Offline mramstedt
#1 Posted : 23 October 2021 18:53:42(UTC)
mramstedt
Hi Community, just picked up a used Märklin set. I have only experience with the old analog systems and wonder what to do with this. The DC plug is kinda fiddly, but got it to work a the Mobile Station Powered up. Track terminals are connected. None of the buttons on the Mobile Station seem to have any response. What should I do?
thanks 1 user liked this useful post by mramstedt
Online Bogenschütze
#2 Posted : 23 October 2021 19:33:05(UTC)
Bogenschütze
When powered up, the MS always starts in the STOP mode. Nothing will respond until you press the red illuminated "Stop" button. All the other buttons and the large red speed control knob should then work.
Edited by user 23 October 2021 23:57:50(UTC)  | Reason: Not specified
Marklin - "The train set I never had as a child."
Keith Bowman
Offline mramstedt
#3 Posted : 23 October 2021 19:44:27(UTC)
mramstedt
Tried the STOP buttons and then other buttons, nothing works. What am I missing here?
WhatsApp Video 2021-10-23 at 20.42.29.mp4 (3,780kb) downloaded 58 time(s).
#4 Posted : 23 October 2021 23:52:30(UTC)
Do you have an mfx loco to put on the track? If so then do so and let it register.
You may need to clear out the loco list first if the locos present are not yours.
Offline Martti Mäntylä
#5 Posted : 24 October 2021 00:37:08(UTC)
Martti Mäntylä
You have a short circuit somewhere. Check the Trackbox connections and make sure the connectors are joined correctly.
- Martti M.
#6 Posted : 24 October 2021 10:17:29(UTC)
You need a digital locomotive to work with the Mobile Station 2, preferably a later generation one with mfx that will register itself with the MS2 (as Alan pointed out).
As Martti suggests, it seems you have a track short somewhere which is why the MS2 won't come out of Stop mode. You need to fix that first.
I suggest you download the MS2 manual which should get you started using the MS2
https://static.maerklin....20fbe5c2c31619688976.pdf
Offline mramstedt
#7 Posted : 24 October 2021 11:12:36(UTC)
mramstedt
Thanks all for the advice. Cleaned the MS2 connector with electrical spray and a piece of wire and also the plug. Unplugged the track box and tightened the connectors and connected everything back without the loco. Was then able to get the MS2 to respond and enabled the factory default settings. Loco back on the track and now configured. Everything works :) have a great Sunday!
thanks 6 users liked this useful post by mramstedt
Offline Ranjit
#8 Posted : 24 October 2021 12:05:44(UTC)
Ranjit
"All is well that ends well" ! Enjoy !
#Get Vaccinated
Mobile Station 60653 (H0-scale)
by Gunnar 27/09/2020 12:28:37(UTC)
Mobile station 60653 (Digital)
by Gunnar 09/09/2020 16:30:50(UTC)
Mobile Station 60653 (Digital)
by charles Sharpe 27/06/2020 13:54:42(UTC)
Mobile Station 60653 software ver. 3.3.5 (H0-scale)
by ParisTsirchoglou 12/02/2020 20:19:24(UTC)
Upgrading between Mobile Station 60653 and 60657 (Digital)
by aclassifier 13/02/2016 12:33:27(UTC)
Troubleshooting Mobile Station 60653 (Digital)
by elite194 22/05/2015 14:47:12(UTC)
Mobile Station 60653 (Big scale)
by Rocca 29/11/2014 14:38:58(UTC)
mobile station 60653 (Digital)
by Varun R 22/10/2014 11:11:30(UTC)
Mobile Station 60653 Freezing (Digital)
by Cyborg 10/03/2014 03:22:03(UTC)
Mobile Station 60653 Replacement Cable (Digital)
by chrisisrang 09/06/2013 02:47:25(UTC)
Mobile station 60653 (H0-scale)
by jackmac 21/09/2011 16:33:23(UTC)
Mobile Station 60653 - Reg 1 & 75 change (Digital)
by huttel 17/10/2010 12:44:54(UTC)
This page was generated in 0.408 seconds.
