Offline nomda777
#1 Posted : 10 January 2015 18:20:34(UTC)
nomda777
Hello everyone,
I'm new to this site and Marklin in general and I would like to ask your expert opinions if you don't mind for the following:
1. I'm planning to buy the upcoming Swiss starter set that comes with an MS2 controller and my question is will the power supply work in the UK?
2. Can i use the MS2 to control my existing US locomotives, currently i have NCE powercab controller?
3. Can i do consisting for MS2 as i would like to simulate multiple traction just like SBB?
4. Can i combine different wagons e.g. Marklin and Roco without changing wheels and couplers? As much as possible i don't want to change stuff as my sight is getting poorer.
5. Is the C-track reliable as currently i don't have space in the house so i'll just resort to carpet layout so there will be frequent tearing down of the layout?
6. I read in the forum that the loco that will come in for the new Swiss set is AE610 Cargo which i really like. Do you know if this is a good locomotive in terms of running quality and fidelity against the prototype?
Apologies for so many questions and thank you very much.
Rodel
By the way i've choosen Marklin as my primary locomotive brand because they produce models in metal and they have great history.
#2 Posted : 10 January 2015 19:24:04(UTC)
Originally Posted by: nomda777 Go to Quoted Post
Hello everyone,
Yes - assuming you buy the set in Europe it will come with a 230V power supply that has a European plug. You can get adapter plugs to fit to European plugs so they can readily be used in the UK, although if careful the European plug can be put into a UK power socket without an adapter. This is not recommended if children are to use the set.
Yes, but - your loco is probably a 2 rail loco. The marklin system uses a row of studs between the rails to supply the power to the train, and both rails are used for the return. A two rail system has one rail supplying the power and the other as return, so the loco will not run on Marklin track without modification. The MS2 controller will run DCC controlled locos, so it is suitable to use as a controller on a DCC system.
Rodel
In view of the two questions I have answered, rather than step through the other questions I would suggest you look at the equivalent set as marketed by Trix. TRix items are (for the most part) Marklin items but made for two rail operation. You should be able to find a Swiss start set in the Trix range which also has an MS2 controller.
The Trix C Track is a two rail version of the Marklin C Track.
#3 Posted : 10 January 2015 19:31:09(UTC)
Hi, Rodel!
It works with 230 V. I don't know if the plug will fit.
The MS2 supports DCC with functions F0 through F15.
Not when using mfx. Can be done for DCC.
I never swap wheels for Roco cars. But you will get problems with Märklin couplers.
See also:
http://blog.mailez.de/eblog/?p=65
C track made in the last 10 years is reliable.
Märklin fans will tell you it is a great loco. HAG fans will tell you the HAG model is closer to the prototype. The motor may be a bit noisy.
Offline Renato
#4 Posted : 10 January 2015 19:58:50(UTC)
Renato
Hi Rodel,
Welcome to the forum.
Renato
#5 Posted : 10 January 2015 20:23:56(UTC)
Transformer black 66361 or grey box 60061 should be fine.
Marklin do not intend the 60052 to be used in the UK. I have two 60052 transformer dead more that five years ago.
Offline nomda777
#6 Posted : 11 January 2015 13:54:10(UTC)
nomda777
Thank you very much for the welcome and answers to my questions.
@kiwiAlan, i was looking at the Marklin rather than Trix so that i can avoid the pain of dealing with reverse loop.
@Tom, it seems that Hag doesn't produce much Swiss locomotives as i've looked into Ebay and didn't see much. Most of the stuff that are being sold are more than 10 years old and i don't want to pay premium for an old model.
@steventrain, thank you for giving me the power supply part number so i guess i'll just go for the starter set and in case it breaks then i'll buy as suggested. Also i've noticed that you are very knowledgeable of Marklin do you know when Set 29484 will be out? Do i have to wait for months?
One more question, does "modellbahnshop-lippe.com" reliable shop online? Are there other online shops that you can recommend in terms of reliability, pricing and service?
#7 Posted : 11 January 2015 17:33:33(UTC)
I haven't personally dealt with Modellbahn Lippe, but I believe others here have, so I will let them give you the benefit of their experience.
Personally I have frequented Lokshop (click) and Modellbahn Kramm (click), with Lokshop being my preferred source. A number of the folk here also use Lokshop. Both of these shops have real store fronts and both have a good command of English language.
Hag produce almost exclusively Swiss locos, but in recent years I believe they have been in the doldrums, and may have gone into liquidation. I believe there is a couple of attempts at reviving the company, but there are others here with more knowledge of that.
OK, I can now understand why you wish to use Marklin, but without further investigation your existing models may not work with it without modification, as I noted in earlier post.
Offline PMPeter
#8 Posted : 11 January 2015 17:52:33(UTC)
PMPeter
I have bought from MBSL several times and they have great service. However, I have recently found that Lokshop prices are consistently cheaper with the same level of service.
Offline GDJTrain65
#9 Posted : 11 January 2015 19:26:08(UTC)
GDJTrain65
In my opinion Lippe is very reliable and I can without doubt recommend that store. I have bought lots of stuff from them and I have never had any problem of any kind at all with them.
New to marklin What is a Reed switch? (Model railroad wiring)
Belarus brudon82 16/04/2022 22:48:19(UTC)
New to Marklin Digital - Need reference books (Digital)
by nzrabbitty 13/07/2019 00:40:59(UTC)
Completely new to Marklin HO Scale (H0-scale)
by grahame 23/12/2018 14:12:18(UTC)
New to marklin (General MRR)
by Billg 30/09/2018 16:43:22(UTC)
New to Marklin....kind of (General MRR)
by Steve1434 18/07/2016 17:20:08(UTC)
new to Marklin (General MRR)
by Chris Dunn 17/05/2016 00:40:34(UTC)
New to Marklin (but not to MRR) has some questions (H0-scale)
by kokomo 28/04/2014 21:28:54(UTC)
Help I am new to Marklin (Model railroad wiring)
by grdnsal 16/09/2013 22:01:56(UTC)
New to Marklin and I inherited an old Marklin Train Set, Please help me figure this out. (General MRR)
by Marklin3200 06/01/2013 03:36:20(UTC)
New to Marklin and loving it (General MRR)
by neo78 03/01/2009 16:00:49(UTC)
New to Marklin Digital can you help (Digital)
by David Dewar 01/02/2004 00:31:01(UTC)
This page was generated in 0.472 seconds.
