#1 Posted : 02 March 2004 00:12:27(UTC)
Hi all
I always like to have lighting in my coaches...which must be flicker free. Now I am using Marklin the extra rail certainly helps to avoid any flicker. However rather than have a pick up on each coach I tried the electrical coupling set but have to say it is not very reliable and a bit hit or miss when fitting. Previously I used the Roco 4 pole couplers and have tried them with the Marklin coaches....you really only need one of the wires...and find they work well.
Anyone else had experience with the Marklin couplers and find they are OK?
David
Offline tnx jake
#2 Posted : 02 March 2004 08:52:12(UTC)
tnx jake
David,
Like you I have found the Marklin current conducting couplers very difficult to work with particularly on long trains. I have converted all of my passenger coaches (over 150) to Roco 4 pole. They are reliable and easy to work with. I have used the extra wires in some cases to turn the lights on and off with a decoder. I have even one set where I turn the lights on and off in each coach individually.
Jack
Offline Lars Westerlind
#3 Posted : 02 March 2004 09:28:03(UTC)
Lars Westerlind
Me too. I certainly prefer Roco 4 pole; I have them between cars, but not between cars and loco; in that way I can change loco and direction of travel.
And I have full use of the four poles; I don't understand how you get flickerfree with only one pole... I also like the idea of individual light control; my train sets are only 3-4 coaches.
/Lars
#4 Posted : 02 March 2004 13:20:26(UTC)
Thanks for replies guys. Interesting to note that you also use the Roco couplers. Lars, if you use one of the Marklin pickups you only need one wire from the coach with the pickup shoe. Probably not the best way I agree but saves on some wiring.
I am a great believer in lighting and include all the station buildings etc which when the main layout lights are off gives a completely different effect to the scene.
JUst quickly on another matter, I joined the insider club in January and have still not received anything from them. Perhaps this is just the UK being slow as usual?
David
#5 Posted : 02 March 2004 14:46:34(UTC)
Lars Westerlind
Aha David,
you have a separate decoder in every coach? I use one function decoder for the train set. Typically I use the connections in this way:
1. Function 1
2. Function 2
3. Decoder ground
4. Extra wheel contacts / track ground.
So in each direction from the decoder I have two separate functions (if the decoder permits). In the other direction I use Function 3 and 4.
Actually, I have only 2 trainsets equipped in this way, and both are exceptions!!! The first is Würtemberg train set with 3 passanger coaches, and a heating car in the middle containing the decoder. So I use only 3 functions here, and have extra wheel contacts in one direction, and the pickup shoe in a passanger car in the other direction (as the slider fits better in a boogie).
The other train set has only 2 passanger coach, and one luggage coach. So only the decoder is in one end, but nevertheless each coach is individually controlled.
Lars
Offline dikken
#6 Posted : 02 March 2004 23:04:43(UTC)
dikken
Dpes anyone has any experience in adding a capacitor to stop flickering?
confused
Dikken
Check out my site:
http://www.modelspoorhobby.be
Offline laalves
#7 Posted : 03 March 2004 03:44:17(UTC)
laalves
You must rectify the AC current with a rectifier or diode bridge to feed an electrolytical capacitor (a 50V 250 microF is fine) in turn feeding the light circuit.
WARNINGS:
1 - Isolate AC ground from the lamps.
2 - NEVER feed AC current to an electrolytical capacitor: it will explode violently, with 100% probability.
3 - DO MIND for correct electrolytical capacitor polarity or, same as above....
Otherwise, install things correctly and enjoy flicker free lights on your coaches...
Luis
Offline dikken
#8 Posted : 03 March 2004 11:40:25(UTC)
dikken
thanks for the info!
biggrinbiggrinbiggrinbiggrinbiggrin
Dikken
Check out my site:
Info on wiring Viessman coach lighting decoder 5077 (Digital)
by fabstar68 20/08/2024 19:30:02(UTC)
Coach lighting control? (Digital)
by Puttputtmaru 24/07/2024 19:34:33(UTC)
Will this work? battery magnetic switch led coach lighting (Model railroad wiring)
by marklinist5999 31/01/2023 23:52:01(UTC)
Train Tech coach lighting (H0-scale)
by Michael4 19/11/2020 12:59:14(UTC)
Coach Lighting Product (Model railroad wiring)
by Hannes Porsche 28/07/2020 00:34:39(UTC)
Unknown coach lighting accessory - brand? (Collector's Corner general)
by cookee_nz 01/01/2020 03:04:38(UTC)
Interior coach lighting (Model railroad wiring)
by DaleSchultz 29/04/2019 18:14:39(UTC)
Coach lighting (H0-scale)
by mike c 16/03/2019 16:07:03(UTC)
Lokpilot, coach lighting & current conducting couplers (Model railroad wiring)
by morsing 29/10/2018 20:33:02(UTC)
Review of Train-Tech Coach Lighting (Accessories reviews)
by sidblack 08/09/2018 10:01:51(UTC)
26922 Coach Lighting Problem (H0-scale)
by dickinsonj 13/02/2017 21:07:15(UTC)
Coach Lighting (H0-scale)
by amunro 10/11/2015 18:03:59(UTC)
Coach lighting for IC 2000 coaches (General MRR)
by charles Sharpe 02/04/2013 06:58:27(UTC)
Coach lighting kits for 4022, 4023, 4024, 4026, 4027, 4029 , 4052 (Collector's Corner general)
by BrandonVA 14/03/2012 14:05:05(UTC)
Coach lighting question (Digital)
by LaurryG 26/03/2011 07:59:47(UTC)
Coach Lighting Pickup Shoe Short Circuiting Under Digital Operation (Digital)
by aos 05/03/2011 18:19:00(UTC)
42941 Riviera Express coach lighting (H0-scale)
by GSRR 17/12/2009 18:38:24(UTC)
Elektor magazine - Model Coach Lighting Decoder (Digital)
by DamonKelly 25/05/2009 15:06:21(UTC)
INOX Coach lighting (H0-scale)
by mrmarklin 03/02/2008 07:31:51(UTC)
Ultimate coach lighting? (Digital)
by Rudi Bekkers 26/04/2006 22:10:11(UTC)
F7 controls passenger coach lighting (H0-scale)
by hmsfix 20/02/2006 02:02:11(UTC)
Coach Lighting (General MRR)
by David Dewar 15/02/2004 17:27:06(UTC)
by Chris Vella 17/10/2003 11:49:40(UTC)
This page was generated in 0.580 seconds.
