Offline Lorene
#1 Posted : 28 April 2005 23:26:40(UTC)
Lorene
I have a turntable 7186 new about 15 years ago. I am finally getting my layout completed. My loc will operate on the turntable, but I cannot get the turntable to move to different tracks. It seems to be "frozen". I have oiled the bearings with Marklin oil as instructed but this did not help. Does anyone have any suggestions or do I need to send it to a repair shop. Thanks. Lorene
Offline rschaffr
#2 Posted : 28 April 2005 23:40:17(UTC)
rschaffr
Lorene: Does the motor try to run? If you hear a hum, try rotating the armature shaft somewhat to give it a little help. If there is no apparent power to it, turn the turntable over. There should be a series of contacts riding on contact rings on the moving surface. Make sure the rings and the contacts are clean...be sure not to stress the contacts.
-Ron
Offline Lorene
#3 Posted : 29 April 2005 00:41:01(UTC)
Lorene
yes, the motor runs. . I don't know what the armature shaft is but I have tried very gently to help move it one way or the other. I will try to turn it over and view the contacts. They are all clean and are connected (no loose wires). should I remove the c ring and try to lift up the "bridge"? (I really don't have a clue of what I am doing.)
8
<br />Lorene: Does the motor try to run? If you hear a hum, try rotating the armature shaft somewhat to give it a little help. If there is no apparent power to it, turn the turntable over. There should be a series of contacts riding on contact rings on the moving surface. Make sure the rings and the contacts are clean...be sure not to stress the contacts.
Offline Ray
#4 Posted : 29 April 2005 00:51:58(UTC)
Lorene: I have a transfer table and had the same problem. Check under
the table if there is a safety shipping screw. That was my problem.
From Florida,
Rainer
Offline Lorene
#5 Posted : 29 April 2005 01:46:18(UTC)
Lorene
Rainer, I looked and found nothing. I also removed the c spring and nothing. It still will not move.
Offline Sander van Wijk
#6 Posted : 29 April 2005 01:46:48(UTC)
Sander van Wijk
As I read your post you didn't use the turntable recently? Maybe you haven't even used it for some years? (15 or so... wink )
In that case it could be that the mechanism itself is stuck due to the fact that the oil has been drying out. This turntable has a rather strange mechanism, sort of transmission. You can easily check whether the oil is the problem by opening the housing (2 screws, one on the bridge, one on the side of the housing) and checking what happens when the motor runs. There's an axle with a kind of spring on it and a gear wheel on the end of it. The bearing on the end of this axle often gets stuck. If that happens, the motor is still be able to run but the bridge will be jammed. If so, clean it, oil it, a very little bit and everything should be working fine again. Good luck!
Sander
Offline Lorene
#7 Posted : 29 April 2005 02:04:50(UTC)
Lorene
you are correct. . . turntable not used for 15 years. I took off c spring, evaluated the underside and it looked clean. I put it back together and opened the housing and the motor does not run, it only hums. The bridge does not move and I have tried gently moving it by hand with no success. thanks. Lorene
[size=1" face="Verdana" id="quote]quote:Originally posted by Sander van Wijk
<br />As I read your post you didn't use the turntable recently? Maybe you haven't even used it for some years? (15 or so... wink )
Offline rschaffr
#8 Posted : 29 April 2005 02:52:00(UTC)
rschaffr
When you said the motor runs but the TT down't turn, it sounds like the gears are not ingagned. If the TT was jammed and the gears were engaged, the motor would stall. There is a little ever on the side of the motor house. Make sure it moves freely back and forth (it is for reversing the TT manually).
-Ron
Offline Lorene
#9 Posted : 30 April 2005 00:32:56(UTC)
Lorene
thanks to all re 7186. . . found someone to take it apart, clean all the sludge and it is working fine now. thanks. Lorene
Offline rschaffr
#10 Posted : 30 April 2005 04:23:12(UTC)
rschaffr
Great. Glad it works.
-Ron
#11 Posted : 01 May 2005 13:48:31(UTC)
Sander van Wijk
Good, enjoy! wink
Sander
#12 Posted : 01 May 2005 14:19:09(UTC)
Great job.
Guest (5)
Markin Turntable 7186 Issue (H0-scale)
by Eddie7979 05/04/2025 18:07:43(UTC)
Decoder for Marklin Turntable 7186 (H0-scale)
by ChrisBu 07/04/2023 17:19:25(UTC)
turntable 7186 (Collector's Corner general)
by drstapes123 17/08/2020 19:25:09(UTC)
Marklin Turntable 7186 (Track plans)
by Philip McCracken 09/04/2020 14:55:58(UTC)
by MHZ 03/03/2017 01:13:29(UTC)
Can Turntable 7186 operate on a digital layout? (Digital)
by DB Fan 20/06/2016 04:23:19(UTC)
Old turntable 7186 controlled with ARDUINO (H0-scale)
by Markus Schild 29/06/2014 19:14:43(UTC)
Märklin Turntable 7186 (H0-scale)
by Rocca 10/03/2014 10:19:10(UTC)
This page was generated in 0.454 seconds.
