Offline Mr. Ron
#1 Posted : 30 January 2023 00:27:20(UTC)
Mr. Ron
Does anyone use the "My World" line of Marklin trains for their model railroad. I find that information regarding the systems is far and few between. I have been able to come up with the following information: 1. My world is HO scale; 2. My world track is compatable with "C" track and can be connected together; 3. My world uses battery power. Now for my questions; Can My World trains run on C-track? My World track is all plastic, so AC and DCC trains cannot run on My World track; is this true? Are My World trains "toy like" in appearance therefore would not fit in with scale Marklin trains? Will My World couplings work with scale Marklin couplings? The reaso why I am asking these questions is; the cost of My World tracks are very cheap compared to 3-rail track. The same for cars. Can they be converted to run on 3-rail track? Conceivably, An inexpensive train layout could be built using a combination of My World and conventional 3-rail track.
There is a model railroad club close by that I believe is using "My World" trains. I will have to check them out.
thanks 1 user liked this useful post by Mr. Ron
Online marklinist5999
#2 Posted : 30 January 2023 00:30:49(UTC)
Ron, "My World" is a line of sets and such for kids. Most are of plastic, and battery operated. A few starter items in the adult ho line may be labeled My World, like C track in blister packaging.
#3 Posted : 30 January 2023 00:48:17(UTC)
Correct on second point, first point is arguable. The My World items use magnetic couplings, and are probably relatively oversize, and are generally representative of items rather than being true scale items.
Yes.
Correct. The My World track is one piece molded including plastic centre studs. The points use a very different mechanism to standard C track (and I'm not sure it isn't a more robust mechanism).
yes they are toy like (see my point further up). They are made for rough handling by pre-school children, while giving them maximum play value.
No they have magnetic couplings. However marklin do make a wagon with the My World magnetic coupling on one end and a standard Marklin coupling on the other end.
The track is cheap because it is one piece plastic including the rails, so there is no assembly process once it comes out of the plastic injection machine, whereas a piece of C track will have about six or seven assembly operations once the trackbed comes out of the machine (along with a whole heap of manufacturing operations to make the other parts that go into those assembly operations).
I would be very surprised if an MRR Club is using My World track unless they have a little layout for small children to play with. The track cannot be used for conventional MRR use unless the wagons are being pulled by the My World non-prototypical locos and using the coupling adapter car I mentioned above.
The MRR Club may be running My World locos and stock on conventional track on a club layout as a means of having a small childrens operating day, or something similar, or for some other disability related reason, but I seriously doubt they will use any My World items for serious MRR activity.
Offline Mr. Ron
#4 Posted : 30 January 2023 02:25:38(UTC)
Mr. Ron
Yes.
Thank you for the answers to all my questions. The local club I mentioned does have a layout tailored towards children, I didn't know if it was "MW" or Lego. Due to its low cost, the track could be used in areas where powered locomotives are not used.
#5 Posted : 01 February 2023 10:03:58(UTC)
FWIW and as it may relate to the 2nd hand market ...
Over 10 years ago "MyWorld" started the branding confusion .. and there was unfortunate overlap/crossover with "StartUp"
The MyWorld 2011 announce had its own catalogue , but was also covered on pages 4-48 of the 2011/2012 catalogue
UNDER THE SAME BRAND
e.g.#29163 pg 10-11 : had 24xxx C-Track and power to the track sets able to control digital locomotives.
The IR remote pointed at a mini trackbox which issued the commands to the locomotive decoder via the track
AND
e.g. #29200 pg 8-9
The sets with 24xxx C-Track and Battery Powered locomotives with the IR remote pointing to an IR receiver on the top of the locomotive/wagon unit
The - much later in 2016 - the 23xxx track arrived
so today we have the sets with the 23xxx C-Track ( plastic rails) and only IR to the loco/wagon
#6 Posted : 01 February 2023 11:30:54(UTC)
To make things more confusing, there are already two generations of the plastic rail tracks:
The first generation had 24° R2 turnouts and straight tracks were 188 or 172 mm like regular C track.
The current generation has 30° R1 turnouts and straight tracks are 180 mm like the older Alpha track.
My world steam locomotive (H0-scale)
by Silentmoose 07/12/2023 19:22:30(UTC)
Marklin my world 29340 debug and repair advice (Digital)
by NoOne 26/08/2023 06:39:36(UTC)
Märklin My World loco on Digital layout; what’s the address? (Digital)
by Max J 09/03/2023 23:31:11(UTC)
Marklin My world 29340 back wheel replacement? (H0-scale)
by Jelmew 23/01/2023 08:25:27(UTC)
Märklin my world - "TGV" Starter Set 29306 - MS2? (Digital)
by mramstedt 29/10/2022 19:17:41(UTC)
Marklin My World Club (General MRR)
by Harvey 18/08/2021 03:12:50(UTC)
Loc 37325 Re 6/6 11672 and My World Operation (General MRR)
by Harvey 14/03/2021 01:50:54(UTC)
Marklin My World 72218 (H0-scale)
by Cermak 28/01/2021 19:17:49(UTC)
Marklin My World 72221 (H0-scale)
by Cermak 24/01/2021 11:45:54(UTC)
Reverse Loop My World (H0-scale)
by SoarSummit 13/08/2020 15:35:45(UTC)
My World building blocks, to steep for regular trains? (H0-scale)
by rhNOR 20/07/2019 23:35:13(UTC)
My world compatibility (H0-scale)
by budi@ups4.com 30/05/2019 10:38:40(UTC)
My world under catenary? (General MRR)
by hennabm 08/03/2019 21:27:11(UTC)
My World tracks - Are they compatible with C-Track? (H0-scale)
by rglasinovic 25/05/2018 19:37:43(UTC)
My World RC (General MRR)
by Darek 20/12/2017 19:26:19(UTC)
using "my world " light signals on M track digital layout (Digital)
by Tex 22/10/2017 21:16:21(UTC)
Märklin freight cars - Märklin (white box) vs My World (white&orange box) (General MRR)
by Minok 17/02/2016 06:47:55(UTC)
My World 29370 Freight - What's your experience? (H0-scale)
by Tomgi 06/12/2015 01:16:15(UTC)
Märklin My World - Replacing the sounds (H0-scale)
by Tomgi 28/11/2015 13:11:58(UTC)
Help - need guidance on My World Battery Train sets (General MRR)
by DV 14/06/2015 13:31:55(UTC)
Marklin my world motor unit measures please (H0-scale)
by danmarklinman 06/02/2014 11:21:52(UTC)
My World 29213 Dutch High Speed Train (News from Märklin and others)
by NS1200 10/10/2013 17:37:51(UTC)
Help with some My World / Streetcar options (H0-scale)
by ratherbesailing 03/09/2013 19:58:22(UTC)
Marklin my world 2013 catalogue. (News from Märklin and others)
by steventrain 01/02/2013 09:36:50(UTC)
"My World" ICE Set - Letter from Customer (H0-scale)
by plavnostruev 15/12/2012 18:05:20(UTC)
My world Special starter set. (News from Märklin and others)
by steventrain 21/11/2012 17:54:51(UTC)
My World Thalys in upgraded version? (News from Märklin and others)
by NS1200 18/10/2012 20:29:37(UTC)
My World on sale via Intertoys. (News from Märklin and others)
by NS1200 14/10/2012 17:29:26(UTC)
Marklin 36320 (My World Db Br81) With Full Gearing (H0-scale)
by Artologic 19/08/2012 11:41:05(UTC)
My Birthday - My World! (General MRR)
by Joseph Meiring 05/07/2012 22:51:01(UTC)
Marklin My world 29201 Battery TGV set. (News from Märklin and others)
by steventrain 20/05/2012 09:53:05(UTC)
My World trains (General MRR)
by Darren W 06/05/2012 03:04:58(UTC)
Anyone used a 'My World' RC train on DC Track? (General MRR)
by Choobacca 26/02/2012 11:36:31(UTC)
Maerklin My World ICE/TGV trains are cute! (News from Märklin and others)
by NS1200 16/02/2012 20:33:58(UTC)
Marklin My World in US (H0-scale)
by rschaffr 10/12/2011 15:41:24(UTC)
Marklin My world ICE Battery set. (H0-scale)
by steventrain 25/09/2011 11:39:27(UTC)
My World - Start them young! (H0-scale)
by plavnostruev 26/06/2011 21:12:50(UTC)
Marklin 'My World' Promo (News from Märklin and others)
by GG1 Fan 22/02/2011 05:51:54(UTC)
Are other brands compatible with Maerklin? (from "My World" Flyer) (News from Märklin and others)
by mike c 16/02/2011 05:36:45(UTC)
This page was generated in 0.534 seconds.
