Offline Ranjit
#1 Posted : 07 August 2020 06:48:38(UTC)
Ranjit
Hi All...
A quick stupid question. Do you need control boxes (7072, 7210, 7211, etc.) to control solenoids, signals, lighting, etc. or can you do without them?
Ranjit
#Get Vaccinated
#2 Posted : 07 August 2020 08:47:45(UTC)
You don't need them.
As an analogue guy, you can switch turnouts by holding the blank ends of the wires together. Or switch by hand. Or use contact switches from the electronics supplier of your trust.
An a digital guy, you can install decoders that replace the control boxes.
#3 Posted : 07 August 2020 09:19:13(UTC)
Hi All...
Ranjit
You need always electronic control to switch signals and motor.
Also switchable to control lighting.
#4 Posted : 07 August 2020 09:27:17(UTC)
Hear, hear!
I can do it with my finger without electronic control... Wink
Offline Ranjit
#5 Posted : 07 August 2020 09:57:37(UTC)
Ranjit
Hey Tom and Anders... Great to hear from both of you !! The quick stupid question was actually stupid. I did not frame it properly. The quick stupid question again is: Do you need control boxes (7072, 7210, 7211, etc.) to control solenoids, signals, lighting, etc. or can you do without them in a digital layout? All this while, I have been controlling these devices manually in an analogue layout. As I am embarking on building a brand new digital layout, hence my stupid question. It seems that I don't need to have these control boxes provided I install decoders as Tom has explained. One more new thing I have learned about Marklin digital layouts.
Ranjit
#Get Vaccinated
Offline ocram63_uk
#6 Posted : 07 August 2020 10:07:21(UTC)
ocram63_uk
in my limited experience even with a digital layout you can use the control boxes you mention.
Using decoders or other digital amenities costs money compared to these cute little boxes.
Plus every decoder drains a bit of power from the control unit.
Depends on size of layout and money :-)
#7 Posted : 07 August 2020 10:14:05(UTC)
Yes, but opens new options for automation (setting routes from a sophisticated controller or maybe even PC control).
Every decoder draws a tiny bit of power from the booster - not necessarily the booster built into the controller. Separate busses can be a good idea even if you do not use a separate booster right from the start.
#8 Posted : 07 August 2020 10:31:54(UTC)
I use decoders and motors for C track turnouts. Expensive but good for routes etc with my CS3. For lights I just use a control box. Try a decoder in a turnout and I am sure you will like it.
Offline ocram63_uk
#9 Posted : 07 August 2020 10:47:14(UTC)
ocram63_uk
Tom, I agree with you as much as I agree with myself :-)
At the end of the day it all comes down to what Ranjit wants to achieve with his layout, i.e. setting the foundations of an all digital layout now or following his immediate needs, IMO
But do not buy the old blue boxes, they tend to warp and I had to throw a few away and replace them with the white ones
thanks 3 users liked this useful post by ocram63_uk
Offline Ranjit
#10 Posted : 07 August 2020 15:41:26(UTC)
Ranjit
You have said it, David... All this Analogue to Digital conversions of locomotives, solenoids, signals, etc. is going to cost me a bomb !! But, once it is done, I am sure I am going to like it. Thank you for saying so.
Ranjit
#Get Vaccinated
Offline Ranjit
#11 Posted : 07 August 2020 15:45:08(UTC)
Ranjit
Marco... I am slowly getting rid of most of my analogue stuff, and I am setting a foundation for a digital layout.
Ranjit
#Get Vaccinated
#12 Posted : 08 August 2020 12:57:34(UTC)
Hear, hear!
Still you don’t! You even use trafo or and power feeder.
#13 Posted : 08 August 2020 12:59:50(UTC)
Ranjit
Märklins control boxes are electronic function to control devices.
Offline Ranjit
#14 Posted : 08 August 2020 13:46:23(UTC)
Ranjit
ThumpUp
#Get Vaccinated
#15 Posted : 08 August 2020 16:20:51(UTC)
Hear, hear!
Still you don't get the point. I can do it with my finger without electricity and without transformer.
Most control boxes are simple electric switches without any electronics included.
Offline Ranjit
#16 Posted : 08 August 2020 17:59:24(UTC)
Ranjit
Now, I am completely at a loss !! Do I use control boxes in a digital layout or don't I ? The answers to this very "stupid question" have become very large indeed.
Ranjit
#Get Vaccinated
Offline Martti Mäntylä
#17 Posted : 08 August 2020 18:37:06(UTC)
Martti Mäntylä
If you use decoders to control the switches and signals, you don't need the control boxes in a digital layout. I mainly use old K83 decoders for there job. I use them even in an analog setup for convenience and automation.
- Martti M.
thanks 2 users liked this useful post by Martti Mäntylä
#18 Posted : 08 August 2020 18:37:07(UTC)
Ranjit
Ranjit. Buy a turnout decoder and motor and fit it to a C track turnout. When you see what it does you will not want control boxes. Digital is expensive but it is worth going slowly and build up over time and buy the correct stuff. CS controllers work well with decoders and give you routes etc. Why buy manual switches in the digital age. Sometimes on here threads get out of control and do not give you what you want. My view is easy ... do not use control boxes and spend some extra cash to get the better option.
thanks 4 users liked this useful post by David Dewar
Offline Ranjit
#19 Posted : 09 August 2020 07:56:49(UTC)
Ranjit
Thank you for your suggestions, Martti and David !!
By the way, I will be using the K-track system for the entire digital layout, and I was wondering if it is possible to motorize and digitalize the turnouts under the baseboard to make it look more prototypical. What are the specific item numbers for the decoder and for the motor? Also, can the Maerklin Item # 7549 actuators be used?
Ranjit
#Get Vaccinated
#20 Posted : 09 August 2020 11:49:14(UTC)
Ranjit, a lot depends on how you want to run your layout. If you are going to rely totally on automated route-control, or run from something like a CS2/CS3 then you may never need any control boxes.
But what about when you might want to run your layout on manual control?, ie actually just "play trains" ? Then, if you want to change turnouts (and signals) you either need to bring up the track diagram and use the stylus to change settings, (which personally I find too fiddly), or you have to be "hand of God" and reach over to switch the accessory manual - not really ideal unless the turnouts are right in front and in easy reach (but I still don't like to do that).
Personally, I prefer to wire in control-boxes so that I have the added flexibility. And I like the newer ones with the LED that show the status of the device. It's still being driven via Digital, but operated by hand (if that makes sense).
However, for me, I like it even a step further. I prefer a track diagram schematic control, using either the older 6041 Switchboard, or an equivalent. Then you can still choose whether you use push-buttons, or a wired-probe to 'touch' the setting as some people also like.
What I definitely would suggest is that even if you decide not to use control boxes, do keep open the option that you may change your mind in future, and make allowances for adding control boxes if you like. It's a minimal extra cost to install the wiring and leave it unconnected when you are actually doing the construction, than to try to add it later on.
#21 Posted : 09 August 2020 16:38:56(UTC)
I don´t understand why you even write about to switch turnouts/signals with the fingers since TS did asked about control boxes to control switch turnouts and signals support by of the electric/electronic power feeder?
No you don´t get the point about the topic.
Ranjit...yes you can use analog power feeder to control your switches/signals via Märklin boxes and drive trains digital if you like.
#22 Posted : 11 August 2020 04:25:15(UTC)
Ranjit
Ranjit, unless Märklin has changed the underfloor mechanism and incorporating the thickness of your board they are not very reliable., there is so much play in them and with the K-track turnout mechanism it doesn't make it a secure operation., I got rid of all my underfloor motorized solenoids and exchanged it with proper servo motors, the benefit is, they are locked into a position and the linkage can't move hence the turnout mechanism can't move either but this again needs money and you have to have control boxes to operate the servo motors.
It is never a stupid question when it comes to outlaying a lot of money eventually and you could save a lot of money when asking questions before hand, it literally could save you thousands of dollars.
depending on the size of your layout, the amount of locos you're running at the same time, all of this has to be taken into consideration, whether or not you're able to run the locos single handed or you need an automated system., whether you can switch the turnouts and signals manually as Tom suggested., if not it will cost you money.
My main concern is is with Märklin signal or turnout products they are very expensive and there are alternatives at a much cheaper price and do the same job., whether you're talking about K 83's K 84's, signals, I've been in the fortunate position and made them myself with substantial savings.
It needs a lot of homework to establish what you need and at a later stage when you've got it all together (before purchasing anything) to share your plan with us and I would suggest not in bits and pieces but as a whole., one thing you also have to have in mind are you a handy person or would you rather put everything together products from a catalogue.
Being a Librarian you have to get into the habit of reading a lot about digital components and their use, asking questions about specific items can or could confuse you more than help you because each digital component has a link to another digital component and unless you know what you want and need the confusion can increase and for us to give you the right advice could be hampering your success.
You could finish up running around like a mouse on its wheel, getting enough exercise for your brain with ideas running wild but not much of getting a foothold to proceed with facts and figures, it took me 3 years to decide which command station to buy switching over from the Motorola system and it depends you may not need an expensive Märklin or ESU central station/command station and it may be enough to buy a second hand Motorala system, combine this with ESU decoders, you can expand it to 255 addresses and 12 Aux functions.
There are so many different options you can choose from, therefore read a lot beforehand and than put it all together.
It is already apparent with forum members giving you advice with different options and it seems you find it hard to analyze whats right for you therefore go back and read and read, some things you most probably will not find anywhere is the practical application of digital components as they can change options you have available to you as this topic has already shown
Jay
Offline Ranjit
#23 Posted : 11 August 2020 05:41:06(UTC)
Ranjit
I totally agree with everything that you have said, John. Reading about digital components is no doubt an important aspect of understanding how they all fit together as a system. I also feel that seeing is believing. Unfortunately, there is nowhere I can go to see such components in operation, and I miss this terribly here in Chennai. The only top-notch resource that I have is 'marklin-users.net', and tank God for that !!
Now, what are these 'servo motors' and how are they used to control devices on the layout?
My new 12 feet (3.7 m) x 10 feet (3.0 m) digital layout planning is underway. As soon as it is finished, I will be sharing it here to get all your inputs. The room for this layout is currently being cleared and cleaned. Once this is completed, I wish to renovate the room to accommodate this layout. I would also be rewiring and installing an UPS, fitting spot lights, etc.
You see, the one good thing about using Märklin components is that they all fit together nicely, and it is usually 'plug and play'. Using components from other manufacturers is a bit fiddly.
Let me get back to the books and let me get engrossed. There is lots that I need to learn.
Take care, stay safe and stay healthy.
Ranjit
#Get Vaccinated
#24 Posted : 11 August 2020 08:59:24(UTC)
YouTube is a great source of information. Lots of how-to videos for beginners.
-And maybe you should read about DCC, and then YouTubers from UK and US really kicks in, and there´s a LOT of information available on the net!
#25 Posted : 11 August 2020 09:40:48(UTC)
Ranjit, I agree with Märklin is plug and play but there others which do the same at a fraction of the cost and this is where it becomes a never ending topic with so many options.
Offline Ranjit
#26 Posted : 11 August 2020 10:00:24(UTC)
Ranjit
Hi John... I will definitely look at the cost of Märklin digital components vs. other manufacturers and explore the "other options" when the time comes.
Ranjit
#Get Vaccinated
#27 Posted : 11 August 2020 11:19:47(UTC)
Ranjit, you will be amazed the money you can save
Online kiwiAlan
#28 Posted : 11 August 2020 18:20:47(UTC)
As pointed out, there is lots of information on using Radio Control servos as point motors. I believe the recent Marklin 60881 can control them, but I have not investigated this, so have no experience with setting them up.
The servos are available for good prices on eBay, so the cost of the Marklin point controller becomes the major cost.
Control Boxes (H0-scale)
by dboost 20/04/2021 19:01:15(UTC)
Sockets and plugs for old control boxes (Small scale)
by davidmack 28/09/2019 15:45:56(UTC)
connecting circuit tracks, relays, and control boxes (Model railroad wiring)
by profher 03/08/2017 21:41:03(UTC)
7272 White control boxes. (Digital)
by charles Sharpe 06/11/2013 16:45:19(UTC)
How to connect the tracks to the Control Boxes and to the Transformer (Model railroad wiring)
by Abdul 02/09/2013 08:37:21(UTC)
This page was generated in 1.427 seconds.
