Offline charles Sharpe
#1 Posted : 17 November 2007 22:34:28(UTC)
charles Sharpe
Hi all For the last 2 weeks I have been running a loc with coaches /lights in them. I have had no trouble with flicker at all. Yesterday I put I some feeder wires to my c type track . As I have 4 lots of track running along with each other I looped from one track to the next to the next and so on but when I run the same train with the same coaches I am know getting a lot of flicker. I have checked the wires are on nice and tite and the track is pushed together ok.
CHARLES SHARPE
#2 Posted : 18 November 2007 01:51:05(UTC)
Hi Charles. Unlikely this is caused by extra feeders. If you disconnect the extra feeders do the coaches still flicker.
Does it happen on all of the four tracks? If so then the problem is with the coach lighting. Make sure the connection from the pickup in the first coach is Ok and that the currect conducting couplers are also connected properly.
Do all coaches flicker or just some of them? If just some check the ground on those that flicker.
Make sure the track is clean if flicker happens only at the same part of the track.
David
#3 Posted : 18 November 2007 01:53:56(UTC)
<br />...Make sure the track is clean if flicker happens only at the same part of the track...David
Got my money on the problem being related to dirty track or wheels too..
#4 Posted : 22 November 2007 20:57:50(UTC)
charles Sharpe
Hello All. I am still working on the above problem you were right David I put the loco on the lower level and the lights still flicker .Today I have installed a 73140 light kit in a 43584 BI level coach why can't all lighting kit be so easy as that onebiggrinbiggrinbiggrin
CHARLES SHARPE
#5 Posted : 22 November 2007 21:09:01(UTC)
If your track must go over the wires (no matter how thin and fine they are) that could crete a bump that worsens connection to teh train when crossing that spot...
#6 Posted : 22 November 2007 22:09:35(UTC)
Hi Charles. 73150 is probably the best of the lighting kits.
Most of the trouble comes from the various connections going from coach to coach.
Current conducting couplers are not great with flimsy connecting parts...although they do work given time spent with them.
There are two pole current conducting couplers available but they are very expensive and only couple and uncouple by hand but you do get flicker free lighting.
If you have many coaches coupled you can have a pickup shoe at each end thus getting power from two sources which helps with six or more coaches.
My own view is take the power from the loco either with the two pole couplers or with the single pole and a ground on each coach. If coming from the loco attach the wire to the coupler from the track pickup going to the decoder.
David
#7 Posted : 23 November 2007 21:00:44(UTC)
charles Sharpe
Hi David .Who makes the two pole current conducting couplers and what sort of price are they. Are they a straight replacement for the single pole coupler. If you put a shoe on the last coach would you but it at the end of the last coach or at the beginning.
CHARLES SHARPE
#8 Posted : 23 November 2007 21:18:09(UTC)
Charles. Marklin make the two pole couplers but they are different to the single pole in that they only couple by hand. They are about 15 euros each.
If you are putting a pickup on the last coach I would put it at the beginning.
Do you have your coaches running flicker free now.
David
#9 Posted : 23 November 2007 22:20:00(UTC)
charles Sharpe
David. Not yet I have been laid up again with me spine hope to have a go on sunday I keep looking on ebay for a new one but no look yet.winkwinkwink
CHARLES SHARPE
Invisible track feeder wires (Small scale)
by Manga 08/03/2023 10:30:03(UTC)
Feeder wires (H0-scale)
by Suomi762 01/03/2023 22:48:54(UTC)
Additional Feeder Wires (Digital)
by Mayleneman 05/02/2023 21:27:58(UTC)
Bus feeder wires? (Model railroad wiring)
by Jabez 10/05/2019 22:24:24(UTC)
Soldering Feeder wires to C track (Model railroad wiring)
by Jabez 19/04/2019 22:36:52(UTC)
Marklin 8590 Feeder Wires (Small scale)
by Sinx 18/08/2017 19:36:16(UTC)
How to Connect Multiple feeder Wires with 60113 Track Box? (Digital)
by 5HorizonsRR 05/09/2016 17:32:22(UTC)
Method for adding more feeder wires-Any suggestions (Model railroad wiring)
by garben 13/10/2015 00:29:10(UTC)
Ragarding M tracks with feeder wires (H0-scale)
by elig99 16/02/2013 09:32:07(UTC)
This page was generated in 0.333 seconds.
