Offline Makistrain
#1 Posted : 16 December 2023 00:09:00(UTC)
Makistrain
I haven't posted in 10 years. But like others, with Covid, I've gotten back into the hobby. My previous posts resulted in amazingly kind and helpful responses so I am very hopeful. I must say that I am fairly ignorant about electricity etc.
Anyway, I have a layout of about 35 feet of m-track (mostly very old), with a few feet of C-track mixed in.
Trains work great at the analog level. For digital, I disconnect from my analog transformer the wires from my feeder buss and ground (the buss feeds track at about 7 different points) and connect them to my mobile station. I get nothing... but when I connect those wires to my analog transformer, the analog trains run like a top.
So I pulled the Mobile station off the main layout, and attached it to a length of c-track. Digital locos run great! So I assume it is not equipment failure. Is there a short in my layout that doesn't bother analog, but defeats digital? Do my tracks need further cleaning? just getting my feet wet with digital, so all signals and switches are still analog.
I've searched various threads on the forum and haven't been able to find the answers. If it is a short, how can I find it? Do I have to break out the layout into blocks that correspond with my feeder tracks? Any insight you can provide would be immensely appreciated. Don't know anyone else that has marlkin trains here in Connecticut!
With many thanks...
thanks 1 user liked this useful post by Makistrain
Online Steveknz
#2 Posted : 16 December 2023 00:33:56(UTC)
Steveknz
Maybe check that your feeder tracks dont have capacitors attached to them which can interfere with the digital signal. Some feeders tracks come with them, some do not
Steve
thanks 1 user liked this useful post by Steveknz
Offline sidblack
#3 Posted : 16 December 2023 03:22:11(UTC)
sidblack
Yes, I did exactly the same and thought I had a short, but as stated above it was capacitors in some of the feeder tracks. I've removed them and my trains run fine with my Mobile Station 2 on my m track layout. I'm sure it will fix your problem. The difficulty was for me digging the feeder tracks out of scenery to check whether or not they had a capacitor.
Here is the link to my discussion on this Forum:
Link to my layout
Good luck!
thanks 2 users liked this useful post by sidblack
#4 Posted : 16 December 2023 13:17:13(UTC)
Have you checked all your M track for rust, and the rail joiners for fit and cleaned it well?
Offline Paul59
#5 Posted : 16 December 2023 17:22:00(UTC)
Paul59
My money's with Steveknz's suggestion. Some M track feeder pieces have little capacitors between the studs and the rails. They are there as they helped with suppressing radio interference back in the old days.
They will effectively short out the digital signals and must not be there.
Assuming you are using proper track feeder sections then with seven feeds it's quite likely that at least one of them will have a suppression capacitor fitted.
I guess you'll have to unclip each feeder section and have a look underneath it.
If you have a multimeter that can measure capacitance then I suppose you could use it between ground and each power feed wire having disconnected the feed wires from the power buss. Any that show a value will likely have a capacitor underneath.
At least then you'll know which ones have to be lifted. This would probably be just as much hassle as lifting each feeder track though.
Marklin HO using M track. Now reverted to analogue as I find it has more character - and I understand it!
thanks 2 users liked this useful post by Paul59
Offline Makistrain
#6 Posted : 16 December 2023 17:44:01(UTC)
Makistrain
Gentlemen
Many thanks. I am on it... and quite hopeful.
And I would never ever have thought of that.
Will report back re: outcome.
Smile
Offline Makistrain
#7 Posted : 16 December 2023 19:23:31(UTC)
Makistrain
Originally Posted by: Makistrain Go to Quoted Post
Gentlemen
Smile
Found one feeder track with a capacitor.
Clipped the capacitor out... do I need to change the feeder track?
Looked like clipping the capacitor would do it.
Anyway, still no connection between my MS2 and the locomotives.
And analog running fine.
Will set to cleaning the track next. Checked the joints. All look good.
Any other ideas? Thanks for all your help.
Much appreciated.
Makistrain
Offline BenP
#8 Posted : 16 December 2023 21:43:09(UTC)
BenP
My old M track also had a radio/tv interference track piece (with some contraption underneath) that should not be included in digital layout. Did you test for ~18V power from box to track with a meter (use old fashioned needle meter)?
Offline Makistrain
#9 Posted : 17 December 2023 03:06:50(UTC)
Makistrain
will do.
thanks.
Offline Makistrain
#10 Posted : 07 March 2024 15:45:31(UTC)
Makistrain
BenP
Three months later, I know, but now I am Back home with my train and my challenge.
Have set up a test bed for my digital locos. Have attached the box and the controller to the test track , and my meter gave me a steady 9v. Digital Locos work find on three foot length of the test track. (C-track)
When I test the voltage to the track in the full layout, I get less than a volt reading.
My full layout has both old M track and C track.
What is the very low voltage on my full layout digital test telling me? I have checked for capacitors on all my feeder tracks, and removed the ones I have found. But would an overlooked capacitor create this problem? Or a rusty piece of track?
On analog, locos run fine!
Thanks for any thoughts you may have. Am determined to figure this out!
Offline rbw993
#11 Posted : 07 March 2024 18:53:31(UTC)
rbw993
Sounds like a short but one that isn't triggering a shutdown on the MS. If you remove all items from the track that have a pick up shoe (locos and lit cars) and then disconnect the power supply an ohm meter test between the middle and outer rails the should show no continuity. Of there is continuity there is a short.
Roger
Offline Harvey
#12 Posted : 07 March 2024 19:15:36(UTC)
Harvey
If you can isolate sections of track and test your MS and digital locomotives. That is disconnect two ends from the rest of the layout. Do this until you see it works and then expand the length of track that is isolated from the rest of the layout. That should help identify the areas that are causing problems.
Harvey
thanks 2 users liked this useful post by Harvey
Offline Makistrain
#13 Posted : 26 March 2024 00:24:07(UTC)
Makistrain
Harvey
I am thrilled to report that this will probably be my last post on this particular problem.. Everyone who chimed in was hugely helpful. After many deductive steps informed by fellow members of this forum, I finally resolved to connect directly to one feeder track, and not use the buss that was hosting 7 such feeds. That direct correction on an isolated section of track worked great, but when fully connected to the layout it did not work, but there was a buzz in a M track turnout that required attention. Things seemed to be working now.
So now I am going to do an entirely new buss. I can't see what is wrong with my current buss, but I just know there is something wrong and
I think a total replacement is a good place to go. I will connect feeders, one by one, to make sure it works with one feed, then another feed, etc. etc.
So things are looking up. Am installing a knife switch, to easily go from analog to digital. Hoping it will work out as I do like to operate now in both modes... (not at the same time of course).
Many many thanks to the people who weighed in. Hope I can someday be as helpful to others on this forum as they have been to me.
Bottomline, it took my off and on attention for over 10 years to sort this out, but I'm glad I stuck with it.
And am grateful for this forum.
Thanks Guys!
It worked.
thanks 2 users liked this useful post by Makistrain
Where to start - Analog to Digital (Digital)
by Aussie Susan 08/11/2023 02:11:05(UTC)
Analog to Digital Conversion Marathon (Digital)
by Paul24 02/02/2022 23:27:03(UTC)
Analog to Digital (H0-scale)
by Bill106 11/11/2021 15:28:24(UTC)
Another move from analog to digital (Digital)
by sidblack 20/09/2021 06:24:38(UTC)
analog to digital conversion (Digital)
by hangle718 09/04/2020 01:31:26(UTC)
Piko Taurus loco - analog to digital 3 rail conversion (Digital)
by Ammorphis 27/10/2019 15:58:54(UTC)
Converting from analog to digital (H0-scale)
by Ugo Boggio 20/01/2019 17:23:18(UTC)
Going from old 3rail AC analog to digital AC vs DC (Digital)
by PeterD 03/01/2019 13:51:30(UTC)
Going from M track and analog to digital (General MRR)
by zoomtrain 07/07/2017 20:05:23(UTC)
Analog to digital migration (Digital)
by Pierrenicolas 17/09/2016 03:52:06(UTC)
Converting lok's from analog to digital (Digital)
by Cargodog 21/03/2015 22:49:41(UTC)
by puffin9303 06/10/2013 03:13:09(UTC)
Roco E17 -- Upgrade analog to digital ????? (Digital)
by sop 17/07/2011 13:54:49(UTC)
Analog To Digital Queries (Digital)
by ac jacko 04/07/2011 11:04:56(UTC)
Converting Märklin 6302 from analog to digital. (Digital)
by virtualsweden 15/11/2010 15:48:21(UTC)
Marklin 3000 analog to Digital Problem (Digital)
by mancsaint 13/10/2009 01:24:31(UTC)
Analog to Digital Decoders (Digital)
by rhobson1968 22/02/2009 06:46:30(UTC)
Analog to Digital - Loco 3168 - NS 1200 (Digital)
by Caplin 16/05/2008 02:58:42(UTC)
Analog to Digital Conversion (Digital)
by Ranjit 15/08/2004 15:06:00(UTC)
This page was generated in 0.860 seconds.
