Offline Nick A
#1 Posted : 25 February 2020 00:05:39(UTC)
Nick A
With Marklin Ho scale, what is the max incline?
Nick
thanks 1 user liked this useful post by Nick A
#2 Posted : 25 February 2020 00:42:55(UTC)
Perhaps 5% depending on the loco and its load, and the curvature of the track.
It also depends on how realistic you want it to look. Anything over 2% starts to look toy-like.
thanks 4 users liked this useful post by DaleSchultz
Offline Drjoe11
#3 Posted : 25 February 2020 13:57:26(UTC)
Drjoe11
I use a 4% incline and it looks fine. I used Scenic Express 4% incline kits. It is a an 8 foot run up and down.
thanks 3 users liked this useful post by Drjoe11
#4 Posted : 26 February 2020 08:53:39(UTC)
There are several main and branch line examples in- and outside Germany, old and new, with an incline of more than 2%. I guess they look toy-like.
#5 Posted : 26 February 2020 19:04:54(UTC)
as I said "starts"
and yes, they do exist and they are all special cases, either designed for modern system with multiple traction wheels, light rail, or they require pusher locomotives, etc.
Just because something exists (rarely) in the prototype does not mean its looks realistic on a model layout. If one is striving for realism, including something that is extremely rarely seen in real life, detracts from the realism being sought.
When S-Bahn trains dive underground on the outskirts of a big city, they do look toy-like. Running a good trains across such a grade would look awful.
#6 Posted : 27 February 2020 01:46:01(UTC)
That simple question and it has the usual answer of "it depends".
As others have pointed out, there are the optics that may come into play, but then the curves we can use are also unrealistic so its all a mater of taste.
From the practical perspective it still depends;
Which locomotive (power and # of traction tires), pulling what sort of weight, and how those cars behave (going up or down, do the buffers get entangled, couplers stay cleanly engaged).
So a single locomotive can do extreme inclines, put 3 passenger coaches after it and it cannot do as much, put a full 8-11 car train after it it does less, pull 30 or cars and its probably even less.
Run it up a straight with slow ease into the include (and out) and its one thing, in an R1 helix, its another thing.
Its on my "to do" list to test out the trains I'll be running by adjusting the elevation of the threaded rod helix I'm putting together to test the limits and know where I stand.
#7 Posted : 27 February 2020 08:47:50(UTC)
Most Märklin trains are very "strong". Especially older designs from the 80´es.
You should be safe with 5%.
Some smaller locos (like Glaskasten or Köf) does not handle inclines well. (Check to see if your locos has traction-tires)
Think in advance if you are likely to ever use locos from other brands. They might not be well suited for a 5% incline.
2,5% will probably do for almost all types of rolling stock.
Lastly, its not only the incline itself that can poses a problem, but the TRANSITION from level to incline; It is important that the transition happen gradually, or your loco will loose traction and/or waggons will uncouple.
thanks 4 users liked this useful post by hxmiesa
Online PJMärklin
#8 Posted : 27 February 2020 11:32:52(UTC)
... its not only the incline itself that can poses a problem, but the TRANSITION from level to incline; It is important that the transition happen gradually, or your loco will loose traction and/or waggons will uncouple.
ThumpUp
#9 Posted : 27 February 2020 12:54:20(UTC)
...either designed for modern system with multiple traction wheels, light rail, or they require pusher locomotives, etc…
To name single track line examples outside of Bavaria, from a MRR point of view a class 85 steamer (or a class E[2]44 electric) on the Hoellentalbahn (max. 5.7%), a class 218 diesel on the Murgtalbahn (max. 5.0%), a class 218 diesel (or a class 171 or 185 electric) on the Ruebelandbahn (max. 6.0%), and a class 213/215/218 diesel on the Hunsrueckbahn (max. 6.1%) would be just a single loco hauling a train, respectively. Regarding double track, ignoring new steep ICE lines, „regular“ trains make it over the Erkrath–Hochdahl ramp (max. 3.3%) between Duesseldorf and Wuppertal without helper service since the 1960s electrification.
And just because something exists (frequently) in the prototype does not mean its looks realistic on a model layout.
Come again?
Now aesthetics and realism are becoming mixed up.
Edited by user 27 February 2020 18:52:18(UTC)  | Reason: Not specified
Offline Drjoe11
#10 Posted : 27 February 2020 19:05:47(UTC)
Drjoe11
All I did was answer a question. I did not expect folks to talk about realism or aesthetics. I just like to run my Marklin trains while building this new layout. I like scenery and old German and Bavarian buildings (some modern also). So I guess my layout is a mixture of old and new. I really do not care. All I care about is how it looks to me and that I can have building it and running my trains.
My layout is 12 feet by 8 feet in an "L" configuration. Right now I am trying to automate it using signals as on my old layout that the late Tom Catheral designed for my. My 2 cents.
#11 Posted : 27 February 2020 19:53:27(UTC)
Asking or even answering questions on this forum is a bit like opening Pandora's box. You never know in what direction the answers and comments will go! BigGrin
#12 Posted : 27 February 2020 22:11:32(UTC)
And what you like is the only thing that matters. (I assume you meant ...was ask a question...) So focusing on the mechanical physics of what can a particular locomotive do, pulling several cars - with Märklin it can probably go up a steeper incline than you would expect; but you want to test with your weakest (least traction and lightest weight, going around include R1 curves ) pulling your longest for it train, to find your limits. If the traction tires (rubber) are old, replace them first with new ones as old rubber gets brittle and less grippy often.
#13 Posted : 28 February 2020 00:21:05(UTC)
All I did was answer a question. I did not expect folks to talk about realism or aesthetics...
And what you like is the only thing that matters. (I assume you meant ...was ask a question...) ...
I believe there is some confusion, as Nick A started the thread by asking a question, while Drjoe11 was the second to reply (with DaleSchultz being the first responder).
Offline michelvr
#14 Posted : 28 February 2020 00:48:15(UTC)
michelvr
I'm inclined to agree!BigGrin
thanks 3 users liked this useful post by michelvr
#15 Posted : 28 February 2020 09:25:21(UTC)
Yes, its an uphill battle...
Online PJMärklin
#16 Posted : 28 February 2020 09:55:19(UTC)
I was waiting for someone to speak up, but then someone else might take a different angle on it - now that would ramp up discussion, particularly if another was to rise to it.OhMyGod
#17 Posted : 28 February 2020 10:34:14(UTC)
if you have a tunnel vision the incline doesn't come into the quotation and your problem is solved without doing anything.
#18 Posted : 29 February 2020 09:04:50(UTC)
ThumpUp LOL Scared ThumpUp
Offline GaryTrooper
#19 Posted : 29 February 2020 23:59:22(UTC)
GaryTrooper
Boy this technical ramp discussion just went into decline.Flapper
G - LGB
HO - Marklin
N - Mix of manufacturers mostly Kato
thanks 3 users liked this useful post by GaryTrooper
Offline PeFu
#20 Posted : 01 March 2020 05:22:47(UTC)
PeFu
Really? IMHO, this is a progressive discussion. Cool
thanks 2 users liked this useful post by PeFu
#21 Posted : 01 March 2020 09:22:39(UTC)
I'm inclined to agree with that statement ... Crying Crying Crying
Woodland Scenics Incliners/risers (General MRR)
by FV1974 25/03/2018 22:59:53(UTC)
Inclines performance problems... POWER is the answer.... (H0-scale)
by Guest 20/10/2017 23:51:09(UTC)
37051 rolls freely down inclines. Gravity takes over. (Digital)
by craigericks 27/04/2015 02:10:52(UTC)
M track inclined curves - thoughts (H0-scale)
by Ken Mitchell 12/01/2015 22:28:19(UTC)
What is the absolute maximum % for tracks incline? (H0-scale)
by Janne75 05/07/2014 22:25:24(UTC)
digital operation with grades and inclines (Digital)
by river6109 27/10/2013 04:09:38(UTC)
inclines with HO (H0-scale)
by acwertheim 22/01/2008 23:33:33(UTC)
rebuild incline - Steen layout pic (H0-scale)
by Eisenhower 24/09/2004 00:04:05(UTC)
Incline - 270 degree turn uphill (H0-scale)
by Eisenhower 20/09/2004 22:26:21(UTC)
This page was generated in 1.133 seconds.
