Offline Dickrep
#1 Posted : 14 January 2019 16:37:54(UTC)
Dickrep
I have a problem with the variable side of a Marklin 6646 (110v, HO) transformer. The fixed side seems to work properly. Is there a way to remove the cover and check the inside of this transformer?
or can you recommend anyone who will offer repair service?
Dick
Edited by user 14 January 2019 21:49:12(UTC)  | Reason: Not specified
#2 Posted : 14 January 2019 18:54:37(UTC)
What is the nature of the problem? Is there a dead spot or other similar issue with the dial or is it a contact issue (no output or intermittent output)?
#3 Posted : 14 January 2019 21:17:56(UTC)
Dick
Hi Dick,
With the greatest of respect, Transformers are dangerous items. Please ensure you are confident and skilled in this area, otherwise seek a skilled professional.
But... even if you do, unless they've seen one before it's highly likely they will say to you "how do you open it" :-)
The problem is most likely that the flexible wire from the wiper control has detached. The actual repair is simple and it's been discussed here before, I just don't have time at the moment to find the previous topics.
But basically it involves extracting the four small white plugs, two either side. A common trick is to drill a small hole, then screw in a small sharp self-tapping screw to grab the plug then pull it out.
But as I said, maximum care and I am not responsible for the perm you may acquire should you poke in the wrong place!!! BigGrin
If no one else posts the previous topic/s I'll try to find them later tonight.
Steve
Offline Dickrep
#4 Posted : 14 January 2019 21:52:16(UTC)
Dickrep
there appears to be no output from the transformer...on this variable side. I would be happy if someone can recommend a competant repair person.
Offline Danlake
#5 Posted : 15 January 2019 06:15:25(UTC)
Danlake
Hi Dick,
Here is some older post regarding possible repair solutions:
https://www.marklin-user...r-6646-is-having-trouble
And is this one scroll down to last post to see some photos:
https://www.marklin-user...Transformer-Problem.aspx
My advise would be to try and take the plastic cover off (as suggested in post) and then take it to a local electronic repair shop to see if they can do the repair for you?
Best Regards
Lasse
Marklin 6646 transformer (H0-scale)
by Keim 09/03/2023 07:56:59(UTC)
Connecting a C-Track layout to a 6646 Transformer (H0-scale)
by waterslip 02/01/2019 00:46:37(UTC)
6646 Transformer for power w/MS2? (Digital)
by mcnall 10/03/2018 19:13:51(UTC)
Looking for 6646 Transformer (General MRR)
by DB Fan 18/10/2017 03:06:06(UTC)
Question Re: 28970 Glaskasten and 6646 Transformer (Collector's Corner general)
by TheFatTick 12/03/2015 19:30:14(UTC)
HO Starter Sets with 6646 Transformer (H0-scale)
by GSRR 09/03/2009 23:21:30(UTC)
This page was generated in 0.394 seconds.
