Offline realcaseyjones
#1 Posted : 12 February 2026 02:14:47(UTC)
realcaseyjones
I'm curious what are the longest trains people run with Z scale Märklin engines. And does this vary much between 3-pole, 5-pole and coreless motors?
I got up to 20 cars. I made a quick video showing it running with 19 then 20 cars. 88482 5-pole (black box). There is an S curve off camera which stopped it from pulling the last (21st) car I have right now, a 4-axle metal chassis container car. I also probably should clean the track with alcohol before trying this.
At some point I'm going to make a more comprehensive video showing this in more detail comparing multiple types of engines.
thanks 3 users liked this useful post by realcaseyjones
Offline Manga
#2 Posted : 15 February 2026 08:03:50(UTC)
Manga
What are you aiming for, the Guinness world record ? or matching the prototype ?
For a single locomotive, you might get ~20 standard box cars (~240m real world train length).
Most freight trains in the real world are 1.5km long which is 6.8m in Z-scale, that's a very big ask.
If you want to pull more cars, add lead inside the shell to increase weight and add traction wheels to locomotive.
With this, you might be able to pull 30-40 cars.
If you want even more, a double header locomotive would be good.
As a general guideline, 1 locomotive with added weight and with traction tyres could pull ~1m of cars reliably.
Test train lengths on curves not straights, they add to rolling resistance.
I run a single locomotive without any extras, and pull 600-700mm of cars. That's pushing the stock model.
Most of my freight cars have 2 axles (less rolling resistance), passenger cars and some heavy freight are double bogie (4 axles) = more rolling resistance.
I hope you don't have any inclines.
Offline Poor Skeleton
#3 Posted : 15 February 2026 21:14:30(UTC)
Poor Skeleton
Originally Posted by: realcaseyjones Go to Quoted Post
I'm curious what are the longest trains people run with Z scale Märklin engines. And does this vary much between 3-pole, 5-pole and coreless motors?.
Oh dear! This is one of my pet subjects, I'm afraid, and one I have tried long and hard to understand!
The limiting factor with any Marklin locomotive is the grip of the wheels to the track. The wheels will always start spinning on the track before the motor is stalled. I think that answers your question about the difference between motors in terms of pulling power. Essentially there is none, though the weight of a 5 pole motored loco may be different to it coreless equivalent and that will affect traction.
In general the heavier a loco is, the more coaches it will be able to haul. However, there are other factors. Steam locomotives with pony trucks do less well than those without. This is because the pony trucks are sprung and therefore reduce the amount of the loco's weight bearing down on the driven wheels as well as adding friction.
I have also to say that I believe brand new locomotives pull less well than well run-in ones. I think this is because the wheels get polished with use and therefore grip the track better.
Needless to say gradients have a huge effect and so do curves, so keep gradients to a minimum and keep curves as large a radius as you can afford.
Adding weight will have a beneficial effect, but I've never found anywhere I can practically squeeze in any lead or tungsten ballast! It seems to me that adding traction tyres (I'm not sure how you'd do that) would be a mixed blessing, too, as that would reduce the number of wheels picking up electricity and cause poorer running due to contact problems - another bain of Z scale!
My main layout has 2% gradients and 220mm minimum radius curves and I have had 14 bogie coach trains (I guess about 1.7, long in total) running on that on occasions (Usually double headed with BR218s, I expect, though I think I've achieved the same with a single (metal loaded plastic body) Ludmilla on occasions. The problem I've then found is one of derailment.
This question is much more involved than it might seem at first sight but I hope my comments have shone some light on the issues.
All the best
Chris
Offline Zme
#4 Posted : 16 February 2026 05:44:50(UTC)
Zme
Hello, hope all is well.
I agree, clean track, light weight wagons, traction wheels and a flat track are the key.
How many dry goods wagons do you think are in this string, I keep losing count. This guy runs 20 or more wagons all the time. Fills me with envy. Impressive.
https://youtube.com/shor...jI6M?si=JTIBuPsRFO3enryG
Take good care.
Zme
This page was generated in 0.226 seconds.
