:34:30(UTC)
List of Marklin decoders and performance (Digital)
by Harryv40 23/08/2016 10:44:22(UTC)
Marklin Decoder Dip switch. (Digital)
by steventrain 08/10/2014 10:00:10(UTC)
Marklin Decoders with ESU Command Station (Digital)
by drbob01 21/11/2013 16:24:18(UTC)
Marklin decoder outputs (Digital)
by nunk 29/10/2013 01:02:22(UTC)
Marklin Decoder 60945 (Digital)
by miguel.nascimento.184 27/07/2012 18:01:35(UTC)
Marklin decoder and motor upgrade kits (Digital)
by RayF 16/03/2012 10:49:02(UTC)
New Marklin Decoders (Digital)
by James 12/03/2012 21:22:56(UTC)
How to load new sound files on a Marklin decoder (Digital)
by casdeop 06/03/2012 20:11:02(UTC)
New Marklin decoders in Shop... (News from Märklin and others)
by jeehring 18/12/2011 12:47:14(UTC)
Marklin decoders and Rocrail (Digital)
by James 06/05/2011 01:45:06(UTC)
Marklin Decoders for Marklin 34750 (Digital)
by Krokodileman 10/03/2011 02:37:28(UTC)
Question about Marklin decoders (Digital)
by wa6ld 17/03/2009 00:20:00(UTC)
Marklin Decoder Manufacturer (Digital)
by mvd71 24/10/2008 10:30:14(UTC)
Viessmann v Marklin Decoders & S88's (General MRR)
by dpg001 15/10/2008 01:10:44(UTC)
Build Marklin decoders on my own (Digital)
by dandrikop 10/01/2007 10:45:40(UTC)
by Bigdaddynz 14/10/2006 12:54:26(UTC)
Marklin Decoder Performance (Digital)
by moz 30/05/2006 16:30:47(UTC)
changing address of non-marklin decoder (Digital)
by jeehring 26/04/2006 21:56:02(UTC)
Marklin Decoder 60760 (New decoder 2005) (Digital)
by lvfocus 20/12/2005 03:18:47(UTC)
Marklin Decoder Wiring & Heat Shrink Tubing (Digital)
by voivode 12/01/2005 05:51:24(UTC)
Old marklin Decoder (Digital)
by franciscohg 23/09/2004 22:05:42(UTC)
This page was generated in 0.414 seconds.
