Offline Manuel Sousa
#1 Posted : 18 September 2022 18:19:13(UTC)
Manuel Sousa
Hello can anyone help me?
I am in a new project and i am using my old CS1 with last firmware and software update 2.0.4.
The problem is that I can't get the Marklin K Track Electric Turnout working.
The k83 is ok and working because I tested it on my other layout with Marklin CS2 and all Marklin K Track Electric Turnout are also ok and working because I can test them directly on Track.
Any idea what might be going wrong?
Thanks in advance,
Manuel Sousa
#2 Posted : 18 September 2022 19:19:58(UTC)
Do not swap the red and brown wires leading to the k83.
IIRC the wires are swapped between CS2 and CS1, so if the plug works with CS2 then you have to swap wires for CS1.
#3 Posted : 18 September 2022 21:55:33(UTC)
Manuel Sousa
Hi Tom,
First of all thank you for the quick reply.
I think I've made the correct swap wires for CS1.
The cables to the k83 are connected:
Red to Marklin K Track 0
Brown to Marklin K Track B
#4 Posted : 19 September 2022 01:12:18(UTC)
That's correct but what Tom is saying is that the output pins on the CS1 are reversed from those on the CS2.
CS1
CS2
#5 Posted : 19 September 2022 01:20:49(UTC)
Except those connections aren't reversed......
The connections for the Central Station Reloaded (ESU's upgrade to the Central Station) appear to be reversed, but they are taken from the rear view of the controller, so effectively the same.
#6 Posted : 19 September 2022 09:32:11(UTC)
Red goes to B or centre rail, Brown goes to 0 or outer rail.
The k83 will not work if red and brown are swapped anywhere between controller and decoder.
#7 Posted : 19 September 2022 10:03:00(UTC)
The view is the same, the arrangement of the sockets is the same, and the connections B and 0 are swapped.
#8 Posted : 19 September 2022 14:20:03(UTC)
Manuel Sousa
Good morning, everyone,
Thank you all very much for your help as I was going crazy.
Everything is working properly now.
This request for help can be considered closed
Thank you all
MARKLIN CS1 (60212) MALFUCTION (Digital)
by lvfocus 02/02/2021 18:32:15(UTC)
Marklin CS1 60212, S88 and Rocrail experience and issues (Model railroad software)
by Profpetrof 24/11/2016 11:03:15(UTC)
Update Marklin CS1 V2.0.4 to ESU V4.0 (Digital)
by RUBEN SPAIN 18/05/2014 16:29:35(UTC)
Marklin CS1, 6017 Boosters & MFX loco (Digital)
by ycliew 27/12/2011 11:34:18(UTC)
This page was generated in 0.351 seconds.
