Offline moz
#1 Posted : 30 May 2006 16:30:47(UTC)
moz
Brief Overview:
Starting in Digital; conversion of first loko (3000); ordered ESU Lokpilot mfx; dealer send me Marklin decoder from latest upgrade set - he doesn't know the part number of the decoder and there's nothing printed on it. I find out that it's not mfx; convert 3000 loko with hamo magnet only and test it with said decoder.
As I've read before the low speeds may be a bit jerky and sure enough they are.
I connected my Fluke scope meter to the motor signal and I see the following:
The important point here is the frequency of only 259Hz!
Now when I extend the time scale to see a larger time slice I get this:
Each of the grey blips you see occuring every 50ms is a bunch of pulses as seen in the first graph. It also reveals that sometimes it misses a set and the pulse groups are therefore 100ms apart.
No wonder this thing is jerky.[xx(]
One more test:
I disconnected the motor and ran the decoder without load on the output and the waveform was nice and regular - this leads me to believe that the "Lastenregler" (Load Control) feature which is trying to keep a constant speed no matter what the load is, is responsible for these variations. Maybe tuning the CV's I could get this problem sorted out - if only I had documentation on the CV's of this decoder! - and my LokProgrammer[:(]
Reading the ESU LokPilot mfx manual I can see that it operates at 40kHz, not the 250Hz I see with this unit.
Has anyone checked the output of other decoders to see what the ouput is doing?
Remember that a lone amateur built the Ark whereas a large group of professionals built the Titanic
My website: http://www.bejsta.com/model_railway/
Offline SRB
#2 Posted : 31 May 2006 00:40:22(UTC)
SRB
I'm sorry but I don't follow you. What is your problem? Which decoder do you have equipped the 3000 with then?
I can't see your pics.
Stig
IB; C-track; DSB and SBB ep. III-V
Offline moz
#3 Posted : 31 May 2006 14:16:42(UTC)
moz
If anyone else has trouble seeing the pictures please leave a post in this topic.
The problem:
The loko runs jerky at low speed.
I (and the dealer) can't identify the decoder, there is no number on it. All I know is that it came from Marklin.
My question:
Do all decoders suffer from this problem or is it onle the Marklin decoder(s)?
This is really a question for the techno gurus of this forum which can read the included graphs.
Online xxup
#4 Posted : 31 May 2006 14:32:38(UTC)
I can't see the pictures either and I am a lot closer...
http://boaz.bejsta.com/slow_speed1.bmp "unable to connect to" boaz.bejesta.com error
Offline rugauger
#5 Posted : 31 May 2006 16:27:05(UTC)
rugauger
No pictures for me either... But what you are describing here is very interesting for me, because I believe the problem may be similar (or even the same?) to the one I posted here:
https://www.marklin-users.net/fo...ault.aspx?g=posts&t=4645
My guess would be that some (cheap) load-regulated Marklin decoders (e.g. the one from the pre-Christmas DCM conversion set, or the on-track programmable one installed in some Feuerwehr starter set locos) only work properly with the high-efficiency 5-pol motors; anything else (e.g. HAMO) and they get upset, angry and generally unwilling to play nicely.
Suggestion: try an Uhlenbrock or ESU decoder...
Richard
Offline McLae
#6 Posted : 31 May 2006 19:24:13(UTC)
McLae
If you put on a Hammo magnet, you might as well swap motor shield and rotor to get 5-pole. (6090X parts kit)
The magnet by itself is of no use. The old (3-pole) rotors are wired to work with a e-magnet that reverses polarity. HAMMO magnets are permanent, and the 6090x rotors are wired to work in a constant magnetic field.wink
Sort of like puting a 2-rail Lok on C-track and asking "Why does it not run?".biggrin
The McLae
Offline SRB
#7 Posted : 01 June 2006 01:30:48(UTC)
SRB
I will go for an ESU or Uhlenbrock decoder too. It's very difficult to work with a decoder you don’t know what is. And upgrade the motor to 5-pole makes it run just fine.
Offline rugauger
#8 Posted : 01 June 2006 12:02:54(UTC)
rugauger
[size=1" face="Verdana" id="quote]quote:Originally posted by McLae
<br />If you put on a Hammo magnet, you might as well swap motor shield and rotor to get 5-pole. (6090X parts kit)
I'm sorry, but I have to disagree:
1) I believe the magnets that come with the 6090x kits to be different to the HAMO ones. So you can't just swap the motor shield and put in a 5-pole rotor. You will have to change the magnet as well.
2) The magnet itself IS of use - the rotor and motor shield for HAMO DC motors are exactly the same as those in the AC versions, and the rotor wiring has absolutely nothing to do with it. All you do by replacing the field coil with the magnet is turn the AC motor into a DC one. And that's all that the 6090x motors are, too - DC motors. Admittedly, smooth ones wink[:p]
3) HAMO + ESU or HAMO + UB decoder have been proven to work perfectly well together, and I myself have done this type of conversion with no problems. However, I will admit that you have to get the choice of decoder right. The aforementioned ones are safe bets as Stig quite rightly says.
Richard
Offline hmsfix
#9 Posted : 01 June 2006 17:06:56(UTC)
hmsfix
Hi moz,
Can't see your scope pics either. Your findings might have to do with the jerky behaviour of your lok. Perhaps the load regulation of the decoder does not work correctly with the 3-pole-DCM + HAMO magnet.
I have tested the motor voltage of some of my loks with an oscilloscope, too. Always found a very clean signal for older 6090x decoders (100 Hz pulse frequency) as well as for ESU/MFX decoders with 32 or 40 kHz pulse frequency.
Hans Martin
Offline hqstu
#10 Posted : 03 June 2006 23:48:41(UTC)
hqstu
I've just converted a 3000 lok with full 60903 motor parts, and a 6090 decoder. The lok tends to be a bit noisy and can start off with a bit of a jerk, but I think this is more a function of a less than perfect gear train than anything else. Perhaps a 60902 decoder will work better, or a lokpilot... The 6090 decoder only just fits.
Stuart
This page was generated in 0.810 seconds.
