Offline David1954
#1 Posted : 11 September 2013 00:45:23(UTC)
David1954
How do you wire circuit track (24994) to turn on or off another track power. Both have an insulated space. Do you need an additional item beside two circuit tracks? If so what is it?
#2 Posted : 11 September 2013 07:52:56(UTC)
You need a signal or a universal relay for that task.
It's easier to answer your questions if you keep related questions in one thread (instead of starting a new thread for every new question).
Offline waorb
#3 Posted : 11 September 2013 14:12:57(UTC)
waorb
Brazil
You can also use the K84 decoder for this task. Several diagrams are on the net, depending of what do you want. Cool
Maybe you need the S88 also...
Walter
#4 Posted : 11 September 2013 14:45:40(UTC)
And also a CS2 or ECoS or something like that. A universal relay will be a li'l bit cheaper than k84+s88+CS2. LOL
#5 Posted : 12 September 2013 00:45:50(UTC)
The Circuit track acts as a trigger(control) only, so you DO need additional componetry(relay) to act as the on/off switch
ESSENTIAL
The switch is generally a relay contact and, for the purpose you describe, is generally provided as an integral part of most Marklin block signals.
If you have no need of the signal part then any relay(latching) will do .
Note: a latching relay is one that needs only a pulse to change state. thus there is a wire for the on_pulse and a wire for the off_pulse
As to the actual control method, you have a choice of DIRECT or INDIRECT
DIRECT (just add wire)
The control signal from the circuit track (or contact track, or pushbutton control panel) is feed directly to the relay. In this scenario you would generally have 2 sensors one to make the track safe(dead/off) and one for go. It is quite normal for a sensor to, concurrently, set track power off for one line and on for another. This is typical when a train enters a block and the signal goes red to prevent entry, but this can also imply that the block just vacated is (becoming)clear and the upstream signal can be concurrently set to (amber)green.
INDIRECT (see other references to Controller<6021,CS,ECos> and Control Equipment<6084,6083-plus-Relay/Signal>)
In this scenario , the trigger signal from the sensor (circuit track) is connected to a controller device with , generally, more advanced logic.
The resulting output of the logic is to send the needed commands to the relay/signal as above.
Thus 1,2or3 additional pieces of equipment are needed depending on the features of the Controller
a) The Controller
b) a mechanism to receive the trigger (in Marklin world this is a s88 <60880>)
c) a driver for the relay (in the Marklin world this is provided by a k84<60840> or k83 <60830>PLUS Universal relay<7244>)
The direct method requires only the relay mechanism (Marklin 7244 relay or Signal with relay wiring ). however it has almost no flexibility - this can be desirable for the reliability of fixed sequencing. The indirect method, as well as adding flexibility of logic, also allows the controller to accurately reflect the state of the layout, track occupied for the Layout Schematic, and the state of points and switches(relays)
References
Universal Relay (note: the red wires indicat the On/Off wiring)
http://medienpdb.maerkli...s/1/pdf/7244_betrieb.pdf
k84<60840>
http://medienpdb.maerkli.../1/pdf/60840_betrieb.pdf
Note: The Schematics are pathetically naive but do give something to work with
In the 7442 diagram, an ASSUMPTION is being made that the brown wire that is shown connected to 7039 signal is connected to the baseplate which is clipped to M-Track in order to propogate the circuit down the rail to the 24994 switch (other side of the blue wire). As this is clearly C-Track additional , manual, wiring is needed to ensure the brown wire return circuit is complete all the way to the 24994.
In the 6084 diagram do not get confused by the Red wireing to the "dead" section being "jumpered" to the bottom/left red connection of the k84. This wire should come from the same power source that is feeding the adjacent pieces of track to the dead section. IF this was a digital layout AND there was only a single controller with no boosters this schematic would be acceptable. But for Analogue or Booster track powering this wire should be derived from the upstream track to prevent cross connections of different power sources.
Offline Mike M
#6 Posted : 12 September 2013 01:05:48(UTC)
Mike M
None of these links work. Tried copy paste no success
ESSENTIAL
a) The Controller
References
k84<60840>
#7 Posted : 12 September 2013 01:46:01(UTC)
If your browser does not allow hyperlinking the full urls are ...
http://medienpdb.maerklin.de/product_files/1/pdf/7244_betrieb.pdf
http://medienpdb.maerklin.de/product_files/1/pdf/60840_betrieb.pdf
Circuit tracks (Digital)
by Bones 13/12/2023 02:07:12(UTC)
connecting circuit tracks, relays, and control boxes (Model railroad wiring)
by profher 03/08/2017 21:41:03(UTC)
Finicky, Sticky Circuit Tracks ? Fixed? (Digital)
by Laxman 02/02/2013 05:18:32(UTC)
False alarms with circuit tracks (Digital)
by Semaphore 15/03/2012 23:25:11(UTC)
24194 circuit Tracks. (Digital)
by charles Sharpe 10/07/2008 23:38:11(UTC)
Circuit Tracks in 1 Gauge? (Big scale)
by sprogger 07/03/2008 07:43:11(UTC)
circuit tracks and ms (Digital)
by db216 09/12/2007 07:16:32(UTC)
Using Circuit tracks (General MRR)
by malsnake 02/12/2004 23:32:03(UTC)
This page was generated in 0.703 seconds.
