Offline charles Sharpe
#1 Posted : 31 March 2014 08:04:07(UTC)
charles Sharpe
Hello.
Can a loco with a esu v4 decoder in it run with a cs1 that went back to Marklin to be upgraded.
Charles
CHARLES SHARPE
#2 Posted : 31 March 2014 08:16:03(UTC)
It should run with either the Motorola 28 or Motorola 14 setting.
If it's an ESU V4 M4 decoder, it should register automatically and run using mfx.
#3 Posted : 31 March 2014 10:09:28(UTC)
charles Sharpe
Hi.
Are you saying the code can be 28 or 14 if so that is no good because I have no way to reprogram it to run on the CS2.
Charles.
CHARLES SHARPE
#4 Posted : 31 March 2014 10:41:04(UTC)
That's no problem: the CS2 does not implement 28 speed steps for Motorola protocol anyway, but with Motorola protocol the decoder runs automatically on either 14 or 28 speed steps without re-programming.
So with the CS1 you can use Motorola 28 or Motorola 14, with the CS2 you can use DCC with either 14, 28, or 126 speed steps or Motorola protocol (with 14 speed steps).
#5 Posted : 31 March 2014 10:48:22(UTC)
charles Sharpe
You have lost me on this .I know about speed steps but that is it.
Charles
CHARLES SHARPE
#6 Posted : 31 March 2014 11:28:23(UTC)
Don't worry about it, the answer to your original question is Yes.
Guest (5)
Adding stayalives to ESU decoders. (Digital)
by lewistrain 27/04/2019 04:31:23(UTC)
Esu decoders parameters (Digital)
by foumaro 24/02/2018 06:33:42(UTC)
Cheap USA (or EU for that matter) Source for ESU Decoders? (Digital)
by 5HorizonsRR 13/10/2017 16:47:59(UTC)
Chokes on Esu decoders? (Digital)
by Danlake 24/05/2017 22:19:15(UTC)
LEDs for use with ESU decoders (Digital)
by IsItDigitalAlready? 04/03/2015 21:59:50(UTC)
ESU Decoders - Upgrade (Digital)
by camcath 03/05/2014 09:07:14(UTC)
ESU decoders versatility (Digital)
by river6109 25/07/2012 14:11:58(UTC)
Mixed results tonight with ESU decoders and CS2 and advice sought (Digital)
by ac jacko 13/04/2012 16:46:18(UTC)
Problem with MS2 and ESU decoders (Digital)
by anthpao 29/12/2011 13:19:30(UTC)
Help with Problem with ESU Decoders in train consist (Roco BLS 420 & Liliput EWIII AC) (Digital)
by mike c 19/09/2010 02:48:09(UTC)
Converted locos with 5 pole motor and ESU decoders (H0-scale)
by river6109 19/07/2010 19:43:17(UTC)
Programming of ESU decoders with MS (Digital)
by Hemmerich 25/03/2009 22:55:34(UTC)
This page was generated in 0.294 seconds.
