Offline MHZ
#1 Posted : 03 March 2017 01:13:29(UTC)
MHZ
Hi can anyone help ? I have been given a marklin turntable 7186. The condition isn't great but it seems to work. The blue controller with the 2 red buttons looks melted and broken someone has tried to solder pieces of steel to the switch internally. Is it possible to use a toggle switch in its place and what configuration of switch do I need.
Offline analogmike
#2 Posted : 03 March 2017 01:52:27(UTC)
analogmike
It would be better to just get a new control box. Marklin #40185
Mikey
Offline DB Fan
#3 Posted : 03 March 2017 04:39:45(UTC)
DB Fan
I agree with Mikey. My turntable was missing the controller. I tried different switches and ways to control the turntable and in the end I just ordered a like new original control box on eBay. Works like a charm nowBigGrin
Robert
Offline Markus Schild
#4 Posted : 03 March 2017 10:07:29(UTC)
Markus Schild
The simplest way is to get a new switch. It is still available. The number is now E401850: http://www.maerklinshop....s/32667/turntable-switch
At http://www.jk-webagentur...ibe%207186%202011-09.pdf someone published an instruction how to make the switch yourself. If you can't read German try to copy the text to the Google-translator or a similar service. The document also includes some wiring-sketches where UZ means "clockwise" and GUZ means "counter-clockwise". "Taster" is a "push-button" and the "Schalter" is toggle-switch which has three steps: ON - OFF - ON.
Markus
Markin Turntable 7186 Issue (H0-scale)
by Eddie7979 05/04/2025 18:07:43(UTC)
Decoder for Marklin Turntable 7186 (H0-scale)
by ChrisBu 07/04/2023 17:19:25(UTC)
turntable 7186 (Collector's Corner general)
by drstapes123 17/08/2020 19:25:09(UTC)
Marklin Turntable 7186 (Track plans)
by Philip McCracken 09/04/2020 14:55:58(UTC)
Can Turntable 7186 operate on a digital layout? (Digital)
by DB Fan 20/06/2016 04:23:19(UTC)
Old turntable 7186 controlled with ARDUINO (H0-scale)
by Markus Schild 29/06/2014 19:14:43(UTC)
Märklin Turntable 7186 (H0-scale)
by Rocca 10/03/2014 10:19:10(UTC)
turntable 7186 (General MRR)
by Lorene 28/04/2005 23:26:40(UTC)
This page was generated in 0.245 seconds.
