shunter Offline
#1 Posted : 06 August 2012 17:20:57(UTC)
shunter
I am wandering what the use/purpose of the choke coil are in the pic supplied with the motor conversion packs.
I have some locs that have them attached in the wiring to the motor and some without them ,
and i notice no differance when running them around the track .
Anyone who can give me the dummy explanation BigGrin
Fokko
H0 Offline
#2 Posted : 06 August 2012 17:47:16(UTC)
Some say they prevent radio and TV disturbances, others say they protect the decoder.
I think all my Märklin locos with 5-pole HEP have them installed and I always add them when I do digital conversions.
AFAIK most locos will run without them without problems. I never tried it without them.
Analogue Märklin locos and digital locos with AC/DC motor had one choke of a different type installed.
Suaviter in modo, fortiter in re
intruder Offline
#3 Posted : 06 August 2012 18:16:58(UTC)
They have been a part of all Märklin 5-pole conversion sets since the first 6090 set.
As far as I know, they are installed in all digital locos from Märklin with the 5-pole high power motor.
I do as Tom and always install them. Märklin could save a lot of money not installing them, so they are there for a reason.
Best regards Svein
member of MFDWPL for some more months
www.saebonet.com
shunter Offline
#4 Posted : 06 August 2012 19:33:03(UTC)
shunter
I was curious for the reason because as said i found 2 of my loco's that don't have them and run perfectly.
Both done by official dealer.
As i took the plunge and give it a try myself to convert some locs i noticed them missing
and wandered about the purpuse of the part.
Won't take any risk and just use them in my conversions .
Webmaster Offline
#5 Posted : 06 August 2012 20:12:11(UTC)
I'm in the group "protect the decoder" from voltage spikes due to derailing and such myself... BigGrin
RayF Offline
#6 Posted : 06 August 2012 20:36:05(UTC)
Chokes, or inductors, attenuate high frequencies. They let DC pass straight through, but prevent sharp voltage/current spikes from getting through.
In the context of a motor, high frequency spikes are generated by sparking at the commutator. These high frequencies can have two negative effects.
The first effect is that if they are allowed to conduct down a length of cable they will use the cable as an antenna, and radiate these high frequencies as radio waves. These waves will interfere with TV and radio reception in the vicinity of the trains.
The second negative effect is that the voltage spikes, which can have quite a high amplitude, will feed back into the output stages of the decoder driving the motor. They can be enough to damage the output stages and maybe blow an output transistor within the decoder.
Inserting the chokes in series with the motor brush connections will go a long way towards both preventing unwanted Radio emissions from your layout and also protecting your decoders from voltage spikes.
Ray from the Rock.
Mostly Marklin Era III & IV
6021 replaced with MS2
 1 user thanked RayF for this useful post.
Bigdaddynz Offline
#7 Posted : 06 August 2012 20:36:26(UTC)
This has been discussed in the forum previously, but as Tom and Ray point out they are there to prevent radio and TV interference, and to protect the decoder.
Best to use them, even though a conversion may seem to work fine without them.
 1 user thanked Bigdaddynz for this useful post.
This page was generated in 0.313 seconds.
