Offline realcaseyjones
#1 Posted : 12 February 2026 02:14:47(UTC)
realcaseyjones
I'm curious what are the longest trains people run with Z scale Märklin engines. And does this vary much between 3-pole, 5-pole and coreless motors?
I got up to 20 cars. I made a quick video showing it running with 19 then 20 cars. 88482 5-pole (black box). There is an S curve off camera which stopped it from pulling the last (21st) car I have right now, a 4-axle metal chassis container car. I also probably should clean the track with alcohol before trying this.
At some point I'm going to make a more comprehensive video showing this in more detail comparing multiple types of engines.
thanks 3 users liked this useful post by realcaseyjones
Offline Manga
#2 Posted : 15 February 2026 08:03:50(UTC)
Manga
What are you aiming for, the Guinness world record ? or matching the prototype ?
For a single locomotive, you might get ~20 standard box cars (~240m real world train length).
Most freight trains in the real world are 1.5km long which is 6.8m in Z-scale, that's a very big ask.
If you want to pull more cars, add lead inside the shell to increase weight and add traction wheels to locomotive.
With this, you might be able to pull 30-40 cars.
If you want even more, a double header locomotive would be good.
As a general guideline, 1 locomotive with added weight and with traction tyres could pull ~1m of cars reliably.
Test train lengths on curves not straights, they add to rolling resistance.
I run a single locomotive without any extras, and pull 600-700mm of cars. That's pushing the stock model.
Most of my freight cars have 2 axles (less rolling resistance), passenger cars and some heavy freight are double bogie (4 axles) = more rolling resistance.
I hope you don't have any inclines.
thanks 1 user liked this useful post by Manga
Offline Poor Skeleton
#3 Posted : 15 February 2026 21:14:30(UTC)
Poor Skeleton
Originally Posted by: realcaseyjones Go to Quoted Post
I'm curious what are the longest trains people run with Z scale Märklin engines. And does this vary much between 3-pole, 5-pole and coreless motors?.
Oh dear! This is one of my pet subjects, I'm afraid, and one I have tried long and hard to understand!
The limiting factor with any Marklin locomotive is the grip of the wheels to the track. The wheels will always start spinning on the track before the motor is stalled. I think that answers your question about the difference between motors in terms of pulling power. Essentially there is none, though the weight of a 5 pole motored loco may be different to it coreless equivalent and that will affect traction.
In general the heavier a loco is, the more coaches it will be able to haul. However, there are other factors. Steam locomotives with pony trucks do less well than those without. This is because the pony trucks are sprung and therefore reduce the amount of the loco's weight bearing down on the driven wheels as well as adding friction.
I have also to say that I believe brand new locomotives pull less well than well run-in ones. I think this is because the wheels get polished with use and therefore grip the track better.
Needless to say gradients have a huge effect and so do curves, so keep gradients to a minimum and keep curves as large a radius as you can afford.
Adding weight will have a beneficial effect, but I've never found anywhere I can practically squeeze in any lead or tungsten ballast! It seems to me that adding traction tyres (I'm not sure how you'd do that) would be a mixed blessing, too, as that would reduce the number of wheels picking up electricity and cause poorer running due to contact problems - another bain of Z scale!
My main layout has 2% gradients and 220mm minimum radius curves and I have had 14 bogie coach trains (I guess about 1.7, long in total) running on that on occasions (Usually double headed with BR218s, I expect, though I think I've achieved the same with a single (metal loaded plastic body) Ludmilla on occasions. The problem I've then found is one of derailment.
This question is much more involved than it might seem at first sight but I hope my comments have shone some light on the issues.
All the best
Chris
thanks 4 users liked this useful post by Poor Skeleton
Offline Zme
#4 Posted : 16 February 2026 05:44:50(UTC)
Zme
Hello, hope all is well.
I agree, clean track, light weight wagons, traction wheels and a flat track are the key.
How many dry goods wagons do you think are in this string, I keep losing count. This guy runs 20 or more wagons all the time. Fills me with envy. Impressive.
https://youtube.com/shor...jI6M?si=JTIBuPsRFO3enryG
Take good care.
Zme
#5 Posted : 17 February 2026 05:31:42(UTC)
realcaseyjones
14 4-axle coaches is impressive!
Looked like at least 30. Very nice.
Not trying to set a record, just wondering what I should aim for if everything is working properly.
I found the S curve in the current layout to be a limiting factor for several things I've tried to run, so maybe I will avoid any such features if possible. There is an unintentional incline after the S-curve because there are wires sitting under the track and that also definitely seems to make a difference in outside cases.
thanks 1 user liked this useful post by realcaseyjones
#6 Posted : 23 February 2026 10:43:58(UTC)
realcaseyjones
21 cars (additional metal 4 axle car).
The cargo loco never pulled as well after being cleaned and lubricated but I expect I can restore it. It could barely pull the 21 cars so I swapped engines for his video. The Re 460 is a champ.
thanks 2 users liked this useful post by realcaseyjones
#7 Posted : 23 February 2026 13:40:51(UTC)
That is an impressive haul for a Z gauge loco.
#8 Posted : 23 February 2026 14:09:59(UTC)
What brand is the Loco.? Microtrains have been known for better pulling power than a Marklin Z.
#9 Posted : 23 February 2026 14:18:49(UTC)
realcaseyjones
The Re 460 (white) is 88456 brown box 5-pole Märklin. The Re 482 ("cargo") is 88482 black box 5-pole.
I think the 482 can do it (it does but it slips a lot). Something about how I cleaned it or lubricated it affected the traction a bit because it was pulling a little harder before.
Offline Zme
#10 Posted : 26 February 2026 07:11:03(UTC)
Zme
There are many Marklin locomotives which are good pullers. Marklin does not generally use traction wheel, unless they share production with other manufacturers
If you are looking for American locomotives, there are always a few released from Marklin every year. When production is shared with another manufacturer, you would likely find traction wheels and good pulling power.
If you like the European varieties there are many to choose from. In the early years of Z scale, Marklin produced a few models which were very heavy and this weight made them good pullers (8874/75). You can still find some of these around in the secondary market. A few years later, updates of these two model, resulted in a more efficient, but lighter weight locomotive and the ability to pull wagons was reduced. If you compare these models to the format which you mention above, they a very similar. Pulling power may not satisfy your desires. Generally, the “BOBO” styles with many gears inside the bobos create more drag than other models. Missing the weight, makes them less efficient pullers, unless you use two locomotives. I have found locomotives like Ludmillas have three wheels in each bogie, (but only use two). Are more effective pullers. The ludmilla is excellent and I feel the most effective is the 88136 because metal was injected into the plastic of the shell and the motor is coreless. Other locomotives which are similar are the Br 103, 151 and others (but may lack metal in the plastic ). Comparing these models will give you the idea of what to look for.
If you are interested in steam locomotives, check out the Br 94, or 96. Tank locomotives tend to be better pullers because it is not necessary to add the weight of pulling a tender. Of course if you layout if flat, and clean with good switch points you will have better results, no matter which locomotives you use. Traction wheels make a difference and might be used on the TGV making these better at pulling wagons. I have an ICE from Marklin and it is comprised by not having better drive wheels. Keep your wheels clean, add lube when needed and you will also be more successful.
I think you will find locomotives which will meet your standards. Hope my discussion makes it easier to decide what to add to your collection. Please remember, short trains were also present in any railroad and can look very good. I noticed, the older freight and passenger wagon were smaller units and therefore lighter to pull. Keep your ERAs together helps to add more wagons to a locomotive string like would be found with a Br 64/74.
Hope you found this useful. Take good care and let us know what your are considering or what works for you. Maybe other forum members will share their thoughts. I likely overlooked an important fact here.
Zme
This page was generated in 0.426 seconds.
