Offline McLae
#1 Posted : 16 July 2002 23:39:31(UTC)
McLae
I saw a discussion some time ago about what type of oil is best for smoke generators. Now that I have a loco with smoke, I can not remember the details. I do remember that the Marklin oil was not the best to use, but that is about all I remember.
Anybody have suggestions on what is best to use?
The McLae
thanks 1 user liked this useful post by McLae
#2 Posted : 17 July 2002 00:09:13(UTC)
I believe Seuthe sells some smoke oil, SR 24? Also on the MML and Märklin Bar&Grill it was suggested to use "musical instrument oil" intended for brass instrument valve lubrication and such since the smoke was better and did not harm the smoke generator. Can someone else "fill up" on this issue?
Offline KLB
#3 Posted : 17 July 2002 16:22:39(UTC)
KLB
Original posted on the MML,then reposted on the Bar&Grill by J.J. McVeigh:
A few months back there was a discussion about the making of smoke for the
>Seuthe units. John McVeigh came up with the suggestion of using Cass
>musical instrument oil for valves, trumpets, and valve trombones etc. Wow
>John !!! You talk about "Smoke" It works grrreeeat. Far better than
>anything I have used and the smoke pours out. The BigBoy with two units was
>just fantastic. I have the layout in a 20x15 foot room and I felt that I
>was in an old roundhouse with all the steamers blasting away. Thanks John.
>I'm impressed. Dick Pike
Credit to where credit is due: not to me, but to Rex Trye of New Zealand.
I merely republished what Rex had previously posted to MML, in the
glory days of that list, about a year after I learned of it:
> >From: "Rex Trye" <ariete@netsource.co.nz>
> > To: <Bjchoochoo@aol.com>, "J.J. McVeigh" <jmcveigh@erols.com>
> > Cc: <marklin@scintilla.utwente.nl>
> >Subject: Re: cleaning smoke fluid
> >Date: Tue, 25 May 1999 11:59:13 +1200
> >MIME-Version: 1.0
> >X-Priority: 3
> >I have found that Al Cass FAST valve, slide and key oil (made in
>Milford, Mass, USA) for >brass musicial
> >instruments, works very well as an alternative
> >for smoke fluids. It comes in a 2oz plastic container and is way
>cheaper than the Marklin product, as far as I >can see it has no
>harmful effects on the loco or my self.
> >Rex Trye, New Plymouth, New Zealand
J.J. McVeigh
Kevin!
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
thanks 1 user liked this useful post by KLB
smoke oil substitute (H0-scale)
by heinrichhess 10/06/2023 17:32:43(UTC)
Smoke Oil (General MRR)
by moz 06/07/2006 16:29:53(UTC)
This page was generated in 0.388 seconds.
