Offline Emin Evrankaya
#1 Posted : 04 April 2020 16:33:13(UTC)
Emin Evrankaya
Turkey
Good evening everyone.
I still use central station 60212 and it works fine. One problem I have is some of the solenoid items getting lost from the screen when I unplug the unit. Everytime I turn on the unit, I have to enter these items. Does anybody else had this problem? If you have any suggestions, I will really appriciate it. Regards. Emin...
#2 Posted : 04 April 2020 16:46:37(UTC)
Hi Emin
It has been a while since I last used my 60212.
You need to have fresh batteries and push the stop button before unplugging.
I believe it is the way to keep your data saved
#3 Posted : 04 April 2020 17:01:46(UTC)
Emin Evrankaya
Turkey
Hi Jean, I tried it and it seems to be working. Thanks a lot for your suggestion. Stay healthy...
#4 Posted : 06 April 2020 13:04:16(UTC)
I never had batteries in my 60212. Batteries are not needed if you always shutdown properly before unplugging.
Always remove batteries when storing the 60212 unused for longer periods.
The batteries are used to power the 60212 while it shutdowns if power is unplugged before shutting down. Always use fresh batteries if you want to use this comfort feature.
Central Station 60212 (Digital)
by jameskwan88 09/02/2025 07:09:28(UTC)
Märklin Central Station 60212 (Digital)
by Harlov 02/12/2021 08:38:33(UTC)
Another central station 60212 question (Digital)
by DB Fan 10/03/2019 22:29:00(UTC)
Central Station 60212 question (Digital)
by DB Fan 06/03/2019 05:38:16(UTC)
program 16 functions central station 60212 (Digital)
by Simon 21/10/2012 18:10:32(UTC)
Märklin Central Station 60212 with ESU Update 59990 ("reloaded") (Digital components and Software reviews)
by H0 03/01/2011 12:54:55(UTC)
by frans 24/09/2008 13:33:41(UTC)
Central station 60212 - telnet login with password (Digital)
by reh 08/04/2006 15:16:40(UTC)
This page was generated in 0.255 seconds.
