Joined: 30/08/2012(UTC) Posts: 78 Location: Northern Ireland
I was wondering is it possible to convert 2 rail to 3 rail or should I just put in an extra line for 2 rail locomotives. I am wondering this because I would like one of these  but they are 2 rail. Any help. Can I use c track and connect a DC controller to it and then run DC locos there, thanks :)
Joined: 23/08/2006(UTC) Posts: 2,597 Location: Beverly, MA
Hi all, Jeff,short answer-yes. Your problem would be mounting a slider(s) on this set.Not impossible.
Dr D
Joined: 16/02/2004(UTC) Posts: 15,450 Location: DE-NW
Maybe Rivarossi make (or will make) a 3R version of the set. If not, either modify the train (as our good Dr recommended) or modify Märklin tracks for 2R operation (easy with C and K track except for some turnouts).
Or feed the DC train from catenary (but don't buy DC diesel or steam locos if you go this way (will also work with DC street cars)). |
 2 users liked this useful post by H0
Originally Posted by: H0  Maybe Rivarossi make (or will make) a 3R version of the set. If not, either modify the train (as our good Dr recommended) or modify Märklin tracks for 2R operation (easy with C and K track except for some turnouts).
Or feed the DC train from catenary (but don't buy DC diesel or steam locos if you go this way (will also work with DC street cars)). Hi all, Good post,as usual Tom! Yes,Rivarossi may make this in a 3 rail version,or you can run it as Tom suggests. Dr D
Thanks guys, could I have a two lane layout, one with marklin and then one with two rail DC. Is it easy to convert marklin c track to be DC. thanks
 1 user liked this useful post by BigJeffyLawd
Originally Posted by: BigJeffyLawd  Thanks guys, could I have a two lane layout, one with marklin and then one with two rail DC. Is it easy to convert marklin c track to be DC. thanks Hi Jeff,all, Yes,I think with C you have to isolate the running rails from each other.(?) Dr D
Thanks, I may buy some European DC track and then have a one marklin track and one DC track, what do you think
Originally Posted by: BigJeffyLawd  Thanks, I may buy some European DC track and then have a one marklin track and one DC track, what do you think Hi Jeff,all, Sure!  leaning toward any brand? Dr D
Hi Jeff,all, Sure!  leaning toward any brand? Not really, there just seems to be lots more brands but I think I will keep it all 3 rail and start off on an 8 x 4 layout and then move up. It seems easy enough to get AC versions of locos though as I already fancy some. I have acually been on more German Trains than Northern Irish Trains!
Joined: 01/03/2008(UTC) Posts: 2,883 Location: South Western France
Originally Posted by: BigJeffyLawd  I was wondering is it possible to convert 2 rail to 3 rail or should I just put in an extra line for 2 rail locomotives. I am wondering this because I would like one of these ... but they are 2 rail. Any help. Can I use c track and connect a DC controller to it and then run DC locos there, thanks :) Hi, I figure it is probably the unit with pantograph that is powered. Right? It is possible in 99.9% of the cases to mount a pick up shoe either directly under the powered unit or under the adjacent trailer coach. You also need to rewire the wheels' pick ups to make it a real 3-rail vehicle, then add a decoder (if you run in digital) Additionally one needs to adjust the inner flange spacing of all axles to 13.8 mm to fit Märklin rails. Then to finish it up, run a pair of wires+ connectors though the trailers to power head- and taillights Not hard (done it literally hundred of times) , but it always takes time and a little experience for good professional looking results. Cheers |
Jacques Vuye aka Dr.Eisenbahn Once a vandal, learned to be better and had great success! |
 1 user liked this useful post by jvuye
Originally Posted by: jvuye  Additionally one needs to adjust the inner flange spacing of all axles to 13.8 mm to fit Märklin rails. Usually this is not required on C track or K track. I'd leave the wheels as they are as long as there are no problems with derailing. |
Originally Posted by: H0  Originally Posted by: jvuye  Additionally one needs to adjust the inner flange spacing of all axles to 13.8 mm to fit Märklin rails. Usually this is not required on C track or K track. I'd leave the wheels as they are as long as there are no problems with derailing. Anyone is entitled to his own opinion....  "Opinion" in this case formed statistically on historical ratio between *pass* and *fail* Cheers |
They make it in AC which is handy :) but there is some other stuff which I fancy and will buy in time probably.
