Offline EB421
#1 Posted : 11 February 2026 18:20:31(UTC)
EB421
...ed six, when I first watched the Thomas the Tank Engine episode where James crashes and gets rescued with rail cranes. Ever since then, I've had the strongest addiction to model railway stuff that does something.
It's not just cranes of course, I want to try all of them. I had some post office coaches once, they were great. Watching the bag disappear off the pole as the coach went past was an amazing feeling, and watching it reappear elsewhere on the layout was great. This one time at a club, I got a hit of wagon hump shunting. It's not really my vibe but it was still a really great feeling. But then this one time there was an archimedes screw lift loading sand into wagons for delivery elsewhere on the layout and honestly I thought I was gonna die. It was amazing.
These cranes though, they're the best. The first was that green one, you know just like a small one to get me started. I need to find some thread to recable it, but I just keep getting tempted by bigger and better things. First I got that Hornby one but it's so annoying to have to do it all by hand on an electric train set and then I got that Hornby Railroad one so I could mock how bad OO vs H0 cranes were but then it turns out it's actually a H0 crane anyway which was even stupider but it looks cool so and then there were the Marklin START-UP cranes that are just peak, they have the slip clutches on the boom drives, they're easy to convert to DCC 2-rail and like they *move* they're just so great but then I used up all my money buying them so I had to switch to a cheaper supplier who keeps cutting the product with like "UNTESTED SOLD AS SEEN" but it's so cheap and I just can't stop and now I have two Roco DCC cranes that work perfectly except one is missing a wheel so I've got a Roco hand-operated crane coming to steal parts off.
I just heard about this really great new one with a waiter who moves around a panoramic car serving drinks and I keep pestering my dealers to try and get me some. They say it's "dangerous", "not their business model" and "basically impossible to modify to run on DCC 2-rail" but I'm gonna keep asking I don't know how they expect me to NOT want to try that.
Anyway, y'all if you know any online therapy that's good for addiction services that'd be really great.
Too many, far too many rail cranes.
Edit: Yes, the writing is meant to be "reddit style unreadable" as a comedic touch, but joking aside help I can't stop buying rail cranes.
I have found out some useful stuff about the Roco cranes, so I should turn this into useful information for people wanting budget cranes rather than just a cry for help - because there seems to be a lot of conflicting data around.
Summary; there are three decoders. 96507, which is hard-wired. This is mainly used by the 41290 portal crane; but I think it's in some rail cranes. This decoder is dual-mode Motorola+DCC but doesn't have DIP switches for address selection in Motorola mode. I'm unclear of it's features in either mode. 96519 is the "AC" decoder, which is replaceable and is used in 46900 and 40111 I've seen versions with DIP-switches and versions with solder pads for address selection. There is also 96518, used in 46800, 40109 and 40110. This is DCC. I believe there were also other variants (46801, 46902, etc) in different liveries. The decoders should be similar to the "round number".
The DCC crane seems to cause some confusion for people because of it's programming limitations. To sum up: It is a pre-railcom decoder.
CORRECTION - it does support long addresses. It turns out there's a bug in the z21 app, where if you change the decoder address on a loco/wagon/etc, it resets the regulation speed steps to 128. And then the crane does nothing. Having now noticed this, and tested it - both my RKRAN_v3 based decoders now have long addresses. Unfortunately my RKRAN_V2 is dead so I can't actually test if that had the short-address limitation, but I assume it doesn't. These are 1998-2006 decoders after all, which I guess is later than long addresses were introduced. I honestly thought they were earlier! Most confusion comes from the speed step limitations.
The "recommended" method of operation of the cranes is with 10780 (DCC) and 10781 (Motorola), which are interfaces from a 15-pin PC joystick and act as standalone DCC/MM controllers. In the case of DCC, it is this controller that is limited to 14 speed steps, and decoder addresses 6/7/8. This is why from the factory, the decoders are configured at address 8 and 14 speed steps. However, setting CV29 to say, 18, the decoder functions in 28 (but not 128) speed step mode. If you set 28 steps or change the address outside this range you will not be able to use the joystick controller; but you'll have an easier time on modern DCC. Because the cranes have motors, they program normally on a programming track.
Control of the DCC crane (rail or portal) is as follows:
F0: rotate using speed control
F1: raise/lower boom using speed control
F0+F1: raise/lower hook using speed control.
If you have the 46807 excavator shovel or 46807 electromagnet, this is operated with no functions on by sending a "burst" with the speed control. Forwards: on, Backwards: off.
There are two replacement decoder carrier boards for the Roco cranes, both of which are carriers for the LokPilot or Loksound. The first was made by DCCDecoderService, and is discontinued. This decoder did not support the plug-in accessories, but was officially rated for the rail cranes and an LED could be hardwired. The second is a very similar design by andrea-karina on eBay (only shipping to Germany), which is officially only supported on the pluggable portal cranes but does support the magnet and excavator. For the DDS adapter, the controls are:
F0: Light on/off
F1: rotate using speed control
F2: raise/lower boom using speed control
F3: raise/lower hook using speed control.
All versions of the Roco crane do not use full slip-clutches, which means if you grab them and try to rotate them by hand without applying the disengaging lever, you will break the gearing. The rotation gear is also notorious for age-related degradation. Replacement gears are available from DCCDecoderService.
The Roco DCC rail cranes have NEM-compatible coupler pockets on the crane, but not all of the included match wagons are NEM.
The Marklin 46719 and new 46720 set do have clutches (so tolerate some rotational hand-abuse if necessary), but do not rotate infinitely the way the Roco cranes do. The reason is that this means they can be rotated by the track curves - and therefore do not need to be "switched" from one mode to the other when the locomotive stops and you want to pick something up. They don't have Railcom either, but do support long DCC addresses, 128 speed-steps and MFX. These have newer quieter motors, do not require the match truck for pickup, and are the first dual-protocol models.
Review time
Honestly, I don't really recommend the Roco rail cranes. They're a slight pain in the butt because of the programming limitations, and the decoder replacements are great but expensive for what is a minor increase in functionality in practice (and a removal in some cases). Worse though - because the cranes won't rotate by hand with the gears engaged, that means unless your layout is an exact straight line; then the Hand of God has to enter the layout to switch rotation from "travelling" to "operational" which somewhat defeats the point of having a non-mechanical rail crane in the first place. The portal crane is a better buy than the rail cranes. It's much easier to accept the joystick interface if it doesn't require complex track isolation; which means the decoder limitations aren't really important any more. Also, as it's fixed in place - once installed it can be left permanently in "operational mode" unless you're doing maintenance nearby and might knock it. This should also mean less wear on the fragile gear (though honestly anyone with the old Roco cranes should keep a spare gear in stock ready for the day).
The lifting capability of these is broadly similar. Without adding extra stabilisation, the rail cranes *will* fall over with any significant load. You're not going to be lifting a brass-body locomotive with any of these. However they can lift (very) light rolling stock, printed cable drums and crates, etc. Delivering skips is a favourite use of mine. The Roco will manage something like a magnetic 1/87 toy car or a bucket of sand though, which is cool - and obviously the portal cranes are similar but can take advantage of better anchoring. A good use of the portal crane would be in a scrap yard scene, picking up crushed cars etc for dropping in a wagon going to a smelter. It was once actually sold in a set with "scrap cars" and wagons to drop them in - I think this was 41290.
For a mobile crane, the Marklin START-UP is a better choice. It's quieter, more reliable, requires no divine intervention in use, supports modern speeds and addresses, and unless you find cheap "sold as seen" deals like the ones I did - is much cheaper than the Roco. It also doesn't take much to convert to 2-rail + NEM (a few wheelsets, a TRIX pickup plate, four coupler pockets and some conductive acrylic - and only the paint is not a current MARKLIN spare part) so it's superior even for DC use. For a fixed crane - the Roco is obviously worlds above a 7051 crane; not least because you can run trains under it; but also being digital out of the box means it can be carefully integrated into a modern layout. It's no-where near up to the standards of the 76501 travelling gantry crane (66105 for DCC users), but it's also 1/5 of the price. I'd soft recommend it.
Edited by user 17 February 2026 00:14:14(UTC)  | Reason: Not specified
thanks 6 users liked this useful post by EB421
Offline Jimmy Thompson
#2 Posted : 11 February 2026 22:01:59(UTC)
Jimmy Thompson
And there are quite a few "collective nouns" for cranes, however the most applicable here might be
Construction of Cranes
...or...
Dance of Cranes
Your choice my friend! Drool
Jimmy T
Dr Dirt's Rule #1 and
Offline EB421
#3 Posted : 11 February 2026 22:26:44(UTC)
EB421
Dance of Cranes
Oh definitely this one!
thanks 2 users liked this useful post by EB421
#4 Posted : 11 February 2026 23:14:23(UTC)
Jimmy Thompson
I wait with abated breath for the video thereunto pertaining! LOL LOL LOL
Jimmy T
Offline EB421
#5 Posted : 12 February 2026 03:47:27(UTC)
EB421
Hit that like button and subscribe? LOL
I have a longer-form instructional video planned on converting the Marklin crane to 2-rail - the stuff is literally sat set-up on my filming rig waiting for me to get more than 4-hours sleep in a night.
For the other cranes; the repairs to the first 46800 are going to be difficult and awkward enough with full concentration, so I don't plan to film that. The repairs to this...
DCC Crane no. 5,
Might get filmed as they're probably going to be much easier. I'd also like to do something of a review/demo across all these cranes (including the 7051) that explores how to actually make them into something of interest on a layout.
But there will probably be some silly short-form demos like the "Dead or Alive AMV" LOL coming up too. Someone did a silly video with a portal crane a while back but for some reason missed the obvious punchline so that must be rectified. A parody of the original Thomas the Tank engine scene that started this would also be fun. And I'm sure I can find something of actual use to make these do. How much Ag solder could I wind onto a laser cut cable drum, before the START-UP cranes couldn't lift it? Maybe some loading capacity tests would be a good idea!
thanks 3 users liked this useful post by EB421
#6 Posted : 12 February 2026 12:33:46(UTC)
Jimmy Thompson
And when you are successful and the crane fires right up and lifts that load...
https://www.youtube.com/watch?v=0VkrUG3OrPc
And then comes play time! Woot
https://ttte.fandom.com/wiki/Lift,_Load_and_Haul
Jimmy T
Offline bph
#7 Posted : 12 February 2026 17:49:27(UTC)
Ah, yes i know the feeling, thanks for sharing. Cool
I used to have an analogue yellow Roco crane, but I sold it off when märklin anounced a digital crane.
And when Märklin launched the 46719 i got one of those, and sold off my old 46715. And as you write, the new one seems to be better in several ways. (I also have an old yellow 4671)
Came across a few photos of the Krupp-Ardelt 6t 103 prototype.
And this image shows a slightly stronger 10? or 15t? version working together with an Ardelt 57t crane
https://eisenbahnstiftung.de/images/bildergalerie/67215.jpg
So I now have the 46719 together with my 49570 Ardelt 57t crane
I made a short video of my digital cranes back in 2021: https://www.youtube.com/watch?v=Gxj9gzeu51Y
Edited by user 13 February 2026 13:50:27(UTC)  | Reason: Not specified
thanks 6 users liked this useful post by bph
Offline EB421
#8 Posted : 12 February 2026 19:06:07(UTC)
EB421
Well my analogue yellow Roco crane should be here by monday, and is headed for a quick death, with all the parts I plan to steal from it for the portalkran and the old digital kranwagen! I was going to cheap out and buy one for £10, but then I saw one for £30 which had a NEM match wagon and figured the cost of the NEM conversion would offset it instantly. Ironically I'm buying it from the same seller I bought the first digital one from. He might get a positive review this time! Last time after seeing the damaged bogie I decided "if you can't say anything nice, say nothing". The seller of the second one certainly has nothing to complain about in that review. By the end of this I plan for the analogue one to have:
One bogie
No buffers
No roof
No cabside rollers
No match wagon
No box
When I first discovered the 46719 I did think about getting a 4671 and going digital+analog, but the fixed metal couplers put paid to that very quickly. NEM or nothing!
I feel like this year's catalog justified my decision to get two - I really like the new livery, but at an extra £60 or so for a wagon that would be way harder to convert to DC; better off buying them solo as I did.
In the immortal words of Keanu Reeves: JESUS CHRIST THAT THING'S REAL!? I thought I'd bought something fictional but pretty! That's so awesome! Thanks for sharing this!
And this image shows a slightly stronger 12t? version working together with an Ardelt 57t crane
And now I have prototype to mix and match my four cranes freely. Useful!
Liked and subscribed!
I'm assuming you've seen this already on the other thread where I posted it but just for comedy one more time:
As I said, I'm aiming to come up with some more useful videos before long. Another fun idea from today, I went hunting to try and find the original RRP of the Roco DCC cranes, and in either the 1998 or 1999 catalog found a great marketing photo of using one to lift track panels. Which is both very obvious in retrospect and a great idea! A little fermi estimation has a British Rail 60ft track panel work out at about 5T, so loading 20cm track lengths on the little K-A's should be perfectly "scale" (even if it's a ridiculous prototype).
The 46715 is fantastic, but the new one is definitely quieter. I also have envy on your tool coach. As I mentioned, I'd like to make tool coaches for these that have sounds attached.
Unfortunately, I made my life difficult on the Roco cranes by getting the Lokpilot. Not an issue when I just had one (in fact it would have been easier since I could have just asked DDS for a sound decoder) but now I have two, one with the old control layout and one with the new. Which means only one crane can be consisted with a DDS sound decoder; and since I bought DDS's last adapter board I won't be getting another!
Still; the question for me is if DDS would program a 58219 LokSound FX for me - one crane is better than none. Then again, I'd also like to add some stuff like a replica of the welding and angle-grinding functions in the Marklin coach, so probably better to face up to the challenge and make my own profile. Especially since I want to make F1-3 purely sound and be able to remap the real function pins to something useful like a "welding LED" on F6.
I definitely need more sleep before I try LokProgrammer again.
Oh, and I need to think very carefully about the selection of my tool coach.
A Bulleid Coach with a Roco CraneType F coach with a Roco Crane
This model railway is perfectly balanced with no scale issues.
Offline Bogenschütze
#9 Posted : 12 February 2026 19:15:57(UTC)
Bogenschütze
...or...
Dance of Cranes
How about a "Hoist of Cranes"?
Marklin - "The train set I never had as a child."
Keith Bowman
thanks 3 users liked this useful post by Bogenschütze
#10 Posted : 12 February 2026 20:08:14(UTC)
Thanks for these photos. I was never sure that the crane as modelled by Marklin was to scale, but looking at this photo it looks like Marklin have modelled it pretty accurately.
What does amuse me is that Marklin then mounted the same carne on a truck chassis to have a mobile crane in their diecast vehicles range, which are a somewhat larger scale (I think 1:43, similar to Dinky Toys and Corgi), and yet it doesn't look out of scale in that use either.
#11 Posted : 13 February 2026 13:19:25(UTC)
Jimmy Thompson
Bogenschütze wrote: "How about a "Hoist of Cranes"?"
Brilliant! Woot Wish I had thought of that LOL LOL
How about a name for our group here?
Crane Lovers Anonymous (CLA) Sneaky
Edit: or
Hooked on Cranes Woot
Edited by user 13 February 2026 20:14:38(UTC)  | Reason: Not specified
Jimmy T
thanks 4 users liked this useful post by Jimmy Thompson
Offline bph
#12 Posted : 13 February 2026 14:40:30(UTC)
Good luck with the analogue one, and the repairs of the portalkran and the old digital kranwagen Cool
And yes, the option to replace the couplers on the new 46719 is a nice upgrade. And perhaps there might be other liveries from Märklin in the future?
Looking forward to more videos from you Cool , unfortunately, I lost access to the youtube acount after I switched ISP. (no linked to phone etc)
Unfortanatly the 46715 and later ones in that series seem to have a high failure rate when they age. Hopefully, the 46719 and 20 are better as they have some upgrades......
If you should stumble on a second hand 49965 that you would like to convert, note that the early versions don't have DCC, but the later versions have. I have an early version, but I strongly suspect it just has a standard mSD 21MTC decoder, so it should be easy to upgrade. And Märklin are "cheating" slightly and is just using the steam locomotive firebox flickering function to simulate the welding flickering ;) The decoder project is available for download. So it should be reasonably easy to recreate on an ESU decoder etc.
I'm a bit tempted to upgrade my 49965 to mSD3 with more lights and sound functions and a better speaker. but that will be in the future, and I have some other projects to do first.
And you also have the 49967, which has a more extensive sound project, but it doesn't have the welding lights.
yes i was also pleasantly surprised when I found out, as there is not much information out there. It would be interesting to know if something like the truck mounted version was made in real life, also.
Some more info:
https://www.hardconn.de/krupp.htm
https://www.modellbau-wiki.de/wiki/Krupp-Ardelt_Kranwagen_6_t_Bauart_103
https://www.modellbau-wiki.de/wiki/Schienendrehkran
https://www.digital-bahn.de/info_kompo/kran.htm
Offline EB421
#13 Posted : 13 February 2026 16:26:13(UTC)
EB421
The King decided not to bother delivering the portalkran this morning, and doesn't do saturday deliveries so that's Monday now. He did bring the 46331 though; so I can give you an after-action report on that.
The starting point is £31, which is the cost of the 46331.
Immediate value, I got a close-coupled flat wagon. Cost of one of those is £25 new, £17 used. So I have £6-£14 of value left to recover. This is of course, where things started to go downhill. The bogies, are way more different than they looked on the low res eBay photos. The only way to use them to repair the DCC crane's bad pinpoint bearing would be to take both bogies out, cut the sideframes off and then weld them back together. Not impossible, but way more problematic than it first looked - and by the time you do that you're possibly better off filling it with epoxy putty, drilling it out and fitting brass axleboxes. Next up, on the mechanical crane, the buffers are moulded. So those are still missing.
The livery is also slightly different with a much brighter silver on the roof. But; it does fit - so the mechanical problem is solved on that side. The wheels are identical, so some from the 46800 with the tyres falling off were swapped out, and I reinstalled one to replace the missing one in the bad bogie so that at least 11 wheels are on the track - it's now working much better, and is at the right height. I'm pretty confident I can salvage the rollers as I originally planned (when the portalkran finally turns up) and the hook and cord also look like useful replacements.
The real bonus though; this crane had Fleischmann couplers on the bogies; and the previous owner wanted to fit it with Roco couplings, so replaced them with NEM363 pockets. Those are about £7-£10 per pair to buy, and I have several bits of Fleischmann stock awaiting NEM conversion so that's a win right there.
So:
  • Axles x3
  • Roof
  • Fleischmann NEM pockets x2
  • Box
  • Rollers
  • Spare hook & cable, and boom cables
The body itself should also fit without too much trouble. The only obvious difference is that it doesn't have a hole for the LED so modification of either the bodyshell or the decoder would be needed. The livery on the "toy" cranes is also quite simplified. I wouldn't do it for an aesthetic redesign, but if you have a DCC crane that got broken; it's nice to have the option available. Other possibly-salvageable parts include the boom itself , and the roller hangers. These are subtly different but should work either unmodified or with slight trimming.
Ironically, the £40 crane is in much better condition than the £90 crane. So that's getting the original 46800 box and the 46331's KKK match wagon. The jankier crane gets the 46331's box and it's original wagon that needs converting.
I got good value from this for £31; but I think that's not really a rule - spending the £60 for a brand new one is not going to be worth it unless you're really desperate. They don't normally come with the NEM couplings on the crane after all (without those, I'd probaby feel significantly less positive about my decision), and while the current flat wagons are still KKK+NEM they're also massively simplified, uglier models. Not being able to salvage the bogie is the biggest pain. Adding a close-coupled NEM match wagon to newer versions; but taking away the close-coupled NEM pockets from the crane itself is certainly one of the choices of all time.
#14 Posted : 13 February 2026 23:16:24(UTC)
I can't say that I have an obsession with cranes, but I am known to have a fetish with "matching" model RR items.
For example, I have the 29750 (2005) Feuerwehr train set in overall red.
So I automatically purchased a matching crane set 46716 (2008) where the crane operates from any of the digital controllers.
(Sorry if the use of the word matching confuses anyone where the set comes with the match (tender) truck).
The digital control is by piezos so the operation is not that smooth or convincing.
But it is fun.
And I guess the later ones have real motors.
Offline EB421
#15 Posted : 14 February 2026 05:35:44(UTC)
EB421
But it is fun.
I can kind of relate to that too. My prototypes are all over the place, but I do get a great satisfaction from a rake of consistent (preferably not actually identical) models. I have ...nine HBIS wagons for one of my rakes? I don't think more than any two are the same, but given the way cross-border shipping works they're all plausible to put together. My main coach rake is a mix of blue and grey Mk1 and Mk2 coaches, too - for a little subtle visual interest. :D
In the "quality of motion camp", Roco crane with Lokpilot fitted wins; right up until you want to move the thing so the Monty Python hand of god has to get involved again. Marklin 46719 isn't far behind - the motion is smooth and with 128 steps can be controlled quite finely. Plus, it doesn't have the slop that gives a long start-up time on the Roco cranes. Roco with the stock decoder is very loud, and because it's only 28 steps, very coarse. It works fine, but the decoder swap is not a subtle difference.
I should email the German seller to find out whether their board has some reason it's unique to the 40109 or if it's confirmed to work in the railway cranes. Handy to have another supply, and even handier if they can drive the add-on modules. Would be fun to design a motorised add-on of my own like a drum tipper or pallet lifter; though that project is well on the "maybe in another life" zone of my to-do list.
Offline EB421
#16 Posted : 14 February 2026 17:56:42(UTC)
EB421
It's the weekend, so I investigated further! The key question for me whenever I look at anything Marklin is - can I convert this to NEM+2-rail+DCC which are my basic specs I have to meet. Both of these can be had with DCC, so that's solved - NEM is out of the box as well...
The problem is 2-rail. Stopping them shorting the track is fine; they both take my beloved Evemodel pinpoints. But I can't find a schleifer part code for 49965 to investigate if it's something that can be modded from a Trix/HAMO part; and the 49967 Schleifer is a pretty confident "nooooooo". So I'm now machining bronze. I'd certainly have been willing for the cranes, since they're such a specific thing; but I feel there's other options for match wagons that require less mechanical work. I've downloaded the decoder project, anyway!
Using ESU decoders is always handy for me because I get block detection from them; and they have the "cheap" options of the LokSound 5 Fx and the LokPilot 5 lighting strip for use in brake coaches, the tool wagon, etc. Given that 3/4 of my cranes don't have railcom, making sure I have it in the support coach is as important as the sound and lighting itself - so that it can provide the end-of-train detection I'm after. Not that I'm using that in my stuff right now, but if I'm spending the kind of money for sound decoders - I want to have that base covered now while I'm doing it. No comments on the Marklin Class 66 and Class 22 loco's... If I ever upgrade the Class 22 to sound, at least I'll be able to steal the 39723 decoder project and stick it on an MSD3.5! Anyway; the 3.5 gives me options to use that project and still have Railcom - so I'll be preserving a copy. :D
#17 Posted : 15 February 2026 14:42:10(UTC)
Of course, you could always buy the Trix version, when available ... Blushing
Offline EB421
#18 Posted : 15 February 2026 15:56:25(UTC)
EB421
Maybe I should have put a TRIX version on my 2026 wish-list thread instead of Flying Scotsman coaches! :D It's the sad thing about the Insider stuff for me as a 2-railer; same as with the BR Class 22 from 1994 - there's often no TRIX versions of the same models. Or HAMO, in the case of the Class 22. Hence spending the last 8 months converting one. ;)
I'm not bitter about this, to be clear. I understand that when you have a limited run tooling, adding a whole bunch of extra parts in a hope that your smaller segment of customer base buys it - isn't an easy task. I would like one though. :D
Offline EB421
#19 Posted : 16 February 2026 15:26:22(UTC)
EB421
Portal crane turned up!
A Roco manual crane denuded of most of it's parts.
To shreds, you say?
There is really not much left of my mechanical parts crane. The pin that holds the spare hook, and I ended up taking both rollers for visual uniformity.
The decoder had clearly had some rough treatment. It's a v2 decoder (the stock one from the first rail crane was a v3), and both the LED and accessory socket had been knocked loose - luckily without pad damage.
A Lenz RKRAN-V2 decoder, showing a slightly dodgy LED repair
Not my best work.
A Lenz RKRAN-V2 decoder, showing a slightly dodgy socket repair
Somewhat better. Honestly, SMD work terrifies me so I'm happy to have done this well with my little pinecil. Anyway, now repaired this is going into stock as "untested spare crane decoder".
The "track" feed wires were also shot and hilariously badly bodged, so I replaced them with two of the unused function wires from my Class 22's MLD3 kit.
And it almost entirely works! The rotation motor isn't looking too healthy, it's slow but fine forward, but back it stops after a couple seconds. Not sure if it's a simple failing brush problem or something more serious, but I'm not investigating right now. It may be Derek Zoolander in that it can only turn left, but it works.
Oh, and the railings are completely shot; maybe one can be salvaged if I can solder the mounting pin back on - but there's too many missing to do both. So that's a challenge for another day.
A Roco 40106 (I think) DCC Portal Crane!
Not too shabby for 20 minutes work (including the time to recondition the now-spare decoder) and some parts from a hand-crank crane. Apart from investigating the motor, the only thing needs doing on this is that the cable guide is missing. Should be an "easily printable" kind of thing so next time I have one of the other cranes apart I'll get photographs and measurements so I can clone it. It's not actually critical to operation so it'll do without as long as I'm careful to watch for any snagging.
The motor is listed as "discontinued, but available". So that's good to know for now, unfortunately it's also 82eur. They also have an "accessory bag", what might actually be the missing cable guide, and amusingly - a green housing. Maybe I should get that for one of my rail cranes, and have yellow, green, and red! Then I just need a blue one and I have Smarties!
Anyway - it should be safe for me to do diagnostics, and in the meantime I might pick up the accessories and cable guide - it would olve my missing part and might also replace my missing steps and railings!
Offline EB421
#20 Posted : 17 February 2026 02:04:00(UTC)
EB421
So, I'm weighing up whether to order a spare motor.
The motor from a 40106 Portalkran
It's working, it's smooth, and it seems to be going a full rotation before stopping now, so that may be a deliberate feature? But it's not the healthiest motor ever and there is a slight smell to it. But you're talking £100 by the time it lands, which is a lot of money for a whim.
What's less working is the original decoder.
A (dead) Zimo RKRAN_V2 decoder
As you can see, I improved my solder joints on the LED, buuuuut when I tested the decoder, it's actually just dead anyway. RIP. The obvious question is "what's wrong with it". Comparing it with the photo in the parts manual for the 40110 (same as my 40106/40109 - but with the fancier boom) there's no visible damage to any component except the big one to the right of the μC - hard to say what it is, since I'm not an expert. Fuse, inductor, high power resistor? In any case, the damage is on the terminals and not the body of the component where I'd expect for a blown fuse, and at a cursory glance it doesn't appear to be in the power circuit. So; not confident in that analysis. It's not worth spending any serious time one, but if I get bored some time I might take a multimeter to the thing. It's a pity Marklin hate selling their mainboards - it would be a fun game to try and apply the 46719 boards to one of these. In any case; all my cranes have working decoders, and this is a spare to play around with some time. Looking at the IC markings on this and a few other Lenz decoders - this is a modified LE040/10040 (or "4th generation") decoder. Ironically, those are rarer than these are. Go figure.
The biggest problems for repairing these then are the decoders and motors. Replacement aftermarket decoders are available, but only in Germany, and by the time you add the LokPilot you're at €100 and change. Then, you have the price of the replacement motors - at about €80 each, that's pretty fatal if one packs up, even while you can still get spares. There's a few more Portal Cranes on eBay.de at the moment. I'm bidding on the cheap one, but looking at it, the LED is yellow; which means it's the same v2 decoder that's a corpse here. Given that it's also advertised as "dead", I'm bidding on the assumption that at least the decoder is also fried on this one, and it'll be a static model for now. It's also going to need the sacrifice of another hand-crank crane as rollers, the hook, the cables are all missing. Expect about a €150 repair bill to get that one back in order!
I took the time to clean up while I was doing the testing - and I think this is now pretty good - other than the missing cable guide, railings and top steps.
Roco 40106 (probably) Portalkran, but this time it's clean.
Does anyone have any experience of emailing Roco? I'm tempted to just say "What's in 127984?" and see what their answer is. Shipping to the UK looks to be about £10, so it's not end-of-world money, but I might as well see if I'm wasting my time first. I've also torn the manual crane up a bit more - anything that can be used on the three digital cranes has been removed, and what's left is looking pretty sorry for itself. The interesting parts of "WHY isn't this reusable" are the bogies and the boom - they've literally made these worse for the hand-crank model - on the digital cranes, the boom has a roller for the hook line to run over, on the hand-crank it's fake, just part of the moulding. Otherwise it's functionally identical to the digital one. Why make a separate, worse part? Did it really make the crane THAT much cheaper?
Now, there's just ONE more thing. I - was spectacularly wrong. Both of the v3 decoders in my cranes, are now using long addresses. They always appeared to accept the address when I gave it to them, but never responded after. Now I worked out why.
It's a bug in the Z21 app. When you're editing a loco (or wagon, whatever). If you change the address, the speed-steps get reset to 128. So every time I changed the address to a high number, it stopped responding, because I wasn't sending it 28 speed step movements. For the LOVE OF PETE.
I've edited the "info post" that started this thread to make sure it's correct in there - but wow. That's hilarious. It now has me wondering - will the joystick crane controls in the app work, if I double check the speed steps after?
Edit: Nope. Z21 app crane controls still do nothing. Pity, I'd even found a bluetooth game controller to try it with.
Anyway, I took some time to tidy up my work bench. Here are the parts from a Roco START crane that have no use for repairing a Digital Railway Crane 4680x/4690x or a Digital Portal Cran 40106 to 40111.
The scrap parts from a Roco 46311.
Efficient, no?
If you wanted to, you could keep the chassis, chassis plate, bogie and wheelsets together and scratchbuild something on top. But in my case they'd broken part of the chassis body when fitting the Roco tentacle-coupling-things that were in the NEM pockets, and I don't have a huge amount of reason to do that. So, it'll get hung onto as "litter", something I can airbrush rust-red and dump in a scrapyard (probably as a basis to fill out a larger pile of stuff). Also, SON OF A - as well as damaging the chassis body, they'd actually pulled the buffers, cut them to be "retracted" like a coach using it's Janney coupler, and glued the heads straight onto the bosses. If I'd bought ANY OTHER crane, I'd have buffers on mine. frustrated grumbling. Never mind, I got £10 of Fleischmann NEM pockets because of it, and if I don't end up getting another parts crane, they're part no 98979 and €1.80 each. But jeez.
Anyway - here's the re-use list:
  • As above, the bogies can't be used as-is but the side-frames can be cut off and used to repair those of an existing digital bogie. They could also be modified if you scratchbuild your own pickups and cut off the Fleischmann coupler mounting arm.
  • The cab-side roller-frame needs the rear 20% cut off, but then should work fine.
  • The boom needs the fake rollers cut off, and a real metal roller-unit from a digital crane boom installed. It also needs the stop-blocks at the bottom replicated with some styrene block. It won't replace a missing boom (I mean it will, but without the roller-unit you'll not have the best time), but if you have that roller-unit you can replace a snapped one.
  • The body can be used by de-soldering the LED from the decoder, or drilling a hole for it, except possibly the 40110/40111? Because of the taller boom, these have a different body shell. However, the 40110 ersatzteilliste shows the older lifting-roof design as a spare, so maybe you can still use it but it will be uglier?
  • The roof and roof-clip can be used as-is.
  • The remaining rollers can be used as-is.
  • The hook/cord and boom cord can be used either as-is, or by cutting off the knots and making new ones. Not tested.
  • The "spare hooks" on the boom can be used as-is - though note the big one is plastic, vs metal on the digital.
  • The wheelsets can be used as-is.
  • The buffers can be used as-is.
As for "parts that can be used elsewhere" - the steel weights can find a use on something that needs to be heavier. The couplings can be re-used on anything with a Fleischmann coupler pocket, but why the hell aren't you NEM fitting those you weirdo. And my favourite part - the hand cranks fit the drums on the Lima and Hornby H0 gauge cranes. So if you have one of those, you now have two spare cranks. It's the little things in life!
Oh, and something interesting - this was hilariously mis-listed as an AC 40111 which I could see was wrong from the boom. I wasn't sure if it was a 40106 or a 40109 though. Looking at them online they share the rail-style boom, the red body and the yellow-led decoder. But; looking at teardown photos (and that eBay replacement mainboard) the most visible difference (once you have them open, it's impossible to tell externally) is that the 40109 has a double-accessory-socket decoder, while the 40106 has a single-accessory-socket decoder. So; I guess this one's a 40106! Good to know!
And if you want to outbid me on the current eBay 40106 - take note of my thoughts above on that yellow LED and the €150 repair cost. Beware! But if you do, I won't take it personally. ;)
Offline EB421
#21 Posted : 06 March 2026 11:29:52(UTC)
EB421
So anyway, a family member has taken possession of Crane 6; and if anyone wants to bid the 40110 on ebay.de to an unattainably high number I'd greatly appreciate it help i cant stop.
At this rate I will deplete the world's entire supply of handraulic cranes to feed my dcc addiction. Still waiting for another 46331 to hit eBay UK; since that specific version comes with the most useful match wagon for my collection, and if I'm gonna tear up a crane for parts it might as well be the optimal one.
#22 Posted : 06 March 2026 18:08:50(UTC)
Jimmy Thompson
"The only way to get rid of a temptation is to yield to it" - The Picture of Dorian Gray - Oscar Wilde RollEyes ThumpUp
Jimmy T
This page was generated in 0.968 seconds.
