Offline dboost
#1 Posted : 20 April 2021 19:01:15(UTC)
dboost
Hello All...I am looking for the correct Marklin Control Box (72710, 72730 or 72740) to control Marklin Home Signal 70392, C Track Turnout Motor 74491 and building interior lights. Thanks for any tips and advise !!
Regards, Dietrich
#2 Posted : 20 April 2021 19:37:34(UTC)
Hi Dietrich
The control boxes and their use:
  • 72710 is to drive a solenoid item (switch motor, etc) with a end position switch. It shows the item's position using green and red LEDs. It is ideal to drive a C switch motor 74491 on an analogue layout
  • 72730 are independent switches to turn ON or OFF the power in a track section (garage). It is ideal for turning ON /OFF the lights in houses
  • 72740 is identical to 72730 with one exception: all switches share the same common (usually the B track voltage or the L accessory voltage
To drive digital signals (like the 70392) on an analog layout, the 72760 is needed
Offline dboost
#3 Posted : 20 April 2021 19:51:34(UTC)
dboost
Thank you Jean !!
Control Boxes (Digital)
by Ranjit 07/08/2020 06:48:38(UTC)
Sockets and plugs for old control boxes (Small scale)
by davidmack 28/09/2019 15:45:56(UTC)
connecting circuit tracks, relays, and control boxes (Model railroad wiring)
by profher 03/08/2017 21:41:03(UTC)
7272 White control boxes. (Digital)
by charles Sharpe 06/11/2013 16:45:19(UTC)
How to connect the tracks to the Control Boxes and to the Transformer (Model railroad wiring)
by Abdul 02/09/2013 08:37:21(UTC)
This page was generated in 0.194 seconds.
