Offline realcaseyjones
#1 Posted : 12 February 2026 02:14:47(UTC)
realcaseyjones
I'm curious what are the longest trains people run with Z scale Märklin engines. And does this vary much between 3-pole, 5-pole and coreless motors?
I got up to 20 cars. I made a quick video showing it running with 19 then 20 cars. 88482 5-pole (black box). There is an S curve off camera which stopped it from pulling the last (21st) car I have right now, a 4-axle metal chassis container car. I also probably should clean the track with alcohol before trying this.
At some point I'm going to make a more comprehensive video showing this in more detail comparing multiple types of engines.
thanks 3 users liked this useful post by realcaseyjones
Offline Manga
#2 Posted : 15 February 2026 08:03:50(UTC)
Manga
What are you aiming for, the Guinness world record ? or matching the prototype ?
For a single locomotive, you might get ~20 standard box cars (~240m real world train length).
Most freight trains in the real world are 1.5km long which is 6.8m in Z-scale, that's a very big ask.
If you want to pull more cars, add lead inside the shell to increase weight and add traction wheels to locomotive.
With this, you might be able to pull 30-40 cars.
If you want even more, a double header locomotive would be good.
As a general guideline, 1 locomotive with added weight and with traction tyres could pull ~1m of cars reliably.
Test train lengths on curves not straights, they add to rolling resistance.
I run a single locomotive without any extras, and pull 600-700mm of cars. That's pushing the stock model.
Most of my freight cars have 2 axles (less rolling resistance), passenger cars and some heavy freight are double bogie (4 axles) = more rolling resistance.
I hope you don't have any inclines.
This page was generated in 0.356 seconds.
