Offline Suomi762
#1 Posted : 01 March 2023 22:48:54(UTC)
Suomi762
Being new to the Marklin fraturnity, not sure what would be best for multiple feeder wires. Plan to have three ovals (R3, R4, R5) under Delta control with a max of four locomotives. Want to run to two 72090 distribution strips and from there to the track. Any suggestions would be most appreciated.
#2 Posted : 01 March 2023 23:34:54(UTC)
Depending on the length of the oval one wire to each oval would be fine.
Offline Suomi762
#3 Posted : 02 March 2023 05:13:40(UTC)
Suomi762
Which wire set would be best? 74040, 74042, or 74046? Thanks
#4 Posted : 02 March 2023 09:44:22(UTC)
Don't use the 74046 - it is for analogue operation only.
You can solder wires to the C track, you can use the 74995 spade connectors, use the 74042 as intended by Märklin along with one 74040 or go your own way.
Offline Suomi762
#5 Posted : 02 March 2023 19:01:56(UTC)
Suomi762
Thanks to everyone so much.
Invisible track feeder wires (Small scale)
by Manga 08/03/2023 10:30:03(UTC)
Additional Feeder Wires (Digital)
by Mayleneman 05/02/2023 21:27:58(UTC)
Bus feeder wires? (Model railroad wiring)
by Jabez 10/05/2019 22:24:24(UTC)
Soldering Feeder wires to C track (Model railroad wiring)
by Jabez 19/04/2019 22:36:52(UTC)
Marklin 8590 Feeder Wires (Small scale)
by Sinx 18/08/2017 19:36:16(UTC)
How to Connect Multiple feeder Wires with 60113 Track Box? (Digital)
by 5HorizonsRR 05/09/2016 17:32:22(UTC)
Method for adding more feeder wires-Any suggestions (Model railroad wiring)
by garben 13/10/2015 00:29:10(UTC)
Ragarding M tracks with feeder wires (H0-scale)
by elig99 16/02/2013 09:32:07(UTC)
feeder wires (Digital)
by charles Sharpe 17/11/2007 22:34:28(UTC)
This page was generated in 0.361 seconds.
