#1 Posted : 16 March 2019 16:07:03(UTC)
I was watching a video, which included some footage of night trains.
It occurred to me that most interior lighting kits, including the ones by Maerklin, focus on lighting inside the compartments and often do not illuminate the washrooms or vestibule of the coaches.
What would it take for a company to come up with a LED strip which included LEDs on one side and on the ends to illuminate the open areas and dimmer LEDs for the compartment areas of coaches?
This would be the most realistic lighting for night coaches, as the corridor and vestibule are usually lit, while the compartments are dark or lit by small reading lights. Additionally, the compartment windows are usually shaded by the curtain/screen when passengers are sleeping.
What do you think?
Offline lewistrain
#2 Posted : 16 March 2019 21:11:47(UTC)
lewistrain
Little strip leds from ebay are so cheap and easy to fit it would not take much work at all to add what ever lights you chose to your coaches. Now tht you mention it, it would be nice to have a random generator on the coach that turns the light on and off in some compartments, maybe turns on outside lights when it stops at stations etc.
But yes, the leds you seek are cheap and plentiful on ebay.
Here are 2 products i recently purchased to make additions to my trains.
ebay
ebay
The wires attached to these things are ridiculously thin, i love them. Also super bright but you can adjust that with resistors etc.
Edited by moderator 17 March 2019 08:31:29(UTC)  | Reason: fixed link
LOLOLOL they are just toys, grow up and play with them.
thanks 1 user liked this useful post by lewistrain
#3 Posted : 16 March 2019 23:03:28(UTC)
Hi .. Lewistrain?
This is surely interesting but I cannot access any of your links.
In Europe a 5 m 12 VDC LED self-adhesive tape can be purchased for 5 Euros (enougth to equip a load of cars):
- must cut to size
- must add a capacitor in parallel to LEDs to stop the flickering
- must add a diode and a current limiting resistor (1 to 2 kOhms) in series when in use with digital feed.
The result is a very low current draw less than 10mA per train.
Alternatively you may pourchse a power supply (5 Euros apiece) anyways the power components are usually hidden in the toilets (IMO)
Offline lewistrain
#4 Posted : 17 March 2019 07:47:31(UTC)
lewistrain
Hhmmmm i cannot seem to get my links to work.
/* Fixed now Smile */
Offline mario54i
#5 Posted : 19 March 2019 10:15:21(UTC)
mario54i
Originally Posted by: lewistrain Go to Quoted Post
Now that you mention it, it would be nice to have a random generator on the coach that turns the light on and off in some compartments, maybe turns on outside lights when it stops at stations etc.
Do you mean something like this ?
Day mode : all lights off
Evening mode : all lights on
Going to bed mode : compartments turning off one at a time at random. Toilets, service room and vestibule always on.
Night mode : compartment off, but someone still awake at random. Toilets, service room and vestibule always on.
Reversing sequence at wake up.
Corridor lights always on.
Not so difficult, just a microcontroller, some LEDs, some electronics and programmig skills Smile
thanks 6 users liked this useful post by mario54i
Offline waorb
#6 Posted : 19 March 2019 13:38:31(UTC)
waorb
Brazil
Hello Mario!
Really nice ones!
Could you share with us the details of what specifically was used and programmed?
Walter
Offline mario54i
#7 Posted : 19 March 2019 14:51:14(UTC)
mario54i
Thanks.
It's not a commercial product, I made it more than ten years ago.
At that time my memory was quite good and I had the bad habit not to take notes, I remembered all details of my designs. Not this way any longer Sad
For what I can remember, the heart is an Attiny84 microcontroller whose outputs are expanded to 32 with the shift-register (HC595) technique. Each HC595 drives directly 8 LEDs. So 32 lights can be turned on/off independently. Up to 28 can be used for compartments, the rest for corridor, tail lights etc. The software knows the position of each compartment (not all 28 LEDs are always used) and controls the sequence of turn on / turn off.
thanks 2 users liked this useful post by mario54i
#8 Posted : 19 March 2019 17:26:55(UTC)
Jean, are you sure?
as far as I understand these LED strips are multiple sets of three LEDs each with their own resistor, with the sets of three connected in parallel.
Each triplet of three might be brought down as low as 10mA, but each passenger coach probably has at least three such sets....
I know my 5m 12V LED strips can draw 2 Amps at full brightness, so I reckon a 2.5M long train could be expected to draw 1 Amp at full brightness. If we were to reduce that to just 10% we still have 100mA.
One of my next projects will be installing lights in my passenger trains and one of my passenger trains is 3.8m long so I need to pay a lot of attention to the amount of current that will be used.
I am also wondering if using 24V LED strips would be better suited to the rectified digital signal, as it would result in less power loss to resistors.
Offline mario54i
#9 Posted : 19 March 2019 18:39:14(UTC)
mario54i
Be aware that 24 V strips have a minimum voltage around 16-17 V. Taking into account the voltage drop across rectifier bridge, it is marginal.
Offline costing
#10 Posted : 20 March 2019 09:35:23(UTC)
costing
I fitted my wagons with ESU interior lights: http://www.esu.eu/en/pro...ing-sets/ntt-h0-digital/ . They are addressable and fully configurable with all kinds of effects ("neon" or "bulbs", random flickering, individual segments on/off). Moreover the tail lights turn on/off with the direction of the travel, so you can make a nice consist with them.
thanks 1 user liked this useful post by costing
Info on wiring Viessman coach lighting decoder 5077 (Digital)
by fabstar68 20/08/2024 19:30:02(UTC)
Coach lighting control? (Digital)
by Puttputtmaru 24/07/2024 19:34:33(UTC)
Will this work? battery magnetic switch led coach lighting (Model railroad wiring)
by marklinist5999 31/01/2023 23:52:01(UTC)
Train Tech coach lighting (H0-scale)
by Michael4 19/11/2020 12:59:14(UTC)
Coach Lighting Product (Model railroad wiring)
by Hannes Porsche 28/07/2020 00:34:39(UTC)
Unknown coach lighting accessory - brand? (Collector's Corner general)
by cookee_nz 01/01/2020 03:04:38(UTC)
Interior coach lighting (Model railroad wiring)
by DaleSchultz 29/04/2019 18:14:39(UTC)
Lokpilot, coach lighting & current conducting couplers (Model railroad wiring)
by morsing 29/10/2018 20:33:02(UTC)
Review of Train-Tech Coach Lighting (Accessories reviews)
by sidblack 08/09/2018 10:01:51(UTC)
26922 Coach Lighting Problem (H0-scale)
Belarus dickinsonj 13/02/2017 21:07:15(UTC)
Coach Lighting (H0-scale)
by amunro 10/11/2015 18:03:59(UTC)
Coach lighting for IC 2000 coaches (General MRR)
by charles Sharpe 02/04/2013 06:58:27(UTC)
Coach lighting kits for 4022, 4023, 4024, 4026, 4027, 4029 , 4052 (Collector's Corner general)
by BrandonVA 14/03/2012 14:05:05(UTC)
Coach lighting question (Digital)
by LaurryG 26/03/2011 07:59:47(UTC)
Coach Lighting Pickup Shoe Short Circuiting Under Digital Operation (Digital)
by aos 05/03/2011 18:19:00(UTC)
42941 Riviera Express coach lighting (H0-scale)
by GSRR 17/12/2009 18:38:24(UTC)
Elektor magazine - Model Coach Lighting Decoder (Digital)
by DamonKelly 25/05/2009 15:06:21(UTC)
INOX Coach lighting (H0-scale)
by mrmarklin 03/02/2008 07:31:51(UTC)
Ultimate coach lighting? (Digital)
by Rudi Bekkers 26/04/2006 22:10:11(UTC)
F7 controls passenger coach lighting (H0-scale)
by hmsfix 20/02/2006 02:02:11(UTC)
Coach Lighting (General MRR)
by David Dewar 02/03/2004 00:12:27(UTC)
by David Dewar 15/02/2004 17:27:06(UTC)
by Chris Vella 17/10/2003 11:49:40(UTC)
This page was generated in 0.618 seconds.
