Welcome Guest! To enable all features please Registers on the forum or Registers.
11 Pages«<56789>»
Offline Macfire
#301 Posted : 26 August 2008 02:39:21(UTC)
Macfire
No.2 sounds good to a non-geek like me Denny
Lord Macca
Offline soren36
#302 Posted : 26 August 2008 05:20:20(UTC)
soren36
A hint from a US dealer:
"Marklin Central Station 2
We have received the first information about the next generation Central Station. Biggest differences will be a color touchscreen, and improved digital system. The CS2 is still in design stages. No delivery dates are available. Remember, we are still waiting on the systems booster!"
A Connecticut Yankee
Offline Maxi
#303 Posted : 26 August 2008 05:25:19(UTC)
Maxi
The real question is how long will the new CS take to power up and be ready for use compared to the current CS.
#304 Posted : 26 August 2008 09:45:09(UTC)
Google translation of the Marklin Press Release referenced on the http://www.modellbahn-kurier.de site, together with the best picture yet of the CS2 (I have not compressed or reduced the size, so you can get a good look at the screen).
"News of 25.8.2008:
The new Central Station 60213 of Märklin is here!
With incredible performance, comfortable, convenient and highly compatible, as Märklin promises
(PM) The new Märklin Central Station (CS 2), specialists in the Märklin electronics development creates, covers more uses than all previously known systems. It is another big step in the comfortable future of the management of complex model railway facilities and also smaller facilities for maximum fun.
Another advantage of the unbeatable guiding Control Center is the compatibility with digital control components of the digital systems of Märklin predecessor. All devices can weiterbenutzt and into the new system. Supports will benefit from this central unit Märklin digital formats of the Control Unit 6021 and the current mfx format.
For each locomotive a color picture…
The fundamental newly developed device has a color display and two integrated Fahrpulte the set running speed round speedometer meters. The speedometer may wish with a color picture of the Lok access is to be fixed. Depending on the locomotives Decodertyp Report itself (mfx locomotives), an integrated database of selected (Märklin Delta locomotives and digital) or manually. This requires user interface is very easy to understand and well designed. In addition, there is the possibility that Lokdaten integrated card reader by cheque cards. Each locomotive can an individual information card with all relevant data can be created. This simplifies the application to another system or re-dialing game during the operation.
Please click to zoom!
The configuration of the individual Lokparameter done in a separate operation menu in the background without technical knowledge of Modellbahner the driving characteristics of the locomotives to its needs can vote. Even in earlier Märklin Delta and digital models without high-performance drive, the starting and Bremsverzögerung. This scheme will be travelling from the Central Station. If desired, the vehicles are also in the automatic shuttle trains with 2 points and an intermediate stop can be used. The knobs and switches are functional and are ergonomically designed with their specific surface structure well in hand. Integrated click stops gives a precise position sense, turning the driving control. The function switches are characterized by a unique switching.
The Central Station in the integrated power amplifier (booster) provides a maximum output current of up to 3A. For larger power requirement of the plant can either previously offered booster 6015 or 6017 or the new booster used 60173. The booster 60173 is optimized for operation with the Central Station vote. For example, on display in a display of the new Central Station the output voltage, the output current and the temperature of this power amplifier control.
20 integrated Magnetartikelstellpulte (keyboards) without allowing input of magnetic product data directly, trying umweglose of magnetic articles. The user interface of this scope can also draw on the existing magnetic article types (Soft, signal, etc.) that are being addressed. The Märklin digital hub is in the access of the new headquarters. 13 integrated Fahrstraßenstellpulte (Memory), each with 32 routes, both manually and on the feedback module s88 of the trains auslösbar. Automatic or safety circuits such as the block-haul operation, the shadow station control etc. can be as simple as realizing a comfortable plant control, which repeatedly running the same operating steps with a touch of a button done.
For the first time at a track Märklin Mehrzugzentrale integrated image-setting panel (layout), the individual magnetic circuit for the article and the routes of memory as well as the re-registration contacts s 88. The user interface is in relation to the clarity and Schaltkomfort an optimum plant control dar. With the Gleisbesetzmeldung can also detect whether a train track in certain areas. Especially for concealed installations areas of high profit.
A simple USB stick is sufficient for data backup…
The Ethernet interface allows the connection and a PC via the USB interface allows a PC mouse, a keyboard or a memory stick to secure the CS settings can be connected. To save the individual external plant data is therefore no longer mandatory PC. A simple USB stick is sufficient for backup.
Apart from other Central Stations 60213 as additional terminals is also the mobile station and a special adapter on the existing Central Station 60212 and the Control Unit 6021 with its affiliated operator connected and thus further. The user interface of the entire layout can be tailored to their own wishes and needs. The operation by several people, so that no problem from the stand-alone solution for a small investment to networked control panels in a large plant is a wide spectrum implement.
The Central Station can easily via the Internet or via appropriate data on a USB stick in the future be updated. This entire process was designed so that users without computer skills that can easily carry. The new digital Märklin Central Station therefore has more than 37 individual components, which the former Digital System had to be purchased separately. These are not new Gleisbildstellpulte included in this form is not yet available.
Download further information
Overview System Architecture (PDF File)
Source: press release of Märklin "
And here's the new CS2 architecture:
Edited by moderator 11 January 2011 20:01:18(UTC)  | Reason: Not specified
Offline fvri
#305 Posted : 26 August 2008 10:53:17(UTC)
fvri
Thanks Dave,
Seems to me a 'fake' display...Smile
'a track Märklin Mehrzugzentrale integrated image-setting panel (layout)...' does this mean a grid layout of your track.
BTW. ESU has released firmware V1.1.3 for the ECoS.
Frank
Offline grr_1954
#306 Posted : 26 August 2008 11:06:26(UTC)
grr_1954
Is time for a new, improved Mobile Station (wireless?) according with the new design of the new Central Station?
Gerardo Rivero,
San Fernando, Cádiz, Spain.
#307 Posted : 26 August 2008 12:02:20(UTC)
The first prototype of the New Improved Wireless Mobile Station is already being tested in Mullerup:
Offline fvri
#308 Posted : 26 August 2008 12:18:58(UTC)
fvri
Hi Lutz,
Will the CS2 be an 'open system' providing a PC Interface protocol for external (thirdparty) software or will it be a 'full' standalone entity providing full layout management and control (such as currently provided by MRR software).
-PC connection only for firmware upgrades??
-The 'layout' display??
Frank
Offline tekin65
#309 Posted : 26 August 2008 12:57:16(UTC)
tekin65
Turkey
Frank hi,
Since the comm. will be via ethernet, I tend to think that M* would provide the protocol to software programmers ... or am I too optimistic?
Cem.
Now all eras but no ICE
Offline fvri
#310 Posted : 26 August 2008 13:11:02(UTC)
fvri
Hi Cem,
I hate to be part of making speculations...[:I] But, I think you are too optimistic wink. M did not do it for the CS1 why do it than for the CS2.
But if layout management is part of this new CS then the days are counted for MRR software (cfr. Viessmann's Commander).
BTW. mid September I'm visiting Istanbul for a whole week... I only hear the best from people that have visited this city.
Frank
#311 Posted : 26 August 2008 13:18:39(UTC)
Very nice wireless controller, Per!
Offline fvri
#312 Posted : 26 August 2008 13:23:54(UTC)
fvri
Hi Per,
Indeed a very nice gadget. I thought it was a new Scandanavian mobile next to Nokia... Ericson.Smile
Frank
Offline tekin65
#313 Posted : 26 August 2008 14:58:29(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by fvri
<br />BTW. mid September I'm visiting Istanbul for a whole week... I only hear the best from people that have visited this city.
Great, make room for a cup of coffee then! If you can spare more time I can take you to see an amazing layout.
The MM protocol is already known, ethernet makes everything easier.
Cem.
Offline fvri
#314 Posted : 26 August 2008 15:16:01(UTC)
fvri
Hi Cem,
Thank you for that friendly offer that would be great indeed! I think my wife won't mindwink. I'll keep you informed.
Frank
Offline tekin65
#315 Posted : 26 August 2008 15:47:34(UTC)
tekin65
Turkey
Hi Frank,
Just drop me a note - mail address in my profile is up to date. In the worst case join our forum at www.marklinciyiz.biz/forum and drop me a pm (link to pages in English - upper right).
Cem.
Offline Maxi
#316 Posted : 26 August 2008 16:08:23(UTC)
Maxi
Hi Matthew,
this was already the case with the current Central Station. wink
This is true but in the CS2 that could have changed and it is nice to see that it has not.
[size=1" face="Verdana" id="quote]quote:The "original CS" (assuming we talk about the current Central Station #60212 and not the former Control Unit #6021) is NOT connected the new Central Station2 via I2C. The only existing I2C data flow ends in the newly developed translation box Connect-60128. wink
I was referring to the 6021 in my statement. I am fully aware that the 60212 only listened to what commands the 6021 put out via a sniffer port and it was strictly a one way path. I suppose with out using part numbers in the statement it would get some what confusing as to which apple is being compared to which orange.
Offline fvri
#317 Posted : 26 August 2008 16:37:59(UTC)
fvri
<br />Hi Lutz,
Frank
Hi Lutz,
Thank you for the better 'English' translation although it was understandablewink.
Could you please give your opinion regarding my question?
Frank
Offline supermoee
#318 Posted : 26 August 2008 16:39:43(UTC)
supermoee
look at these pictures of a real, existing CS2
http://www.modellcentrum...l/central_station_2.html
it has a Sx protocol plug. DCC should not be far wink
rgds
Stephan
Offline mascagni
#319 Posted : 26 August 2008 16:44:22(UTC)
mascagni
I guess that this means CS2 is not multi-protocol. Am I correct in this assumption?--MM
Michael Mascagni, Tallahassee
Offline supermoee
#320 Posted : 26 August 2008 16:46:21(UTC)
supermoee
why not? the CS1 was also multiprotocol. MM and mfx.
now CS2 seems to support Sx, one protocole more wink
rgds
Stephan
Offline tekin65
#321 Posted : 26 August 2008 16:52:52(UTC)
tekin65
Turkey
Hi Lutz,
Thank you very much for the translation - much appreciated. Any guesses about the price of this new toy?
Cem.
Offline tekin65
#322 Posted : 26 August 2008 17:18:03(UTC)
tekin65
Turkey
[size=1" face="Verdana" id="quote]quote:Originally posted by supermoee
<br />now CS2 seems to support Sx
The hell is SX? A new thingie?
Cem.
Offline supermoee
#323 Posted : 26 August 2008 17:23:15(UTC)
supermoee
Hello Cem,
SX is the Selectrix Protocole of Trix.
kind regards
Stephan
Offline tekin65
#324 Posted : 26 August 2008 17:39:39(UTC)
tekin65
Turkey
Stephan hi,
Thanks. Now that M* is including the SX in new CS2 why not including DCC too, i wonder? That would only give CS2 the edge against other controllers ...
Cem.
Offline supermoee
#325 Posted : 26 August 2008 18:01:39(UTC)
supermoee
Hello Cem,
who knows? Maybe DCC is already in? Now we cannot tell.
let's wait and we will know.
rgds
Stephan
Offline DasBert33
#326 Posted : 26 August 2008 18:11:08(UTC)
DasBert33
This looks VERY interesting. I am genuinly impressed (as I probably will be too by its price in the near future). IF it has DCC (which would not be that surprising anymore) and works stable (no Commander stories plz) you can count me in as a customer!
Bert
Offline tekin65
#327 Posted : 26 August 2008 18:16:46(UTC)
tekin65
Turkey
I guess I'll be interested too ... this gadget is way too cool.
Cem.
Offline jeehring
#328 Posted : 26 August 2008 18:31:46(UTC)
jeehring
Bigdaddynz & Lutz Hemmerich , thank you so much for the nice picture & explanations .
Offline Davy
#329 Posted : 26 August 2008 18:54:24(UTC)
Davy
The story is now also on the Marklin website.
http://produktadmin.maer...ilung_CentralStation.pdf
M-track with a CS2.
#330 Posted : 26 August 2008 19:22:09(UTC)
Amazing...!
But still no information about Trix CST2...
Sx hmmm...
It should been standing DCC too in the behind of CST2.
But input for DCC is not correct anyway...!!!
I think that Trix will also soon presentation theirs own CST2.
I like screenplay of CST2...!
The old CS can throw against the wall now...!
#331 Posted : 26 August 2008 19:23:41(UTC)
I have added 60213, 60173, 60128, 60123, and 60121 to Marklin delivery list, See 'News from Marklin' topic.
#332 Posted : 26 August 2008 21:48:10(UTC)
I wonder who one of you will become the first to have CST2...
Good luck to race...
#333 Posted : 26 August 2008 22:26:06(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by jeehring
<br />to know if CS2 will include something based on Real Time OS or not, whatever Linux or Windows
Do we have an answer for this one, already confused
#334 Posted : 26 August 2008 22:54:33(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Goofy
For sure not on Märklin's website. biggrin
[size=1" face="Verdana" id="quote]quote:I think that Trix will also soon presentation theirs own CST2.
So why don't you look there?
Marklin don´t have information about CST2 yet in theirs site...!
Trix will also presentation,but the question is just when...!
Goofy Cool
#335 Posted : 26 August 2008 22:55:53(UTC)
Which "race"? Cool
Are you sleeping...?
Goofy Cool
#336 Posted : 26 August 2008 23:05:12(UTC)
Now you are really sucks,Lutz...! [:(!]
It´s up to yourself to been in race or not...!
And besides,what on the hell shall you presentation me with an clown face for...? [xx(]
I´m understanding now why Steventrain has or did(?)trouble with you.
No sense of humor...
#337 Posted : 26 August 2008 23:06:51(UTC)
Stephan Thanks for up date and pics from one of my German dealers.
Hopefully we can hear about some start sets for the Christmas season. I see Marklin has announced it exists weeks after it appeared on the net.
Looks interesting.
david
PS remember the old 60212 is not discontinued so keep buying lol
Offline Kifobefa
#338 Posted : 26 August 2008 23:10:57(UTC)
Kifobefa
<br />Amazing...!
Sx hmmm...
What make you think there will be a TRIX CS2, if you need one go for the Viessmann Commander or the ESU EcoS. Are there anything special you want from the "TRIX CS 2"
/Berndt
#339 Posted : 26 August 2008 23:15:12(UTC)
<br />remember the old 60212 is not discontinued so keep buying lol
Please don't forget our Cave's special [:p] for today: €99,00 !!! (get two for only 300,00) biggrin
#340 Posted : 26 August 2008 23:21:42(UTC)
John. Will the new CS tempt you to change if it stands up to tests here on the forum.
David
#341 Posted : 26 August 2008 23:25:32(UTC)
Of course, David - for our Grandkids' big layout Smile
But only when it comes in a starter set where I do like the loco(s) ...
Offline jeehring
#342 Posted : 26 August 2008 23:28:20(UTC)
jeehring
<br />Amazing...!
I do like it too . Very much .
It is sober , clear . Only helpful tools are shown on screen , it seems they have expelled all needless access & tools , all which is not necessary ....
Reading specifications and so...At first sight it looks to be a serious product...
#343 Posted : 26 August 2008 23:30:58(UTC)
John If it were to come with a USA start set where the controller is almost free I reckon it could generate a fair number of sales in the US. Marklin really needs to start selling to the worlds largest economy.
David
#344 Posted : 26 August 2008 23:33:42(UTC)
Yep, David. PA-1 NYC freight & MIKADO old-style NYC passenger train [:p]
(excerpt from another masterpiece picture by Al Cool)
#345 Posted : 26 August 2008 23:47:25(UTC)
What is the price on CS2?
#346 Posted : 27 August 2008 00:36:41(UTC)
Hello, my name is C2S2.
Smile
Offline DasBert33
#347 Posted : 27 August 2008 00:38:44(UTC)
DasBert33
<br />Hello, my name is C2S2.
Smile
Now that looks like its evil! biggrin
#348 Posted : 27 August 2008 00:55:53(UTC)
<br />UserPostedImage
Reminds me of those erasers in "Tron" ... biggrin
#349 Posted : 27 August 2008 00:55:54(UTC)
<br />I'm not sure if everyone would understand the following sentence: "The Märklin digital hub is in the access of the new headquarters." biggrin
We sort of get the 'drift' (idea) from the Google translation, but that still does not beat a skilled human translation. Thanks very much for doing this Lutz, very much appreciated. Like you I won't be in a rush to buy a CS2, maybe later on when it has matured and all the other architecture components have been delivered or announced. I don't see any major enhancements or features (given what we know about the CS2), just some incremental improvements. Like John, a starter set may be the incentive to get one. For now, the CS1 is fine for my needs.
#350 Posted : 27 August 2008 01:14:17(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Kifobefa
<br />Amazing...!
Sx hmmm...
/Berndt
You must understand little better,Berndt...!
Trix did announced an own CS,but did not arrived out in the market of Marklins decides.
Why not...?
Because of the new CST2...!
Did you understand now,Berndt...?
New Central Station 3 owner help! (Digital)
by stevenh905 24/11/2024 03:46:00(UTC)
New Central Station (Digital)
by oranda 30/03/2020 14:46:05(UTC)
New Central Station (CS2) app (Digital)
by Oscar0645 03/09/2012 11:26:44(UTC)
Maerklin new Central Station App for iPad, 2012 (Digital)
by river6109 10/02/2012 10:50:18(UTC)
11 Pages«<56789>»
This page was generated in 1.203 seconds.
