Offline Mike M
#1 Posted : 26 July 2013 06:03:21(UTC)
Mike M
I am starting to build my layout and I am using the 74461 turnout decoders for switching. How are these as far as reliability vs the k83 decoder? Being new at this I discovered after I had ordered 22 of these that I would have been much cheaper with the k83.Oh well live and learn. My only concern now is the reliability,obvously these would not be as accessable as the k83.
Your advice would be appreciated.
Offline efel
#2 Posted : 26 July 2013 08:18:20(UTC)
efel
I don't think there is reliability issue concerning either k83 or 74461.
On the contrary, large reliability issues have been reported concerning the turnout motor itself.
You may read it on the forum.
It is advised to short the end shut off switches of the motors before starting the layout.
Fred
Offline Mike M
#3 Posted : 26 July 2013 15:50:19(UTC)
Mike M
Hi, Could you explain how to short the end shutoff switches of the motors please
Offline Danlake
#4 Posted : 27 July 2013 16:23:00(UTC)
Danlake
Hi Mike,
See this post: https://www.marklin-user...4490-turnout-motors.aspx
Note; not all users are having problem with the mechanical turnout device 74490/91.
Main advantages with K83 types is that you can use external power supply to switch the turnouts.
But on the other hand with decoder build into the track you will have much less wiring.
Brgds - Lasse
Offline efel
#5 Posted : 27 July 2013 17:09:59(UTC)
efel
Have a look for instance Here
Fred
Offline efel
#6 Posted : 27 July 2013 17:12:38(UTC)
efel
NOT with the Marklin k83! You must use other brand
thanks 1 user liked this useful post by efel
Offline Mike M
#7 Posted : 27 July 2013 17:23:41(UTC)
Mike M
Hi, Thank you for everyones advice.
Offline Danlake
#8 Posted : 27 July 2013 19:04:20(UTC)
Danlake
You can use a booster to power your K83.
Correct with Viessmann you can use a normal 16vac transformer.
Brgds - Lasse
Offline Janne75
#9 Posted : 20 November 2013 18:24:32(UTC)
Janne75
Upping this old topic, sorry... Wink I had to change today two turnout decoders as they were damaged. Turnout motors were jamming and decoders took too much current and got damaged. They only control turnout motors to other direction now and will be as spare parts or thrown away later. I bought two 74660 decoder as I don't like the newer 74661 design. I don't have to control turnout lanterns lights on and off etc.
These 74460 and 74461 turnout decoders are reliable normally, but 74490 and 74491 turnout motors are unreliable due their micro switches. I have shorted all my turnout motors micro switches.
Janne
Offline Johnvr
#10 Posted : 22 November 2013 07:28:31(UTC)
Johnvr
I am also in the process of soldering across the micro-switches , because several of my mechanisms switch only one way.
May be something to do with the coastal air and small amounts of particles, but I would rather they worked properly when I push the button !
It is such a pain to have to lift the track when one has to replace the turnout mechanism.
Regards,BigGrin
Offline Janne75
#11 Posted : 22 November 2013 09:10:59(UTC)
Janne75
Regards,BigGrin
Hi John,
When shorting them be careful that the micro-switches don´t move from their original positions. It won´t happen if you are careful and just quickly solder a short between them. I had two turnout motors which I had fixed by shorting the micro-switches and they were jamming a bit later. If micro-switches move more towards the movable inner part (lever or acting shaft?) in turnout motor this can happen. The trick is to not heat the circuit board too much to avoid micro-switches factory solderings to heat and get loose, only enough to be able to make short soldering across the micro-switches.
Good luck! Otherwise all my fixed 74490 and 74491 turnout motors are working really good. When those two fixed turnout motors was jamming I did not notice it and only thought that there is again some other electrical problem in the turnout motors themself. Then I just tried to switch them some times and when they were jamming I burned two turnout decoders, because of too high current maybe? ThumbDown . There became some smoke from one of them Wink . I fixed these already by changing the decoders and new fixed turnout motors and now everything works like they should. ThumpUp
Janne
#12 Posted : 25 November 2013 10:08:38(UTC)
I hope you can make sense of this German instruction on how to fix the turnout switches.
http://www.mist7.de/home/Varistoreneinbau.pdf
#13 Posted : 25 November 2013 10:45:56(UTC)
These instructions show how to convert a 74490 to a 74491.
Some folks say the 74491 is still not working reliably and the shut-off switches should be bridged.
The PDF nicely shows how to open the turnout mechanisms - and AFAIK you only have to apply a wire instead of the varistor that is used in the PDF.
Offline Janne75
#14 Posted : 25 November 2013 15:14:37(UTC)
Janne75
Yes, both 74490 and 74491 are unreliable and should be shorted (bridged), but only when using them with a controller (CS2 etc.) where switching time in ms (milliseconds) is adjustable. So if used with control boxes they should not be shorted then.
Janne
Offline jfhjg
#15 Posted : 25 November 2013 17:41:08(UTC)
jfhjg
Ireland
Janne,
If you have a decoder which is only working on one direction, you could use it to drive a decoupling track solenoid...
DB: BR86 SBB: 2x Ae6/6; Re620; Ee3/3; Re4/4ii; RAe TEEii; 3x Re481; Ae7/14; Re460
thanks 1 user liked this useful post by jfhjg
Offline efel
#16 Posted : 26 November 2013 09:50:20(UTC)
efel
..The PDF nicely shows how to open the turnout mechanisms - and AFAIK you only have to apply a wire instead of the varistor that is used in the PDF.
For a long time, I wanted to know if M. was using a capacitor or a varistor in the 74491. I can read in that link that the author suggests to use a varistor, that is the right way to go to avoid any spark. Unfortunately, as I can't read german and as that pdf does not allow to copy and past (!?) in order to translate it, I can't know if the author says that he is sure M. is also using a varistor.
Thanks in advance for any help,
Fred
Offline Janne75
#17 Posted : 26 November 2013 10:29:37(UTC)
Janne75
Originally Posted by: jfhjg Go to Quoted Post
Janne,
Thanks for info John.
I don´t have any decoupling tracks though, but I will keep them for that purpose anyway if I some day have them. I use Telex locomotives or do it "manually".
Janne
#18 Posted : 26 November 2013 11:30:54(UTC)
In the document they write that they found varistors inside the new turnout motors (shipped 2011).
They write about a nominal voltage of 26 V and a break-through voltage of 32 V.
Offline efel
#19 Posted : 26 November 2013 13:49:17(UTC)
efel
Thanks a lot, Tom
Guest (4)
Testing Marklin Turnout Decoders/Motors (Digital)
by Alex H 31/10/2025 18:28:13(UTC)
Marklin C track turnout decoders (Digital)
by Alex H 12/10/2023 09:20:42(UTC)
Turnout decoders (General MRR)
by Christo Swanepoel 17/11/2021 06:25:18(UTC)
Turnout Decoders, Signals and MS2 Controlling (Digital)
by CanadianKid 02/07/2017 02:16:17(UTC)
Turnout decoders (Digital)
by oldchippie 07/07/2015 04:00:19(UTC)
Help programming the turnout decoders in 29483 start set (Digital)
by mascagni 02/02/2015 20:38:32(UTC)
74460 turnout decoders (Digital)
by shbrown2424 03/07/2013 15:39:14(UTC)
C Track Turnout decoders (H0-scale)
by sudibarba 26/07/2012 04:46:14(UTC)
Maerklin vs. Viessmann C-track Turnout Decoders (Digital)
by mascagni 27/07/2008 04:53:14(UTC)
k73/6073 turnout decoders for M-track turnouts (Digital)
by Katchina 12/02/2008 23:51:43(UTC)
Turnout Decoders & MS (Digital)
by David Dewar 17/12/2004 18:40:28(UTC)
This page was generated in 0.578 seconds.
