Offline df1965
#1 Posted : 16 November 2014 02:22:08(UTC)
df1965
I just bought some Marklin trains on eBay. I'm going to set up a twice-around loop layout. Which model transformer do you recommend?
df1965 attached the following image(s):
thanks 2 users liked this useful post by df1965
Offline SteamNut
#2 Posted : 16 November 2014 02:45:40(UTC)
SteamNut
I believe they are analog so you can use the old blue transformers but if you get the newer digital loks you would be better off with the white ones.
Offline drstapes
#3 Posted : 16 November 2014 03:17:35(UTC)
drstapes
Yes an old blue transformer would be fine and cheap on ebay. ( Suitably electrically tested). If you plan to run digital locos you need to have a new white controller as the old blue ones tend to fry the digital chip.
Geoff (UK)
Offline Mark5
#4 Posted : 16 November 2014 04:06:38(UTC)
Mark5
Hello DF,
Welcome to the M users forum!
I use the newer white ones with my old analog loks.
Better quality all around, particularly for any future additions to your collection.
If I recall correctly they start power at 4v, so better for slower running than starting power at 8v with the blue ones.
Many previous posts on "trafos" (aka transformers) on this forum if you go to the search feature at top to find them.
The white ones also have a better circuit breaker in them, when you have a short.
No doubt you will be using the M-tracks (metal tracks) with them.
Note the slider on the bottom, as you many well know, is used to collect the "traction" power or positive, from the center studs in the Marklin tracks.
There are also old catalogs for download online that will help you get things up and running.
Hope this helps. Would love to see a photo later of your experiments.
We all love photos on this forum.
Mark
Offline df1965
#5 Posted : 17 November 2014 01:36:03(UTC)
df1965
I've seen the blue jobs on eBay. Do they all have reversing? I understand analog Marklin reverses by a shot of higher voltage .
Offline df1965
#6 Posted : 17 November 2014 02:03:30(UTC)
df1965
Offline SteamNut
#7 Posted : 17 November 2014 02:22:25(UTC)
SteamNut
Both the white and blue uses a higher voltage to reverse, however the old blue is higher then the white and can damage newer digital loks.
Offline df1965
#8 Posted : 17 November 2014 04:35:27(UTC)
df1965
6627
6502
6699
6621
280
6501
6152
These are some of the "blue" transformers I've found on eBay. Is there a rationality to the numbers? Higher is newer maybe? Which has the most output?
Thanks for your patience.
Offline 3rail4life
#9 Posted : 17 November 2014 07:41:20(UTC)
3rail4life
Your best bet would be any one of the following:
6153: blue metal, 30VA, 110-115 volt, US plug, UL listed
6627: blue plastic, 30VA, 120 volt, US plug, UL listed
6646: white plastic, 32VA, 120 volt, US plug, UL listed, may be most expensive choice, but newest and only one suitable for analog operation of digital locos.
The smaller ones are usually only 10-16VA, some of the other model numbers are for other voltages and should be avoided, the 280 is cool but has issues with the cord/ wire insulation deteriorating and would need to be inspected for safe operation before use. It, and any other older model you may choose should be stamped 110 or 120 volt to function properly in the US.
Marklin has made many different models with different outputs, cords and voltage specifications, most should run your trains, the ones listed are my favorites...
6627
#10 Posted : 17 November 2014 08:29:58(UTC)
It should be noted that transformers marked 110 V must not be used with modern locos that have decoders.
If you buy newer locos with decoder you have to use transformers marked 120 V.
Offline df1965
#11 Posted : 29 November 2014 02:56:58(UTC)
df1965
Thanks for all your help folks. I bought a 6627 on eBay.
Transformer replacement for a 2940 set (H0-scale)
by klinsea007 14/03/2024 23:38:27(UTC)
transformer options (Small scale)
by ProductionMgr 25/02/2024 03:25:33(UTC)
Märklin 6646 or doorbell transformer? (Digital)
by Minok 28/01/2024 23:12:35(UTC)
Pre 1945 HO Train set/Transformer (H0-scale)
by rbat 16/01/2024 20:58:21(UTC)
how do i connect transformer 66646 to feeder track 4088 (General MRR)
by mike@complexplastics 30/12/2023 19:23:37(UTC)
Viessmann Transformer 5200 & Multi Protocol Light Decoder (Digital)
by Eddie7979 05/04/2023 03:07:30(UTC)
Locos crossing transformer areas (Digital)
by einotuominen 26/03/2023 14:23:26(UTC)
Marklin 6646 transformer (H0-scale)
by Keim 09/03/2023 07:56:59(UTC)
Marklin Transformer from 1960 (General MRR)
by Slinger 30/12/2022 15:12:15(UTC)
Marklin 6646: Transformer not working (Model railroad wiring)
by europromo 13/12/2022 02:37:48(UTC)
Transformer Control of Marklin 3088 Engine & 1071 Motor (General MRR)
by mjborelli 05/12/2022 19:32:12(UTC)
Märklin Transformer Wagon 4617.99701 (H0-scale)
by twmarklinfan 03/10/2022 10:39:25(UTC)
Using multiple transformers (analogue) (General MRR)
by Michael4 17/08/2022 17:39:46(UTC)
Central Station 3 transformer compatibility 6002 (Digital)
by vandermerwe 26/07/2022 12:35:09(UTC)
Using several transformers (Digital)
by pmgsr 01/06/2022 14:34:58(UTC)
110 v transformers (General MRR)
by Matthew 14/05/2022 16:09:38(UTC)
Alternate Transformer suggestion (Small scale)
by Bilge Rat 07/01/2022 22:51:46(UTC)
Analogue Loco/Transformer Only Reverses (H0-scale)
by OffColorOtter 05/12/2021 14:43:01(UTC)
Transformer compatibility (General MRR)
by rjleeiv 28/11/2021 22:08:02(UTC)
Marklin transformer 6611 (H0-scale)
by michaelh 13/10/2021 09:30:34(UTC)
Old blue analog transformer from late 60's, early 70's (General MRR)
by mwarsell 04/08/2021 20:36:07(UTC)
European 110v transformer in US / Canada (Model railroad wiring)
by bookcabinet 27/07/2021 22:19:50(UTC)
Gaugemaster Model Q Transformer Review (for Z Scale and other scales) (General MRR)
by zoooctan 26/06/2021 07:07:13(UTC)
Plug for 60052 transformer (General MRR)
by charles Sharpe 23/05/2021 17:19:28(UTC)
Marklin Transformer Voltage (Small scale)
by zoooctan 04/05/2021 14:40:11(UTC)
Non marklin transformers (H0-scale)
by Traindutchman 23/04/2021 17:20:33(UTC)
Old Marklin Transformers (Collector's Corner general)
by GG1 Fan 24/03/2021 05:54:57(UTC)
Marklin Transformer (Digital)
by dboost 24/02/2021 00:51:34(UTC)
Transformer alternatives (H0-scale)
by Schnickie 18/02/2021 10:59:59(UTC)
Marklin 6150 controller/transformer (H0-scale)
by tchiplis 14/02/2021 19:51:38(UTC)
Wiring 7209/72090 Distributor Strips to Marklin AC Transformer (General MRR)
by mjborelli 18/01/2021 00:24:06(UTC)
Newbie - Green but Keen. Transformer Question (Small scale)
by Ricinport 14/01/2021 22:01:38(UTC)
Marklin 960041 Transformer (General MRR)
by Sidebandjack 25/12/2020 21:52:00(UTC)
1960"s HO track and transformers (H0-scale)
by mrfixit 14/12/2020 14:49:34(UTC)
6647/6648 HO Transformer advice (Digital)
by ShannonN 14/12/2020 08:54:34(UTC)
White transformers (H0-scale)
by Michael4 23/11/2020 18:19:47(UTC)
Running digital locos on standard transformer. (Digital components and Software reviews)
by ausland 16/09/2020 18:07:44(UTC)
Difference between Titan 108 and 208 lighting transformers (General MRR)
by rustya 12/07/2020 02:35:24(UTC)
60173 booster with which transformer? (Digital)
by gauravk84 09/06/2020 17:56:25(UTC)
Blue Transformers to Control Turnouts in Digital Ambient (Digital)
by Joao Zilio 28/05/2020 22:34:50(UTC)
Marklin Transformer 67271 (Small scale)
by Carlos 20/03/2020 19:17:19(UTC)
How to open up 18VA transformers (Model railroad wiring)
by thing fish 15/03/2020 08:31:37(UTC)
Questions about a transformer and 2 locos (H0-scale)
by pclancy 03/02/2020 14:01:31(UTC)
How to set up a two transformer analogue markin layout (Model railroad wiring)
by pclancy 28/01/2020 13:26:30(UTC)
Which transformer to purchase? (H0-scale)
by pclancy 12/01/2020 13:46:58(UTC)
Using a Transformer and 7210 Switches rather than Decoders on each turnouts. (H0-scale)
by Richard Joint 07/01/2020 03:33:52(UTC)
Transformer 6646 (H0-scale)
by joyofmarklin 09/12/2019 19:23:04(UTC)
Blue marklin transformer repair (H0-scale)
by Victor Almeida 01/11/2019 00:51:49(UTC)
Transformers... (General MRR)
by LNorthway 28/09/2019 21:39:00(UTC)
White lighting transformer number? (General MRR)
by Michael4 12/08/2019 15:13:39(UTC)
This page was generated in 0.707 seconds.
