E44
Offline applor
#1 Posted : 06 November 2009 07:24:10(UTC)
applor
Hey fellas,
Just wondering if there's any news on the grapevine regarding a new E 44 model?
The latest one produced was model 37440 which was HEP with a horn sound and marker lights, non MFX. I believe the actual model was the same mould as the earlier ones just maybe with more detail?
This model was discontinued a while ago.
Any idea if Marklin are working on a new one?
Offline TimR
#2 Posted : 06 November 2009 09:57:58(UTC)
TimR
Indonesia
According to the database, the latest version of E44 is 39440 from 2006 to 2008 - this is now red-flagged though.
The last 34440/37440 already use can motor (glockenmotor) with all axles powered.
The 39440 still uses the same tooling. The only difference is that M* had replaced the can motor with a compact Sinus motor (Driver board should be upgradable to SDS standard) plus a MFX decoder.
I think it would be a matter of time before another version is released.
Now collecting C-Sine models.
Offline Davy
#3 Posted : 06 November 2009 14:23:32(UTC)
Davy
I have the 34440 and it is a great loc and very strong puller. This Delta loc has his lights always on.
It will pull everything you have.
UserPostedImage UserPostedImage
M-track with a CS2.
Offline Peter Neumann
#4 Posted : 01 January 2010 20:27:08(UTC)
Peter Neumann
Hello Davy, and all -
Can you or someone help explain how to remove the body of the 34440? The instruction leaflet is not clear. I need to set the lok address, but also am interested in adding a LokSound3 sound decoder. I use the 6021 controller.
Advice is appreciated.
Peter in Indiana / USA
#5 Posted : 01 January 2010 20:33:53(UTC)
Hi, Peter,
two screws, reachable from the bottom through the trucks. You'll need a slim screw driver.
Offline Davy
#6 Posted : 01 January 2010 21:57:36(UTC)
Davy
A magnet one is great help.
M-track with a CS2.
#7 Posted : 01 January 2010 22:56:35(UTC)
Hi Eric,
I have a 37440 and am very happy with it.
It has plenty of detail like separate hand rails on front and rear body sections, roof transmission gear, and cooling coils.
The rear lights go red - white for forward.
Whistle is realistic and sharp.
Driving is very smooth, and controllable to very low speeds.
It does not have a particularly high speed threshold, but then this may be digitally adjusted, I am not sure.
A heavy locomotive, full metal, weighing just under 600 grams.
I would certainly recommend getting one if you like it.
E44039 Manual and parts list (H0-scale)
by Rainer B 09/03/2022 20:29:28(UTC)
3011 E44 Screw Part Number Needed (General MRR)
by skeeterbuck 19/03/2021 11:52:19(UTC)
Fleischmann E44 & 6345 Vinatge Analog HO (General MRR)
by Kartik 29/03/2020 12:32:19(UTC)
SEG800 - E44.5 Locomotive for the Märklin 3011 Chassis (H0-scale)
by Markus Schild 26/04/2019 07:22:45(UTC)
E44039 info (General MRR)
by Cocolarue916 17/08/2018 21:13:30(UTC)
E44 (37442) bogie sandboxes (H0-scale)
by Marty 09/05/2016 21:36:06(UTC)
DB E44 and SNCF BB10000 together on the same tracks ! (Prototype)
by TrainIride 07/02/2015 11:22:24(UTC)
E44 capability without overhead power (Prototype)
by dick_in_sd 15/01/2013 00:07:50(UTC)
E44/Br144 in push-pull service (Prototype)
by ozzman 17/09/2011 07:31:23(UTC)
My new E44 (39441) drives erratically at higher speeds? (H0-scale)
by DasBert33 06/04/2010 11:26:07(UTC)
Content DB E16 / E44 era 3/4 Munich-Innsbruck (Prototype)
by Rinus 13/09/2009 21:51:00(UTC)
37440 E44 Conversion.... (Digital)
by pa-pauls 13/08/2008 23:10:17(UTC)
BR E44 old locomotive (Digital)
by marklinologos 16/10/2007 20:12:49(UTC)
Adding LokSound3 decoder to E44 (Digital)
by Peter Neumann 25/05/2005 05:10:26(UTC)
This page was generated in 0.477 seconds.
