Offline Harvey
#1 Posted : 23 November 2009 04:05:00(UTC)
Harvey
I am searching for detailed information/instructions regarding the installation of reed switches. I do have the 'Controling, Switching, Running" manual but not that helpful for me on this topic. Maybe this is a simple topic but having little knowledge of electrical concepts and not currently having a sample reed, I can not picture what connections are needed. Searched the web but not much information.
I have M-track and a CS1. Looking to (possibly) obtain an S88 decoder to control switching track. Obviously, I want to first experiment. I would appreciate any references to sites that provide more detail.
Harvey
#2 Posted : 23 November 2009 07:16:36(UTC)
Harvey, one end of the reed switch connects to the rail ground. On my M track layout I simply soldered the end of the reed switch to the underneath of the track piece, after first drilling 2 holes through the track. The other end should be wired to an input of an S88 decoder. So, I just insulate that end with a piece of heatshrink and connect it via a wire to the S88. Remember to also ground the S88 to your common ground (brown). You also use the special ribbon cable to connect the S88 to your CS1 (needs to have the v2.0.x update).
Offline aos
#3 Posted : 23 November 2009 16:35:56(UTC)
aos
David - I see from your comment that you solder the reed switch under the M track. Do you use the Marklin reed switches or do you buy any type at all? Are the magnets mounted on the locos strong enough to activate the reed switch through the track. I may consider that option if it works. I bought a load of 5104/5105 contact tracks earlier this year, but since then Marklin technical support say that I should not use them to switch signals and points as they are not momentary contacts. Please advise me, what are really for.Thanks in advance.
Offline davemr
#4 Posted : 23 November 2009 17:37:22(UTC)
davemr
Contact tracks are for occupation of a loco being fed back to the controller.
I use reed switches with C track (Marklin type) They work well and to ensure good contact you can mount more than one magnet under the loco or car.
davemr
Offline aos
#5 Posted : 23 November 2009 17:41:03(UTC)
aos
Dave - thanks for that info. I see from the catalog that the reed switches are for both C and K track. Do they also fit in the old M track?
Offline Harvey
#6 Posted : 24 November 2009 01:11:46(UTC)
Harvey
All,
Thanks for the input. I believe reeds will work with M track, Marklin just takes all (most) reference to M out of the catalogue. I would appreciate if anyone can post a picture of how the reed is connected to the track it's placement.
#7 Posted : 24 November 2009 01:36:56(UTC)
Alan, I use reed switches available from a local electronics supplier, and mount them on the top side of the M track. One of the wires from the reed switch is passed through a hole drilled in the track and soldered to the underneath of the track.
You need to be careful with the reed switches as once you bend the leads it is difficult to bend them again without breaking the glass vial of the reed switch.
Where there is room underneath a wagon, I will use some magnets available from a local variety store, otherwise the one that Marklin sell are good for wagons/locos with low clearance underneath. The magnet do need to be fairly strong, but not too strong otherwise the magnet will derail the wagon when it tries to attach itself to the metal M track.
Contact tracks are good for occupancy detection, i.e. detecting if any thing (train, loco, whatever) is sitting in a given section of track. Reed switches are better for momentary switching, and also for detecting whether a train has cleared a certain point before taking some sort of action, e.g., has the train (with a magnet on the last wagon) cleared a point before switching that point to a different setting.
Offline Harvey
#8 Posted : 25 November 2009 22:29:18(UTC)
Harvey
I looked on line for reed switches (7555) and found very few available. I have purchased 1 to experiment with. Wondering what others who use reeds do. Purchase reeds from other than Marklin, what manufacture, model numbers, etc?
Thanks, Harvey
#9 Posted : 25 November 2009 23:09:45(UTC)
Naked reed switches are available in electronics supply stores as Radio Shack and similar. Work just as fine as the expensive 7555, but you don't get a fancy plastic cover with them... Just pain the reed switch in a color that matches and they will be hard to see unless you really look for them on the layout.
Sometimes you need to cut the leads, then do invest in a wire cutter that has one straight edge. The normal cheap wire cutters have a "V" shape edge and that introduces a mechanical shock effect when cutting that may damage the internals of the reed contact inside the glass tube.
And as David says, be careful while bending the leads. Best practice is to have 2 narrow flatnose pliers, one holding the lead close to where you are bending, and another to do the bending... Sensitive bastards they are...
Bumpy Reed Switches? (H0-scale)
Belarus Jabez 27/03/2017 23:50:24(UTC)
How many reed switches for train position feed back (Digital)
by Gregzim 09/03/2016 13:00:45(UTC)
Help with Reed Switches (General MRR)
by aos 31/12/2013 17:43:58(UTC)
Reed Switches and Unversal Relay (Digital)
by David1954 03/10/2013 03:55:43(UTC)
using reed switches on K tracks (H0-scale)
by French_Fabrice 22/11/2011 13:12:04(UTC)
Alternative to Marklin Reed Switches and Magnets??? (H0-scale)
by aos 31/12/2010 16:42:05(UTC)
Reed switches hanging up (Model railroad wiring)
by nelson77 06/03/2010 23:33:50(UTC)
Reed switches for automatic operation (H0-scale)
by elsleuth 15/05/2004 01:12:24(UTC)
by Thomas L. Stephens 13/08/2002 03:34:00(UTC)
This page was generated in 0.717 seconds.
