Offline Mike M
#1 Posted : 18 December 2013 22:04:00(UTC)
Mike M
Here is a silly question,but I like to be clear on this once and for all. When creating a common ground.does that mean I can take the brown wire from the original scource and connect to my distribution panel and then run another wire to the next ditribution panel? For the light transformer after connecting a brown wire to my distribution panel,should I also connect the brown wire to the distribution panel for my track power including the booster and CS2 power?In other words daisy chain all of the brown wires to each scource.I am using C track.
Reason I am asking is one of my turnouts is doing weird things,it only works sporadicaly but works fine on my programming track.This problem started when I hooked up my track end stoppers,so I am trying to isolate this problem.Right now I have run the groung wire as mentined above.
Any help would be greatly appreciated.Confused
Offline BrandonVA
#2 Posted : 18 December 2013 22:18:52(UTC)
BrandonVA
Mike,
I'm not sure the cause of your problem, but a common ground should be no problem.
All brown (ground / negative) wires should be able to be shared.
On my layout I have a 7209 distribution box (it wouldn't matter if it was any kind of distribution box, Marklin or general electronics). I have the following plugged into this box:
-MS 2 Ground from 60113 "track box"
-Track grounds
-Turnout grounds (including turnouts with built-in lanterns, all K track in my case)
-Analog transformers (6646) (supply lighting and track power)
-Additional 7209 (more grounds)
I have an on-off-on toggle that moves the red (B or +) from 60113 to 6646 to switch between analog and digital. I just supply this last bit of info to clarify why 6646 and 60113 share a ground outside of lighting. I also have it set up so I can run my shunting yard analog while the rest of the layout is digital. Common ground does not cause an issue under any of these configurations.
I also connected my father in law's layout in a similar way. Ground for 60113 and 6646 the same. "Positive" isolated. In his case 6646 just powers turnouts and turnout lanterns, never the track. The turnout lanterns do not flicker with the exception of one that had a bad connection. After improving the ground connection, it stopped flickering (it was loose).
-Brandon
thanks 7 users liked this useful post by BrandonVA
Offline biedmatt
#3 Posted : 18 December 2013 22:21:50(UTC)
biedmatt
I generally resist answering questions like this because 1. I may not fully understand your description/question or 2. You may have poorly worded your question. I am not saying you do not understand english, it's just easy sometimes to write something that makes sense to yourself, then someone ask "well what if..." and then you realize you worded your question poorly. The net result is damaged electrical equipment.
You can tie the grounds (brown) wires from several power sources together without trouble and make the ground wiring simple and easy to maintain. Never, ever connect the hot (yellow or red) from multiple power sources together. These must always be isolated from each other.
Matt
Era 3
thanks 5 users liked this useful post by biedmatt
Offline BigBoyChief
#4 Posted : 24 October 2025 04:13:01(UTC)
BigBoyChief
Mike,
-Track grounds
-Brandon
I’m re-building an old m track layout and upgraded to digital, and was thinking of exactly this design to flip back and forth digital and analog and it makes sense. Will update once done!
(Old analog transformer powering only accessories, tied into ground of 60113 when running digital), notably the level crossings.
Common ground (Digital)
by Pfalzbahn 11/07/2020 16:18:00(UTC)
Marklin devices and "common ground" in rails and/or sharing power (Digital)
by fje 04/02/2015 18:18:37(UTC)
Common Ground (Digital)
by PMPeter 07/11/2014 06:00:19(UTC)
Common ground k83 (Digital)
by Gregor 12/02/2009 14:07:20(UTC)
ECOS and common ground (Digital)
by Hobbit 05/11/2008 04:51:56(UTC)
eCOS and Common Ground (Digital)
by xxup 31/12/2007 13:24:34(UTC)
Common Ground? (Digital)
by elsleuth 18/12/2007 03:10:04(UTC)
This page was generated in 0.407 seconds.
