Offline danmarklinman
#1 Posted : 18 November 2025 16:33:04(UTC)
danmarklinman
Is the Faller AMS system AC? Also is there a list or track diagram book that went with it?
I’ve just bought myself the container terminal set with truck and it’ appeals to me to add it to my layout and removing the modern version as the batteries fail on them.
I just want to plug and play 👍☺️
Wiking model car Fan
Instagram: marklin1978
Wiking fan
Online JohnjeanB
#2 Posted : 18 November 2025 23:21:30(UTC)
Hi Dan
Faller AMS is basically a slot car system that uses DC in a simple arrangement Transfo, Rectifier, speed controller and track feeder
There is also a trick to control two cars independently on the same slot
In that case the trick is to cable TWO controllers with a rectifier diode in series (one in one direction and the other in the other direction.
Furthermore a special ski (slider with a rectfier) on one car to be installed on the left and on the other car, on the right.
Below is a copy of the pages in the 1969 catalog, regarding power, control, etc
When those components are not available you can:
- make a contact track by soldering wires underneath a track
- use a 14 VAC transformer 15 VA is ok
- use a rheostat instead of the controller (a DC train transfo with controller may do the job
Things I forgot to mention
- If the car runs in the wrong direction, either swap the cables after the rectifier or change the rectifier selenium cell
- since the tracks are easility corroded, a simple sheet metal plate, used to clean the contact tracks does the job in a great way.
thanks 6 users liked this useful post by JohnjeanB
Offline kweekalot
#3 Posted : 19 November 2025 22:45:59(UTC)
kweekalot
thanks 3 users liked this useful post by kweekalot
Offline kweekalot
#4 Posted : 19 November 2025 22:52:16(UTC)
kweekalot
You might also be interested in the Faller Contaner Terminal 402 thread here on the forum:
https://www.marklin-user...-Terminal-402#post380238
#5 Posted : 20 November 2025 13:15:40(UTC)
danmarklinman
So a normal DC controller can be used for two way traffic as long as you have two control knobs?
Are the double track sections joined electronically?
Wiking fan
Offline kweekalot
#6 Posted : 20 November 2025 17:57:22(UTC)
kweekalot
Yes
No, the two lanes are not connected.
#7 Posted : 20 November 2025 19:30:08(UTC)
danmarklinman
Yes
Excellent I will get myself a gauge Master double track transformer ☺️, I need some more track though. There’s not much in the container set.
Have you tried lifting Wiking containers with the crane?
Wiking fan
Offline kweekalot
#8 Posted : 20 November 2025 23:49:48(UTC)
kweekalot
No, I don't know much about the Wiking containers and I don't have Wiking containers.
Perhaps Steve (Cookee_nz) knows, he runs an AMS Facebook group an knows a lot about the Faller container terminal.
Marco
#9 Posted : 21 November 2025 10:16:00(UTC)
Yes
Actually, the two inside rails of each lane 'may' be connected electrically.
Some track feeder sections are wired this way with the inner rails being 'common' feed by the brown wire, and two different red wires for the outer of each lane
Also, the 'squeeze' track section has the two rails joined although I have seen some where a thin insulator has been placed between them.
Note the bottom red wire in this image has become disconnected from the outer rail
Another feeder method using press-fit contacts
Early wiring schematic
The 4726 squeeze section. This one has insulation between the two inner rails but it would pay to check
thanks 6 users liked this useful post by cookee_nz
#10 Posted : 21 November 2025 10:33:18(UTC)
Marco
danmarklinman Offline
re the Container Terminal. Be aware there is a very common problem with the driver gears becoming split. I wrote about it here...
https://www.marklin-user...02-containerterminal.htm
It's actually such a problem that I've decided not to incorporate the Terminal into my module for our clubs' modular layout activity.
I have two Container Terminals, and I've looked at various ways to get around the issue without success.
There is a company in Poland that can make the gears, but after initial communication they simply stopped responding to me and that killed any remaining enthusiasm.
https://shop.kkpmo.com/index.php
There are probably other sources of the gears but it's not on my to-do list at present
Can I suggest you review this thread on the FAM, LOTS of good info including both version of the squeeze and the container gears
https://www.altemodellba...Faller-AMS-Reloaded.html
Obviously it's in German but auto-translate should work. If you can't see the images, then I'm afraid you'll need to join the forum, it's easy to join, some topics have the content restricted to members only. Privacy I guess.
I saw a comment that someone in Germany is apparently also making 3D gear sets. If you find a solution, or a source to supply, let me know, I'll add on to your order to get mine working. Might give me renewed interest.
I can't answer about other brands of containers. I know the Märklin containers are a different size, the Faller ones are slightly over-scale so I suspect the Wiking ones may be slightly smaller.
Hope this all helps.
Edited by user 21 November 2025 23:49:04(UTC)  | Reason: Not specified
Offline osoraku
#11 Posted : 21 November 2025 17:57:57(UTC)
osoraku
Dear All -
Regarding repair of split plastic gears, here are two techniques that I've seen reported:
Geoff Bunza's string-wrap recipe and another heat shrink solution.
Not yet having had the problem, no guarantees on either of their efficacies.
Osoraku
thanks 4 users liked this useful post by osoraku
#12 Posted : 23 November 2025 08:40:39(UTC)
danmarklinman
Thanks guys, appreciate it. My container crane is still in kit form. So no split gears yet. I might try and sauce some metal gears any way. When I eventually build the kit. I have now done some extensive research on the ams system. And I’ve also done some work on my current car system. Part of my issue with fallers current system is the battery’s supplied don’t actually last more than a couple of years it seems before they start to not take a charge. So I’m now having a go at doing a budget diy car system vehicles to see if it works, before I take more of a plunge with AMS which as it turns out has it’s own issues.
Fallers current road system, It works fine. As long as you ok with recharging and also replacing the batteries. I just want to switch the layout on at the plug and go. But as it is with old toys, it may not be that straightforward.
Here the current layout system.
https://youtube.com/shor...Qjg4?si=ceh76g5KqfmAfp6Y
Wiking fan
#13 Posted : 26 November 2025 10:14:07(UTC)
I also had some of the Car System vehicles, but the batteries leaked, and while they are repairable, a lot of hassle which I just can't be bothered with.
Split gears in the Container gear-box are not from usage, they simply split over time due to the stress of the axle forcing the smaller hole outward.
If yours are not split, that would be unusual, but not unheard of although I'd recommend running the motors to test, you'll soon know because they will snag every revolution.
Faller AMS 4003 City (1968/69). (Faller collectibles and other vintage accessories)
by kweekalot 08/03/2023 15:40:04(UTC)
Faller ams container terminal 402 (Faller collectibles and other vintage accessories)
by danmarklinman 01/06/2020 13:48:07(UTC)
Faller ams chassis size (Faller collectibles and other vintage accessories)
by danmarklinman 07/11/2019 14:59:38(UTC)
Faller AMS and M-Track awesome vintage layout (Faller collectibles and other vintage accessories)
by cookee_nz 28/01/2019 22:47:25(UTC)
My Faller AMS addiction (Faller collectibles and other vintage accessories)
by lmedberry 17/05/2015 08:19:55(UTC)
Faller AMS Nürburgring Classic Race (Faller collectibles and other vintage accessories)
by hellwigm 13/11/2014 16:43:12(UTC)
Another rarity - Faller AMS 8mm Film 831 Nürburgring (Faller collectibles and other vintage accessories)
by cookee_nz 16/09/2013 11:19:26(UTC)
Faller AMS B-4907 BP grandstand. (Faller collectibles and other vintage accessories)
by kweekalot 26/04/2013 15:38:59(UTC)
Faller AMS 50 years anniversary (Faller collectibles and other vintage accessories)
by Mats P 04/02/2013 21:15:57(UTC)
Faller AMS - what is the best way to start? (Faller collectibles and other vintage accessories)
by Robyn Boyd 13/01/2013 02:14:49(UTC)
Faller AMS ADAC Raststätte B-4916 (Faller collectibles and other vintage accessories)
by kweekalot 22/12/2012 22:15:36(UTC)
Faller AMS Continental Tower B-4904 (Faller collectibles and other vintage accessories)
by kweekalot 21/12/2012 21:13:45(UTC)
Faller AMS on a billiards table (Great layouts I have seen...)
by kweekalot 11/11/2012 14:41:05(UTC)
Faller AMS SPORT HOTEL B-4921 (1963-69) (Faller collectibles and other vintage accessories)
by kweekalot 25/10/2012 18:30:25(UTC)
My Faller AMS purchases (Faller collectibles and other vintage accessories)
by kweekalot 23/10/2012 11:53:45(UTC)
1965 Faller AMS VW Van (Faller collectibles and other vintage accessories)
by kweekalot 11/10/2012 16:57:52(UTC)
1964 Faller AMS starter pack 4000 + 4001 (Faller collectibles and other vintage accessories)
by kweekalot 09/10/2012 17:56:36(UTC)
Do you remember Faller AMS (General MRR)
by TrainIride 19/11/2010 22:27:53(UTC)
This page was generated in 0.610 seconds.
