7 Pages«<4567>
#251 Posted : 18 October 2023 02:14:18(UTC)
And a video about "Breemburg Hauptbahnhof" (= Big City Station on 1.35 sqm mentioned in the previous post #250):
Offline Jimmy Thompson
#252 Posted : 18 October 2023 11:44:41(UTC)
Jimmy Thompson
Your posts 250 and 351 reminds me of this from Faller Gleisbaupläne 840
p. s. as well as Post #201 on the previous page.
p. p. s. faller-ams.se link no longer works - removed references
Edited by user 06 November 2024 23:32:47(UTC)  | Reason: add postscript
Jimmy T
Dr Dirt's Rule #1 and
#253 Posted : 30 December 2023 22:15:17(UTC)
L-shape mind game on 2 x 2m with transition curves, maximum track elevation 18 cm, length of track 15.5 m
#254 Posted : 31 December 2023 05:53:40(UTC)
Hello Ak,
I like your last post #253, a very ingenious track plan indeed.
I may be missing something, but would it be possible to indicate the Zero elevation datum on that layout please?
Edit:
Don't worry I found it - the little markers alongside the track showing elevation - thank you.
I missed them until I clicked to enlarge the image.
#255 Posted : 31 December 2023 13:55:03(UTC)
Thank you Kimball. Even though you already detected the 0 elevation, I marked it in below image.The gradients can be chosen in such a way that they reinforce the impression of a mountain railway. The gradients could be harmonized and standardized at 3% to extend the 0 elevation range.
The absolute minimum in terms of elevation would be 8 cm height - see image below. Then there would also be room for crossovers to change the direction of travel. However, this would make the concept look less dramatic.
#256 Posted : 07 April 2024 11:52:11(UTC)
Two German brothers' H0 scale Model railroad under a billiard table
Photos with English narrative:
https://www.noch.com/new...nder-the-billiard-table/
Video:
#257 Posted : 03 August 2024 16:46:29(UTC)
Dunno if I shared this before - one of my favourite designs:
Description:
"By eliminating virtually all trackage except a winding double-track main line, Robb Thomas, from Walkerton, Indiana USA, has managed to squeeze both a credible country scene and a bustling port metropolis into a 5x3ft (150x90cm) baseboard. The port is located in eastern Ohio on Lake Erie, and the countryside represents an Appalachian valley in Pennsylvania. A diagonal backdrop separates the two scenes on this N scale railroad."
Source with some photographs (scroll down) in this 2007 publication:
https://www.carendt.com/...special-mid-month-issue/
Offline rbw993
#258 Posted : 04 August 2024 13:30:41(UTC)
rbw993
Was this an inspiration for Density or just "great minds think alike"?
#259 Posted : 04 August 2024 13:48:20(UTC)
Well, I cannot speak for anybody else, but I consider myself a genius in my own mind.
Wink
#260 Posted : 04 August 2024 14:00:38(UTC)
Above N scale design transferred to H0 scale:
A ruling grade of 3% is feasible on an area of 4 x 8 feet (ca. 1.2 x 2.4 m) as well as a depressed harbor basin. Between the scenic divider and the harbor basin there is still space for sidings on the top level. Each loop measures 10 m in length, so 20 m track length in total. Theoretically, the footprint can be reduced to 1 x 2 m, but then there is no room for the harbor basin or rail curve easements.
Offline hermanvk
#261 Posted : 04 August 2024 15:53:25(UTC)
hermanvk
Amazing actually, that I also own the same four locs... even the set AND the panorama car..ThumpUp
Both electric ones.
I just learned how to have trains (same two of the video ) running on catenary..ThumpUp
thanks 6 users liked this useful post by hermanvk
Offline hermanvk
#262 Posted : 04 August 2024 17:32:12(UTC)
hermanvk
Both electric ones.
red_3021_img_2364.jpgred_3016_4018_img_2367.jpgred_3054_img_2360.jpgred_3036_img_2362.jpg
thanks 4 users liked this useful post by hermanvk
#263 Posted : 06 August 2024 19:13:35(UTC)
Please note that this is the track plan forum.
Hence another twisted "dogbone" track plan on a 186 x 106 cm footprint:
With a limited supply of land and at the same time high demand for MRR space, the only option is to go up.
R1 curves are preferably hidden in tunnels, ruling grade is 3%, total track length just under 20 m, height difference from bottom to top is 24 cm.
Offline rbw993
#264 Posted : 07 August 2024 02:31:11(UTC)
rbw993
Why stop here? How up can you go? Sorry, I've been drinking Cava with dinner.
Roger
thanks 3 users liked this useful post by rbw993
#265 Posted : 15 August 2024 20:05:24(UTC)
Well, one could cave in to reach four levels equalling an elevation of 32 cm on a 100 x 170 cm surface (when accepting a ruling grade of 4% and and the omitting of subtleties such as transition curves).Unsure
The lower return loop is inverted.
A valley with bridges would be ideal here, with scenery obscuring some trackage in the rear.
#266 Posted : 29 November 2024 19:41:03(UTC)
This NMRA description of a basic freight classification yard caught my attention. Amalgamating the NMRA scheme ...
... with an earlier twisted dogbone concept ...
... I came up with this 4x8 ft idea:
The proximity of a big city serves as a pretext for the dense trackwork and operations of various trains. For ease of operation and minimal fouling of the mainline, the yard operates in a one-way mode. Assuming that the small classification yard is located between two larger ones (yard A and yard B) explains this arrangement: Trains originate from the distant yard A and are then hauled to the distant yard B. Freight destined to yard A is turned around - out of sight - in yard B.
The layout allows to break up a long US type freight train and serve various industries, while a passenger train could serve a suburban station (the upper deck trackage is open for interpretation and adjustments). A round trip for a train traveling the entire dogbone route measures 20 m and the arrival/departure ("A/D") track can hold a 4 m long freight train. A yard switcher can be parked on the yard lead tail track. With right-hand traffic, the uphill gradients are 3% steep and downhill slopes up to 4%
Edited by user 30 November 2024 10:11:49(UTC)  | Reason: Not specified
Offline rbw993
#267 Posted : 01 December 2024 14:27:15(UTC)
rbw993
The world wants to know - are you going to build it?
Roger
thanks 4 users liked this useful post by rbw993
Offline Willem99
#268 Posted : 01 December 2024 15:05:16(UTC)
Willem99
Never in the history of Marklin have I seen so many tracks on such a small space with so few houses.
Or something like that.
Tim
thanks 5 users liked this useful post by Willem99
#269 Posted : 02 December 2024 15:33:35(UTC)
Roger
This can happen. It all depends on whether and how I manage to adapt the MRR collection to my hybrid living situation, namely whether I manage to transport the ATSF rolling stock and excess track inventory across several national borders. The aforementioned design would be suitable for ATSF, inspired by e.g. suburban Kansas City, Oklahoma City or Illinois City, I mean Chicago.
Offline rbw993
#270 Posted : 02 December 2024 23:16:03(UTC)
rbw993
I am looking forward to seeing it...If it happens.
#271 Posted : 10 January 2025 18:25:39(UTC)
For entertainment purposes, industrial switching on a simpler basis in the meantime (195 x 95 cm), curvy but no S-curves.
Offline rbw993
#272 Posted : 10 January 2025 18:30:05(UTC)
rbw993
Looks like what happened to my glasses once AK! I like how you worked that extra crossing in there. It makes use of an otherwise empty circle.
Roger
#273 Posted : 16 March 2025 12:47:25(UTC)
Another brainstorming product: A condensed pretzel with stub sidings inside one blob. With the help of the outer crossing outward and return journeys could be simulated. Concealing the inner pretzel would complete the illusion.
Offline Smudge
#274 Posted : 23 April 2025 09:26:00(UTC)
Smudge
I detected a really cool compact (100 x 160 cm) multi-level layout plan for M* C track. It is a single track main line complete with visible station and hidden shadow station (three tracks) on the ground level plus a branch line climbing up to a small terminus on level 3 - quite a long run for a short train. Visually very attractive. The main line level is easy to construct, while the branch line is more demanding. Still it is possible to play on the ground level while the upper level and landscape construction is still under way.
Source (with track library):
http://www.moba-trickkis...p;total=353&start=21
I built this one… need to finished this one.
https://youtu.be/rgDeMxi_DEg?si=Zc6xjnK5onL0M-LT
Screenshot 2025-04-23 at 5.22.34 PM.png (18,120kb) downloaded 36 time(s).Märklin HO Layout build
Smudge
Marklin Modellers of Sydney
thanks 2 users liked this useful post by Smudge
#275 Posted : 24 April 2025 12:15:54(UTC)
Nice !
I take the liberty of attaching a compressed version of your photo for simplified viewing.
I also enclose again the Mobatrickkiste track plan(s) for the uninitiated.
Edited by user 25 April 2025 11:37:14(UTC)  | Reason: Not specified
Offline madhu.gn.71
#276 Posted : 04 May 2025 14:01:54(UTC)
madhu.gn.71
India
Another idea which I find aesthetically appealing: Long twisted bi-level mainline run without a single turnout. The N-scale layout is supposed to support two PC monitors placed inside the two circles, respectively.
Alsterstreek, if I need to realise this using c tracks preferably with R1 curves, is there something you can help me with?
thanks 1 user liked this useful post by madhu.gn.71
#277 Posted : 04 May 2025 16:44:35(UTC)
Like that?
Overall track length 865 cm on a 169 x 94 cm surface, 3.5% incline/decline for 8 cm overpass clearance.
#278 Posted : 04 May 2025 16:46:07(UTC)
Track inventory:
4 x 24077
1 x 24094
25 x 24130
8 x 24172
3 x 24188
1 x 24206
1 x 24224
6 x 24230
Offline madhu.gn.71
#279 Posted : 04 May 2025 20:11:12(UTC)
madhu.gn.71
India
Thank you so much, Ak!! Much appreciated❤️.
For the next couple of years, I have space shortage for a 4*8 ft layout. I will realise this layout instead. I will split the gradient between the two levels. The size is just perfect for the space I have.
I will ensure not to keep the track parallel to the table edge this time.
thanks 3 users liked this useful post by madhu.gn.71
#280 Posted : 18 May 2025 14:21:51(UTC)
This impressive portable z scale layout with bridges, tunnels and gorges, built with lightweight materials, was once for sale in 2020 (asking price was CHF 1,200). It measured 160x 60cm horizontally. The double track line climbed 55 cm before descending again. According to the vendor, up to six trains could run at the same time and trains should be able to negotiate the gradients and curves without any problems.
Unfortunately no track plan available.
Edited by user 19 May 2025 08:07:55(UTC)  | Reason: Not specified
#281 Posted : 18 May 2025 17:16:51(UTC)
Jimmy Thompson
There is almost some Desmaigne Déjà vu going on here Woot ThumpUp
Jimmy T
Online kiwiAlan
#282 Posted : 18 May 2025 20:07:06(UTC)
Laugh Laugh Laugh
#283 Posted : 25 May 2025 18:35:04(UTC)
Elaborating on posts #271 & #273:
189 x 83 cm
#284 Posted : 25 May 2025 22:32:46(UTC)
Inspired by the 4 x 8 ft track plan no. 24 "Toronto, Hamilton & Detroit RR" in 101 Track Plans by Model Railroader Books, here on 199 x 117 cm instead; the gradients are between 3 and 4 %.
Edited by user 26 May 2025 21:51:49(UTC)  | Reason: Not specified
#285 Posted : 05 June 2025 13:12:24(UTC)
Actually, this allows for an Inglenook shunting puzzle - see track section marked in red.
And shifting one of the cross-overs creates a passing loop - see track section marked in red.
Offline rbw993
#286 Posted : 05 June 2025 20:02:27(UTC)
rbw993
Nice, but can you incorporate the Time Saver puzzle?
Roger
#287 Posted : 09 June 2025 21:20:59(UTC)
Roger
I can on 4 x 8 ft.
Inglenook classification yard is used to line up a train more favorably for upcoming tasks at Timesaver switching district. Inglenook is connected "upstream" of Timesaver so that everything runs more smoothly with the restrictions within Timesaver puzzle rules.
Offline rbw993
#288 Posted : 09 June 2025 21:34:27(UTC)
rbw993
Genius! I knew you would come up with a solution.
Roger
#289 Posted : 10 June 2025 00:13:14(UTC)
wow- that is a lot of layout and a lot of operating potential in 4x8!
thanks 4 users liked this useful post by 5HorizonsRR
#290 Posted : 08 August 2025 00:12:42(UTC)
In February 2015 forum member Warorb and I admired this little Z gauge gem in this thread: https://www.marklin-user...-unusual-Z-scale-layouts
I couldn't get the concept out of my head. That's why, after 10 years, I decided to try out how it might look in H0. Since it's an adventurous mountain railway, the radii can be tight, i.e. R1. On a rectangular 165x165 cm surface, with a track length of 18 m and a gradient of 3%, it could look like this. A spur here and there could serve as yard for industries and train meets.
Offline rbw993
#291 Posted : 08 August 2025 15:24:19(UTC)
rbw993
Pretzel Logic?
#292 Posted : 08 August 2025 15:35:58(UTC)
Pretzel Logic?
If there was a station somewhere along the line, it could be named "Point". Like that, it would be point-to-point operations.
#293 Posted : 08 August 2025 15:42:41(UTC)
Pretzel Logic?
Clean this mess up or we'll all end up in jail!LOL Maybe it's far beyond jail as of late?
#294 Posted : 25 August 2025 12:53:14(UTC)
Recent layout video in addition to my post #183 from December 6, 2018, about Jim Griffin's DRGW La Plata Division layout in H0 scale
#295 Posted : 30 August 2025 12:12:09(UTC)
Recent layout video in addition to my post #176 from December 25, 2017, about Eric Miller´s circular GPM&C Ry in H0 scale.
Offline analogmike
#296 Posted : 31 August 2025 13:20:45(UTC)
analogmike
I really like this style of mountain construction. It solves the problem of going strait up and still look good doing it without the use of brickwork or a crazy amount of retaining walls. It's almost prismic or crystaline. I know it's a reach but, are there any pics of this under construction??
Mikey
thanks 5 users liked this useful post by analogmike
#297 Posted : 31 August 2025 17:34:24(UTC)
I'm afraid that's all there is, and a Google image search yields no results.
#298 Posted : 01 September 2025 15:24:51(UTC)
I tried to recreate a Stummiforum track plan—which is no longer available there—faithfully to the original, which I presented 10 years ago in poor resolution in our thread The C track topic - ideas, uses, and innovations.
I find this 135 x 168 cm design interesting in relation to the above post #275. While the latter – actually a compact oval with a branch line – enables realistic point-to-point operation with a shadow station, the former “only” enables prototypical point-to-point operation, albeit with elegant route guidance in a very small space and still on one level, if you use a scenic divider. Alternatively, the S-shaped connecting track could be designed as a ramp to create the impression of a distance between the two stations on different levels.
#299 Posted : 17 November 2025 15:02:13(UTC)
Further to posts #274 & 275, I wondered how much of it - when condensed - would fit on a IKEA Lack table measuring just 118x78x45 cm? Please judge yourself:
#300 Posted : 24 November 2025 18:24:27(UTC)
Inspired by the track plan no. 35 "Denver & South Park RR" in 101 Track Plans by Model Railroader Books, 260 x 100 cm.
It seemed promising in the book, but I'm not convinced by the result.
Guest (4)
7 Pages«<4567>
This page was generated in 1.706 seconds.
