Offline Bones
#1 Posted : 13 December 2023 02:07:12(UTC)
Bones
I been looking at the circuit tracks and have noticed that they can be also used for track occupancy and also still control turnout's ect
Has anybody used these for both and how did you find it
And did they work the way you wanted them to
Offline rhfil
#2 Posted : 13 December 2023 16:14:32(UTC)
rhfil
The advantage of circuit tracks is that they can report the direction the train is moving. The disadvantage of them is that they only report cars with sliders so are not as good at block operation. Also, if you have a consist with cars with sliders for lighting or additional decoders each one will operate whatever you are having them do. But they work pretty well.
#3 Posted : 13 December 2023 17:34:51(UTC)
I use them in events for stop and go plus sounds and turnouts and signals. You can operate them in both directions if you want. Coaches with sliders you need to set delays to avoid coaches using the circuit track when not requred.
Offline BenP
#4 Posted : 14 December 2023 01:43:49(UTC)
BenP
I have a good number of M circuit tracks, but many started to stick after a while. Also, they are activated with each slider passing, so no good with lighted wagons. I changed everything to contact tracks, which work well with cs3 event commands and even better with PC software (Rocrail for me).
Ben
thanks 2 users liked this useful post by BenP
connecting circuit tracks, relays, and control boxes (Model railroad wiring)
by profher 03/08/2017 21:41:03(UTC)
Circuit Tracks (Digital)
by David1954 11/09/2013 00:45:23(UTC)
Finicky, Sticky Circuit Tracks ? Fixed? (Digital)
by Laxman 02/02/2013 05:18:32(UTC)
False alarms with circuit tracks (Digital)
by Semaphore 15/03/2012 23:25:11(UTC)
24194 circuit Tracks. (Digital)
by charles Sharpe 10/07/2008 23:38:11(UTC)
Circuit Tracks in 1 Gauge? (Big scale)
by sprogger 07/03/2008 07:43:11(UTC)
circuit tracks and ms (Digital)
by db216 09/12/2007 07:16:32(UTC)
Using Circuit tracks (General MRR)
by malsnake 02/12/2004 23:32:03(UTC)
This page was generated in 0.244 seconds.
