Offline Mille
#1 Posted : 08 March 2023 06:12:58(UTC)
Mille
My CS3 dont want to connect to VNC Viewer
It goes from a green label to red label in a second and says
Connection interrupted everytime i try start it
Has anyone any idea why or on explanation what i can do
Anor it?
thanks 1 user liked this useful post by Mille
#2 Posted : 08 March 2023 20:58:39(UTC)
Anor it?
Hej!
Have you tried to write IP adress in the column in the PC to test if you have direct connect to the CS3?
Offline Mille
#3 Posted : 09 March 2023 05:04:10(UTC)
Mille
I can do trackplans and cs3 answer
when i ping it
Its only connection with VNC Viewer that not work
Can it be firewall settings?
#4 Posted : 09 March 2023 06:31:15(UTC)
No i don’t think soo. Firewall are always necessary to protect your PC.
#5 Posted : 09 March 2023 09:23:37(UTC)
When Goofy say No then better check the firewall.
VNC uses a different port than ping, but it is a good sign that ping works.
Offline bph
#6 Posted : 09 March 2023 12:37:52(UTC)
has this worked earlier or is this the first time you try VNC?
if it's the first time, have you remembered to activate the CS3 screen server, in the web browser interface on the pc?
Edited by user 10 March 2023 11:07:13(UTC)  | Reason: Not specified
Offline Mille
#7 Posted : 09 March 2023 12:50:16(UTC)
Mille
I have try to use VNC sometimed, but no luck
so far
I have lastet upgrade and have tried with
two different routers and cables
I really need to get it work
#8 Posted : 09 March 2023 16:03:34(UTC)
Anor it?
Sorry if I mention something you already know
1a- connect your CS3 to your PC direct In this mode, you must give your CS3 an address like 192.168.xx.xx and use a CAT5 cable
1b- connect your CS3 to a router (DHCP mode)
2- Download VNC viewer
3- on VNC, select new connection and then in the VNC Server field, enter your CS3 IP address followed with :5900
In my case, my CS3 IP address is 192.168.0.23 and the VNC Viewer the VNC Server field is 192.168.0.23:5900
Then the image on your CS3 is displayed on your PC
NOTES:
- you can't make a screen copy of a VNC viewer screen but this is no problem.
- I have declared my CS3 address in my firewall "Windows defender" so as to not get data blocked by it when using Rocrail or VNC Viewer.
- EVEN if you use a router, it is best, once you got an address by the router, to switch , on the CS3, to manual mode. Why? To avoid unwanted address changes by DHCP that would prevent later VNC, Rocrail, etc to work.
Offline Mille
#9 Posted : 10 March 2023 05:43:45(UTC)
Mille
Thanks for that information
If i use static ip there is 3 more
fields to fill in, is that same Numbers
I get from my router when i use DHCP?
#10 Posted : 10 March 2023 10:53:34(UTC)
Default gateway and network mask should be the same as with DHCP.
Offline Mille
#11 Posted : 10 March 2023 11:05:19(UTC)
Mille
Ok Thanks
Offline bph
#12 Posted : 10 March 2023 11:06:38(UTC)
When you assign a fixed ip address it must be outside the address range your Router uses in the DHCP, but still quite close.
eg if your DHCP range is 192.168.3.10-50 then give the cs3 eg ip 192.168.3.55. otherwise, you would get ip conflicts sooner or later.
The second alternative is to use the router's DHCP to assign a reserved address to the CS3 (using the MAC adress)
E.G. on AUS routers this is found under advanced LAN settings, DHCP Server and is called "Manually Assigned IP around the DHCP list"
that means that you leave the DHCP settings in the sc3 in auto, and the DHCP Server gives the CS3 the same ip every time it starts up.
Have you remembered to activate the CS3 screen server, in the web browser interface on the pc?
Offline Mille
#13 Posted : 10 March 2023 11:11:32(UTC)
Mille
Thinkin of connect to pc
direct without router
problems with CS3 webserver since update 2.0.0(1) (Digital)
by phils2um 26/12/2019 05:54:38(UTC)
CS2 Update v4.1.2(3) : [ system(4.1.1) : cs2-gui(4.2.0(3)) : webserver (4.1.1) : spielewelt(4.1.1) ] (Digital)
by clapcott 25/05/2016 13:12:52(UTC)
CS2 Update v4.1.0(3) - [ system(v4.1.0) : webserver(v4) : cs2-gui(V4.1.0(2)) ] (Digital)
by clapcott 18/09/2015 03:26:55(UTC)
Central station internal webserver (Digital)
by jacqvw 26/11/2013 05:01:41(UTC)
Marklin CS2 Webserver Information and Tips (Digital)
by FrankF 27/04/2012 20:21:34(UTC)
This page was generated in 0.537 seconds.
