Offline BruceOrrell
#1 Posted : 16 April 2020 16:00:43(UTC)
BruceOrrell
My father started using Marklin in the 1950s. As a kid I remember the room we had and the trains all ran very well. I still have the various 800 line of locomotives he used and they work great.
He moved the layout to different house and that was fine too.
Fast forward 15 years and I have finally taken the stuff out of the boxes and set up a room for it. I have a layout area about 14ft long and 4 feet deep with an area at each end that is deeper for yards and sidings.
I have also invested in digital locomotives and controls over the years.
My intent is to setup a layout with both a digital and analog component (not connected in any way). I have a large amount of M Track so I am using it for both. I have completed the digital side of things (2 loops with a reverse) and before moving to analog, I wanted to test it. That is where my frustration is.
I am using a CS2. Works great, and it has my digital locomotives in it. I start to run a train and the newer digital locomotives cannot negotiate curves without derailing (seems to be the steamers with front bogies). Or they will travel along and stop and the CS2 shuts down with a short where the locomotive sits.
I recall this M track being more or less flawless in use but it seems that the newer locomotives cannot handle it. Or is it the track?
Not sure where to turn.
thanks 3 users liked this useful post by BruceOrrell
#2 Posted : 16 April 2020 16:21:14(UTC)
There could be a number of things causing it:
a: the slider is not set properly
b.) the axle(s) is out of gauge tolerance
c.) maybe the front truck spring is to weak.
#3 Posted : 16 April 2020 17:11:02(UTC)
If it is happening to all your locos then it is probably the track. John above has it covered but not sure if all your locos would have problems.
Is it the same track part(s) that cause the problem.
If starting a new layout I would go for C track to give good running and also avoid a lot of wiring with turnouts etc.
Offline mbarreto
#4 Posted : 16 April 2020 17:18:58(UTC)
mbarreto
I think it is not your situatoin, but if the curves are 5120 probably many locomotives can't handle it.
Other aspect to check is to ensure each full curve is at the same level.
Miguel
Mostly Märklin H0.
Offline franciscohg
#5 Posted : 16 April 2020 18:54:23(UTC)
franciscohg
Chile
I run my digital Layout with M track.
The oder the track Is the more the tolerances in manofacturing are higher.
That arises in problems with newer locos running on the oder track. In the End i gave up on oder tracks and get newer wich gave me good results. I also gave up on mostly 5100 series turnouts to avoid troubles.
In some "New" 5200 turnouts problems like yours still existes with no apparent causes, the solution was to Just change it for other one.
Also say that proper, if not perfect, tracklaying is needed
Regards.
Offline carlos.rivas.16752
#6 Posted : 16 April 2020 19:58:48(UTC)
carlos.rivas.16752
I´m also running my digital layout with M track. Check out all the track sections to test if they are leveled; avoid using 5120 industrial tracks (45º); look for good connections between each piece of track in order to avoid shorts and check out the front bogies on your locos. Everything should work OK unless your M track is deteriorated.
Carlos
My blog both in Spanish and English: https://grunewiesen1965.wordpress.com
#7 Posted : 16 April 2020 22:10:08(UTC)
Hi Bruce
When in good condition, M track works very well with all Märklin locos including digital.
As said before me, 5120 track is not suitable for large locos and cars after 1970 but all others are (except also the large lantern switches which may be in the way of longer passenger cars (more than 24 cm)
Make sure the rails are not bent and track joiner are gripping the next rail
On switches, make sure the counter-rails (the ones across the frog) are in proper position and not bent. Check with a loose axle. Make them sit firm in position by grabbing their extremity under the roadbed with long-nose pliers and gently turn a little.
Bonne chance
Offline BruceOrrell
#8 Posted : 21 April 2020 16:10:40(UTC)
BruceOrrell
Thanks for the input. I have been working though this and have identified the problems.
First the front truck spring in the locomotive did not appear to be correct. I took it out and re-seated it and it functions better.
Secondly, the 5120 curves were the problem. I have begun removing them and re-laying the track with proper curves.
These two steps have addressed the derailment issues.
The shorting took a little longer to resolve but I found that some track screws were perhaps not in perfect vertical alignment and when the slider came along it would contact the screw head.
All in all, the frustration level is much reduced!
#9 Posted : 21 April 2020 17:01:27(UTC)
Hi Bruce
Glad you solved the issue.
On my first Märklin layout with M track (that was between 1961 and 1970) I checked that all Märklin rolling stock of that time was doing very well on 5120 but provided conditions:
- no "S" arrangement,
- no grade/ only horizontal,
- no push-back of long trains at high speed
- tracks in good condition
Have you ever been frustrated from a loco with sound decoder and noisy motor? (H0-scale)
by H0 12/12/2013 09:35:34(UTC)
Frustrated with Bank Wire Transfer (Collector's Corner general)
by Jeremy Palmer 26/12/2009 17:10:43(UTC)
Frustrated! (H0-scale)
by MARKLIN LOVER 18/02/2009 01:56:49(UTC)
Frustrated again (Digital)
by prc 21/10/2005 02:14:14(UTC)
This page was generated in 0.600 seconds.
