Offline Scharnhorst
#1 Posted : 11 March 2022 21:09:58(UTC)
Scharnhorst
One of my locomotives had not been serviced in a long time so I gave it a good cleaning. However the pickup shoe seems quite dirty and is interfering with the running no matter what I do. Could any of you give me advice on how to fix this issue please ?
Thank You
Offline rhfil
#2 Posted : 11 March 2022 21:47:26(UTC)
rhfil
Depends on what the dirt is. Most pickup shoes or sliders are removable and replaceable. If the dirt is just grease just clean it with some of solvent starting with soapy water and moving up to carbontetrachloride. If the dirt is actually ionization you might need to sand it off with very find sandpaper or one of those 3M cleaning cloths. Start with the 3M. Get some Q-tips to use with the solvents.
Offline Copenhagen
#3 Posted : 11 March 2022 21:51:11(UTC)
Copenhagen
You could try and clean it with alcohol or some petrol based solvent. If the surface is corroded some very fine sanding paper might do the trick. Be careful not to bend og get the shoe out of shape or alignment when working on it. Lastly it should be possible to get a replacement pickup shoe.
Edit: rhfil beat me to it :-)
It could also be that there is a bad connection between the shoe and the decoder (or whereever the connection is). Some shoes have wire soldered to it and some have some kind of a contact point between the shoe and the locomotive..
Finally, it's even possible that the bad connection is somewhere else, like between the wheels and the chassis.
#4 Posted : 12 March 2022 00:20:05(UTC)
What model is it? For Maerklin or Roco, you should be able to find a replacement at Molard or Boiler. If they don't have stock, try ordering from Bahnorama or Eyro.
If the slider is one of the ones without a cable soldered to it and can be mounted 180 degrees opposed, this can often improve the contact.
I would also look and inspect the ground connections (wheel contacts, axle contacts, bogie contact) depending on the model. Many times, the issue is not the third rail, but the ground return.
Coaches 4050/4076 and pickup shoes 7198 (H0-scale)
by lpesce 29/03/2025 10:50:52(UTC)
Jury Rigged Pickup Shoe (H0-scale)
by TEB007 23/01/2023 03:54:34(UTC)
Pickup shoe short circuit Turnouts (24771/2)? (H0-scale)
by flyhalf 22/01/2023 20:55:12(UTC)
Pickup shoe for digital driving? (Digital)
by einotuominen 21/10/2022 18:13:51(UTC)
Pickup shoes (H0-scale)
by BenP 02/08/2022 21:03:46(UTC)
Current Pickup Shoe (General MRR)
by gmeb 13/01/2022 08:40:49(UTC)
Marklin Car Lighting Set, Pickup shoe part number? (H0-scale)
by frickwg 16/10/2021 16:52:57(UTC)
by revmox 29/05/2021 01:50:11(UTC)
Marklin 7198 Pickup Shoe (Model railroad wiring)
by dboost 23/05/2021 00:11:49(UTC)
Looking for thin pickup shoe (H0-scale)
by DasBert33 24/04/2021 09:01:48(UTC)
Help in finding part # for Marklin pickup shoe (H0-scale)
by frickwg 31/01/2021 18:44:30(UTC)
39640 Pickup Shoe Part Number (H0-scale)
by autowood 08/01/2021 14:07:57(UTC)
Pickup shoe for 43185 (H0-scale)
by PanzerZug 23/11/2020 18:03:57(UTC)
Marklin 1 Gauge Pickup Shoe (Big scale)
by mymarklin99 22/11/2020 04:58:30(UTC)
Which Märklin Lighting pickup shoe Kit? (H0-scale)
by frickwg 28/06/2020 19:27:11(UTC)
Pickup shoes and couplers (H0-scale)
by alistairiancampbell 22/06/2020 10:27:53(UTC)
60973 - Pickup Shoe Changeover Circuit Board (Accessories reviews)
by xxup 01/01/2020 10:11:12(UTC)
Schleifer (Pickup shoe) 206370 (H0-scale)
by Ivan 09/12/2019 16:30:38(UTC)
pickup shoe slider with hole short circuit on slender K switches (H0-scale)
by applor 23/10/2018 00:12:41(UTC)
Marklin silent Pickup shoes (H0-scale)
by anthpao 23/11/2015 21:29:22(UTC)
Better pickup shoe with the wire? (General MRR)
by Goofy 01/01/2015 12:47:22(UTC)
Märklin BR 221 conversions (#29811) - Ball Bearings, LED lights, pickup shoe (H0-scale)
by Moritz-BR365 13/11/2014 08:46:17(UTC)
Silence pickup shoe for Märklin MaK 1206 locos (H0-scale)
by Moritz-BR365 31/07/2014 07:55:49(UTC)
Problems with pickup shoe on ACME Br185 (General MRR)
by jonas_sthlm 18/12/2011 12:55:29(UTC)
Coach Lighting Pickup Shoe Short Circuiting Under Digital Operation (Digital)
by aos 05/03/2011 18:19:00(UTC)
Wiring/track automation problem with 2 pickup shoes (Model railroad wiring)
by vimo 31/12/2010 17:27:05(UTC)
39110 & 39140: Installing a 2nd pickup shoe (H0-scale)
by Marty 06/09/2010 02:47:26(UTC)
Can Märklin pickup shoes be fitted to HAG locomotives? (H0-scale)
by Brakepad 30/05/2010 12:59:05(UTC)
ordered the wrong pickup shoe (H0-scale)
by Kodiak 23/03/2010 08:29:18(UTC)
sourcing Marklin pickup shoe (H0-scale)
by applor 10/07/2009 08:45:10(UTC)
Pickup shoe problems on cars with lighting (Digital)
by gachar001 21/07/2008 19:12:03(UTC)
Which pickup shoe for 3021? (General MRR)
by happyfamily1 12/11/2007 22:25:42(UTC)
service,brushes and pickup shoe (Digital)
by alonso231gery 27/02/2006 21:05:41(UTC)
Pickup shoe part no (H0-scale)
by Sander van Wijk 29/10/2005 20:55:44(UTC)
Pickup shoes spare parts (H0-scale)
by laalves 09/05/2005 01:51:10(UTC)
pickup shoe noise.. (General MRR)
by Sam 13/03/2005 16:06:13(UTC)
This page was generated in 0.552 seconds.
