Offline johnmarklin
#1 Posted : 29 June 2014 19:09:09(UTC)
johnmarklin
Ireland
Fellow Marklin enthusiasts. I am seeking your advice again. My layout is setup as a digital layout using C track and CS2. I recently acquired a vast quantity of Marklin M track in superb condition. I am considering expanding my existing layout to give me more and enhanced running options. I am wondering if I could integrate the M track into my future plans. I would appreciate your opinions and advice. My main concern is maintaining the running/operating qualities that I currently enjoy.
This issue probably has been discussed in the past and I regret causing any annoyance.
Thank you
thanks 1 user liked this useful post by johnmarklin
Offline Harvey
#2 Posted : 29 June 2014 23:22:24(UTC)
Harvey
I only have m track and run digital (CS2). The small issues I run into are likely faces by others with m and c track. Some locs seem to run better in one direction than the other. Similarly, some passenger cars run better when I reverse the direction. I don't use the curved switching tracks as I frequently had derailments and so just leave of any layout design.
I don't have any incurable problems with m track. Just need to 'fine tune connections' when I add a new loc but all locs and all passenger cars of any length run fine. Some people don't like the appearance of the long passenger cars on the 5100 curves. 5200 provide a nicer visual. I am indifferent.
Harvey
thanks 1 user liked this useful post by Harvey
Offline johnmarklin
#3 Posted : 30 June 2014 00:04:43(UTC)
johnmarklin
Ireland
Harvey,
Thank you for that information I will bear it in mind when I get to designing the new layout.
Offline Danlake
#4 Posted : 30 June 2014 14:41:52(UTC)
Danlake
Hi John,
M track is fine for digital operation. Ensure you put enough feeder wires to the tracks. On M track you will sometimes end up with gaps between rails (give the nostalgic sound…) so expect a bit more noise. You can dampen the noise by having an underlay and don’t screw down the track to the base board. Also you can solder the gaps between rails to make the transition more smooth.
However, personally I do find C track inferior as I also think it’s much easier to work with, especially for automated control with feedback etc.
Numerous post in form on this subject – see e.g.: https://www.marklin-user...k-review.aspx#post344376
On my own layout I have a mix between M, K and C tracks. My trains runs fine on all the tracks.
Brgds - Lasse
Offline johnmarklin
#5 Posted : 01 July 2014 00:36:46(UTC)
johnmarklin
Ireland
Lasse,
Thank you for your reply and the link. I had a quick look at the link and the comments look interesting. I will read all of the comments on the link over time and I am sure they will enlighten me further.
#6 Posted : 01 July 2014 09:51:10(UTC)
Hi John,
I had no problems that were peculiar to M track and digital, but I have to say that running on my newer C track is much smoother than on my old M track, especially through turnouts of all types.
My experience with M track is that the metal flexes and distorts over years of use, so that joints become less precise and more likely to cause derailments. I also had issues with the "frog" in the turnouts becoming loose, and with the points not lying flat against the running rails.
If your M track is, as you say, "in superb condition" then I suspect you will get few problems. It would be a shame to waste it, but just be aware of potential problems in the future.
#7 Posted : 01 July 2014 10:55:33(UTC)
being in perfect condition all you have to be aware of the gauge your wheels are set, the accuracy of the rail joints is not always perfect but you can either adjust the height or move them sideways to avoid any derailments, except the noise you shouldn't have any problems and with ballast around the track this would also reduce the noise.
Offline johnmarklin
#8 Posted : 09 July 2014 11:41:40(UTC)
johnmarklin
Ireland
Thank you to all who responded to my query. I will take all of your valuable advice on board.
Marklin M Track 5106 1/1 (H0-scale)
by MALAVIKA 18/02/2024 06:39:03(UTC)
Working with Marklin M track signals (General MRR)
by tandrschaefer 03/01/2024 21:41:00(UTC)
Compatible power supply for Marklin M Track? (General MRR)
by Skywalker646 10/12/2022 02:49:53(UTC)
Marklin M Track 5117 Points / Led Bulbs (H0-scale)
by fossie 28/11/2021 10:53:09(UTC)
HO 2-rail rolling stock on Marklin M track (H0-scale)
by Mr. Ron 08/06/2021 04:59:47(UTC)
Marklin M track vs C track (General MRR)
by Tracy 29/12/2020 22:03:50(UTC)
Marklin M track 7339 signals (General MRR)
by Rheingold55 02/02/2019 14:32:08(UTC)
Marklin M Track catenary: Which screw type is needed? (H0-scale)
by Slider 05/09/2016 14:34:01(UTC)
Problem with Marklin M track switches (H0-scale)
by jimwallace1652 22/09/2014 00:11:24(UTC)
Marklin M track points and TEE Inox coaches froe SNCB and SNCF (H0-scale)
by dan67millie 30/01/2012 21:43:03(UTC)
my first pair of Marklin M Track Turnouts arrived!!! (H0-scale)
by ziggypig321 14/01/2012 22:01:29(UTC)
marklin M track for useing as (ac or dc) (H0-scale)
by neo007 31/03/2011 21:25:47(UTC)
OK, Let's See Who Really Knows Marklin M Track! (H0-scale)
by walters48 02/04/2010 07:40:25(UTC)
Marklin M track and wheel standards (General MRR)
by Dick 17/09/2003 01:29:42(UTC)
This page was generated in 0.500 seconds.
