Offline Torrid
#1 Posted : 06 May 2017 18:31:28(UTC)
Torrid
Hi to all members,
I have an issue with setting up my ESU M4 locos, these will register a MFX.
However if the MFX box is unchecked in track settings they can be set up with a DCC address and all of their many functions will be available, however as soon as I run my MFX Marklin locos I have to revert my track settings to include MFX as well. This results in all the ESU M4 locos re-registering as MFX. Obviously this is a problem as I want to run my ESU locos with all their functions and the Central Station is only allowing for 16 functions.
Does anyone know the reason why when set on MFX the CS will not allow for the full 32 functions?
Suggestions appreciated.
Offline Danlake
#2 Posted : 06 May 2017 18:44:42(UTC)
Danlake
Hi Torrid,
The solution is to disable the Mfx protocol in decoder.
See section 9.5 in the Esu Lokpilot manual:
First register the loco as DCC (as you already did correctly)
In CV 47 write value 1
Then only DCC will be active in the decoder and once you activate Mfx protocol on CS3 it wont be able to register the loco as Mfx.
Then you should be able to access the 32 functions.
Brgds Lasse
#3 Posted : 06 May 2017 19:40:11(UTC)
The ESU decoders require a firmware update to allow 32 functions with mfx. Currently such an update is not available.
Offline Torrid
#4 Posted : 06 May 2017 20:03:22(UTC)
Torrid
Hi Danlake,
Great thank you !!!BigGrin
Torrid
New Central Station 3 owner help! (Digital)
by stevenh905 24/11/2024 03:46:00(UTC)
Märklin Central Station 3 / 3 plus - does production date matter? (Digital)
by Torbjorn 01/10/2024 12:53:07(UTC)
Central Station 3 Plus, nightmare no go (Digital components and Software reviews)
by mattj70 01/05/2024 07:03:18(UTC)
Central Station 3 transformer compatibility 6002 (Digital)
by vandermerwe 26/07/2022 12:35:09(UTC)
Coupling 2 central station 3+, can cable needed? (Digital)
by bask185 04/06/2021 10:56:21(UTC)
Automation on G scale with Central Station 3 (Digital)
by PCRail 18/01/2019 21:21:16(UTC)
Running Trains Digitally with the Central Station 3 (Accessories reviews)
by michelvr 11/11/2017 21:22:15(UTC)
by Michael Jervis 14/10/2017 13:56:31(UTC)
by Twisterdodger 27/07/2017 19:54:23(UTC)
This page was generated in 0.311 seconds.
